    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      First look at a 4 Panel Bifold (closet) Door:
      https://aws1.discourse-cdn.com/sketchup/optimized/3X/4/d/4d8702a0145ba9f841dc28c9d4cb304e373ce229_2_688x500.jpeg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      I still need to come up with the 2D symbol at the base of the door and even a more interesting problem is the opening algorithm for this door type.
      The two outer panels are simple, they are merely a rotation just like a standard swing door. The inner panels on the other hand not only rotate but they also translate in relation to the outer panels since a hinge constrains them at that point. I like these kinds of "hard" problems.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        First look at a 4 panel bifold door being opened and closed:
        http://design.medeek.com/resources/wallplugin/images/BF4.gif
        design.medeek.com
        • medeekM
          medeek
          Version 1.8.4 - 02.02.2021
          • Added bifold (4 panel - solid) doors to the door module.
          http://design.medeek.com/resources/wallplugin/images/wall_su476_800.jpg
          You can also add a threshold if used as an exterior door however I don't have a lot of options yet for exterior applications (ie. full glass). For now these are primarily for closet doors.
          You can also switch which side the doors face by choosing LH INT or LH EXT. For the four panel bifold it doesn't matter whether you choose LH or RH, it essentially ignores the handedness of the parameter.
          I still need to add in the 2 panel variant and then I think we will have most of the basics covered as far as doors are concerned, at least for now. Really exotic stuff will be up to the user to add into a framed opening (which I can provide).
          The door opening algorithm was a bit more challenging than everything encountered thus far but after a couple of hours tinkering it finally came together.
          design.medeek.com
          • medeekM
            medeek
            Version 1.8.4b - 02.03.2021
            • Added bifold (2 panel - solid) doors to the door module.
            http://design.medeek.com/resources/wallplugin/images/BF2.gif
            There are four possibilities for a 2 panel bifold door:
            LH OUT, LH IN, RH OUT, RH IN
            Whereas there is only two possibilities for a 4 panel bifold door: OUT or IN
            design.medeek.com
            • medeekM
              medeek
              I think I'm going to the call the "eyedropper" tool the "Copy Wall" tool. One additional icon will be added to the "Medeek Wall Tools" toolbar:
              https://aws1.discourse-cdn.com/sketchup/original/3X/7/6/761d77044005bf7e5bc8ffd5ab0c833ada679c3f.jpeg
              I know, I will hear it from everyone about the proliferation of more icons. However, there is an extension out there that allows you to customize the actual toolbars if you feel the need to:
              SketchUp Extension Warehouse
              Your library of custom third-party extensions created to optimize your SketchUp workflow.
              (extensions.sketchup.com)
              design.medeek.com
              • medeekM
                medeek
                Version 1.8.5 - 02.07.2021
                • Enabled the "Wall Copy" tool within the Medeek Wall Tools toolbar.
                http://design.medeek.com/resources/wallplugin/images/wall_su477_800.jpg
                Note I've only enabled this tool for rectangular walls. After I am fully confident that it is working well and I've addressed any bugs or issues I will set it up for all the other (gable,shed and hip) wall types.
                Please try out this new tool and provide any feedback or comments directly to nathan@medeek.com
                design.medeek.com
                • medeekM
                  medeek
                  I think the new Copy Wall tool will prove to be quite useful. As I am thinking about it this morning I realized that a similar tool for Doors and Windows would also be quite useful.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.8.5b - 02.08.2021
                    • Fixed a bug with the top plate cut out algorithm when walls meet in a "cross" configuration.
                    http://design.medeek.com/resources/wallplugin/images/CROSS_WALL.gif
                    Each wall teeing into the primary wall has had its corner offset set to 1/2 the thickness of the primary wall.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.8.6 - 02.11.2021
                      • Added the following Simpson Strong-Tie hangers to the beam hanger library: LUS26-2Z, LUS28-2Z, LUS210-2Z.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.8.7 - 02.15.2021
                        • Added an option for the garage door track in the global settings.
                        http://design.medeek.com/resources/wallplugin/images/GARAGE_TRACK.gif
                        Currently you cannot set this parameter per garage door, it can only be set globally (in the Garage Door tab).
                        https://aws1.discourse-cdn.com/sketchup/original/3X/d/6/d6de770ea518f789cfb4231df07ac10520668ee7.jpeg
                        design.medeek.com
                        • medeekM
                          medeek
                          I've had a number of people recently ask me for the ability to apply a wood grain texture to the lumber (ie. studs, plates, blocking, etc...) This really isn't a big ask, so I am going to enable another couple parameters in the global settings (Material Tab) so that the user can apply a texture to lumber and pressure treated lumber. Here is a first look at what that will look like (compare the wood grain wall to the solid colored wall):
                          https://aws1.discourse-cdn.com/sketchup/original/3X/e/8/e8a17a6986f2003f2bf497d25e9b232e8df3ec14.jpeg
                          I've tried to be very subtle with the wood grain texture so that it approximates my default lumber color but as you can see it is a slightly darker shade. I'm not sure I am entirely happy with it yet but it is a start.
                          design.medeek.com
                          • medeekM
                            medeek
                            Comparison between the solid coloring and with the textures enabled (Lumber and PT Lumber):
                            https://aws1.discourse-cdn.com/sketchup/original/3X/6/c/6ce5fcf33db5130d8b3a8dff791296a996723d5c.jpeg
                            I am quite happy with the way the pressure treated texture came out.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.8.8 - 02.17.2021
                              • Enabled options for wood grain texture for lumber and pressure treated lumber in the global settings.
                              http://design.medeek.com/resources/wallplugin/images/wall_su482_800.jpg
                              http://design.medeek.com/resources/wallplugin/images/wall_su481_800.jpg
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.8.9 - 02.22.2021
                                • Added a "Cedar Siding" built-in material (vertical) into the material library.
                                http://design.medeek.com/resources/wallplugin/images/wall_su483_800.jpg
                                http://design.medeek.com/resources/wallplugin/images/wall_su484_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.9.0 - 02.24.2021
                                  • Fixed a bug with the end stud height for Shed Walls with an "Inset Outside Corner".
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    mdkBIM Introduction (Japanese - 日本語)
                                    A brief introduction of the mdkBIM bundle in Japanese.
                                    mdkBIMバンドルの日本語での簡単な紹介です。
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.9.1 - 02.27.2021
                                      • Added one additional parameter to the "User Interface" section of the General tab of the global settings. This allows the customization (color) of the text of the HTML buttons.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su486_800.jpg
                                      This should also resolve the issue with the "white" text of the HTML buttons for MacOS.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        First look at the new Custom Beam Library. This will allow the user to create custom sized lumber, SCL or Timber beams:
                                        https://aws1.discourse-cdn.com/sketchup/optimized/3X/1/0/10c6b11a1d350603d484b733907e154087f1f649_2_690x485.jpeg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.9.2 - 03.01.2021
                                          • Added a Custom Beam Library/Manager in the Beams tab of the Global Settings.
                                          • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) beams.
                                          This may seem like a rather minor update but there actually is quite a bit of code behind any of these custom libraries (within the global settings) and their menu systems, hence the three days of programming that was required.
                                          Since glulam beams use a different sizing system I did not enable custom sizes for that beam type. Additionally, all of the steel profiles are also quite a bit more complicated than a simple width x depth profile (rectangle) so they were also not included in this update. If there are specific wide flange steel beam sizes etc... that you would like to see me add, please feel free to contact me.
                                          design.medeek.com
                                          • jujuJ
                                            juju
                                            :: OFF TOPIC ::
                                            Happy cake day Nathaniel.
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 80
                                            • 81
                                            • 51 / 81
