    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 1.8.2b - 01.27.2021
      • Enabled a second layer of sheathing for exterior gable walls.
      http://design.medeek.com/resources/wallplugin/images/wall_su472_800.jpg
      I only have the hip and shed walls left to update.
      !!! CAUTION !!!
      Installing this update will require that you delete and recreate any GABLE wall presets that you have previously configured. This update will not affect any rectangular, shed or hip wall presets.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.8.2c - 01.28.2021
        • Enabled a second layer of sheathing for exterior shed and hip walls.
        http://design.medeek.com/resources/wallplugin/images/wall_su473_800.jpg
        !!! CAUTION !!!
        Installing this update will require that you delete and recreate any HIP or SHED wall presets that you have previously configured. This update will not affect any rectangular or gable wall presets.
        design.medeek.com
        • medeekM
          medeek
          This completes all of the upgrades necessary to enable the 2nd sheathing layer for all wall types. A tedious but necessary process, over 30 files where updated in the code but only four actual parameters added to the wall types.
          Some minor cosmetic updates to the draw and edit menus of all the wall types. Hopefully the advanced options section is a bit easier on the eyes now and a bit more organized. All of these parameters can get a bit overwhelming at times even for myself, however each one is necessary so we can’t just wash our hands of them.
          I may take a bit of a break today from the code but at the same time I’m chomping at the bit to at least get some sort of “Wall Dropper” tool up and running since I don’t think it would be that hard to implement and I do think it would be very useful.
          design.medeek.com
          • medeekM
            medeek
            Version 1.8.3 - 01.31.2021
            • Added pocket doors to the door module.
            http://design.medeek.com/resources/wallplugin/images/PKT1.gif
            http://design.medeek.com/resources/wallplugin/images/wall_su474_800.jpg
            The pocket door algorithm is based on the 1500 series Johnson Hardware Pocket Door Frames:
            Pocket Door Hardware | Johnsonhardware.com | Sliding | Folding | Pocket Door Hardware
            Johnson Hardware Pocket Door Hardware
            (johnsonhardware.com)
            I am not modeling all of the details of the door assembly such as the steel studs or the track and jamb brackets, however I am modeling the prefabricated (wood) frame header assembly.
            View model here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            design.medeek.com
            • medeekM
              medeek
              First look at a 4 Panel Bifold (closet) Door:
              https://aws1.discourse-cdn.com/sketchup/optimized/3X/4/d/4d8702a0145ba9f841dc28c9d4cb304e373ce229_2_688x500.jpeg
              View model here:
              3D Warehouse
              I still need to come up with the 2D symbol at the base of the door and even a more interesting problem is the opening algorithm for this door type.
              The two outer panels are simple, they are merely a rotation just like a standard swing door. The inner panels on the other hand not only rotate but they also translate in relation to the outer panels since a hinge constrains them at that point. I like these kinds of "hard" problems.
              design.medeek.com
              • medeekM
                medeek
                First look at a 4 panel bifold door being opened and closed:
                http://design.medeek.com/resources/wallplugin/images/BF4.gif
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.8.4 - 02.02.2021
                  • Added bifold (4 panel - solid) doors to the door module.
                  http://design.medeek.com/resources/wallplugin/images/wall_su476_800.jpg
                  You can also add a threshold if used as an exterior door however I don't have a lot of options yet for exterior applications (ie. full glass). For now these are primarily for closet doors.
                  You can also switch which side the doors face by choosing LH INT or LH EXT. For the four panel bifold it doesn't matter whether you choose LH or RH, it essentially ignores the handedness of the parameter.
                  I still need to add in the 2 panel variant and then I think we will have most of the basics covered as far as doors are concerned, at least for now. Really exotic stuff will be up to the user to add into a framed opening (which I can provide).
                  The door opening algorithm was a bit more challenging than everything encountered thus far but after a couple of hours tinkering it finally came together.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.8.4b - 02.03.2021
                    • Added bifold (2 panel - solid) doors to the door module.
                    http://design.medeek.com/resources/wallplugin/images/BF2.gif
                    There are four possibilities for a 2 panel bifold door:
                    LH OUT, LH IN, RH OUT, RH IN
                    Whereas there is only two possibilities for a 4 panel bifold door: OUT or IN
                    design.medeek.com
                    • medeekM
                      medeek
                      I think I'm going to the call the "eyedropper" tool the "Copy Wall" tool. One additional icon will be added to the "Medeek Wall Tools" toolbar:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/7/6/761d77044005bf7e5bc8ffd5ab0c833ada679c3f.jpeg
                      I know, I will hear it from everyone about the proliferation of more icons. However, there is an extension out there that allows you to customize the actual toolbars if you feel the need to:
                      SketchUp Extension Warehouse
                      Your library of custom third-party extensions created to optimize your SketchUp workflow.
                      (extensions.sketchup.com)
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.8.5 - 02.07.2021
                        • Enabled the "Wall Copy" tool within the Medeek Wall Tools toolbar.
                        http://design.medeek.com/resources/wallplugin/images/wall_su477_800.jpg
                        Note I've only enabled this tool for rectangular walls. After I am fully confident that it is working well and I've addressed any bugs or issues I will set it up for all the other (gable,shed and hip) wall types.
                        Please try out this new tool and provide any feedback or comments directly to nathan@medeek.com
                        design.medeek.com
                        • medeekM
                          medeek
                          I think the new Copy Wall tool will prove to be quite useful. As I am thinking about it this morning I realized that a similar tool for Doors and Windows would also be quite useful.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.8.5b - 02.08.2021
                            • Fixed a bug with the top plate cut out algorithm when walls meet in a "cross" configuration.
                            http://design.medeek.com/resources/wallplugin/images/CROSS_WALL.gif
                            Each wall teeing into the primary wall has had its corner offset set to 1/2 the thickness of the primary wall.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.8.6 - 02.11.2021
                              • Added the following Simpson Strong-Tie hangers to the beam hanger library: LUS26-2Z, LUS28-2Z, LUS210-2Z.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.8.7 - 02.15.2021
                                • Added an option for the garage door track in the global settings.
                                http://design.medeek.com/resources/wallplugin/images/GARAGE_TRACK.gif
                                Currently you cannot set this parameter per garage door, it can only be set globally (in the Garage Door tab).
                                https://aws1.discourse-cdn.com/sketchup/original/3X/d/6/d6de770ea518f789cfb4231df07ac10520668ee7.jpeg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  I've had a number of people recently ask me for the ability to apply a wood grain texture to the lumber (ie. studs, plates, blocking, etc...) This really isn't a big ask, so I am going to enable another couple parameters in the global settings (Material Tab) so that the user can apply a texture to lumber and pressure treated lumber. Here is a first look at what that will look like (compare the wood grain wall to the solid colored wall):
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/e/8/e8a17a6986f2003f2bf497d25e9b232e8df3ec14.jpeg
                                  I've tried to be very subtle with the wood grain texture so that it approximates my default lumber color but as you can see it is a slightly darker shade. I'm not sure I am entirely happy with it yet but it is a start.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Comparison between the solid coloring and with the textures enabled (Lumber and PT Lumber):
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/6/c/6ce5fcf33db5130d8b3a8dff791296a996723d5c.jpeg
                                    I am quite happy with the way the pressure treated texture came out.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.8.8 - 02.17.2021
                                      • Enabled options for wood grain texture for lumber and pressure treated lumber in the global settings.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su482_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images/wall_su481_800.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.8.9 - 02.22.2021
                                        • Added a "Cedar Siding" built-in material (vertical) into the material library.
                                        http://design.medeek.com/resources/wallplugin/images/wall_su483_800.jpg
                                        http://design.medeek.com/resources/wallplugin/images/wall_su484_800.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.9.0 - 02.24.2021
                                          • Fixed a bug with the end stud height for Shed Walls with an "Inset Outside Corner".
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            mdkBIM Introduction (Japanese - 日本語)
                                            A brief introduction of the mdkBIM bundle in Japanese.
                                            mdkBIMバンドルの日本語での簡単な紹介です。
                                            design.medeek.com
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 80
                                            • 81
                                            • 51 / 81
