    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 713.7k Views 151 Watching
    • fredo6F
      @jweaver100 said:
      Is FredoCorner free for as long as you are happy to keep updating it? Or is the trial period 15 days and after that, you have to buy it?
      The license is to use the extension. After expiration of the free trial period, you need to buy one if you wish to continue using the extension.
      @jweaver100 said:
      I am an occasional user and have just encountered an unexpected problem and its been suggested that this is because I havn't bought it.. And if thats the case I accept that..
      The problem of preselection has nothing to do with the license. FredoCorner would either work or not.
      I suggest you open the Ruby console before launching FredoCorner to see if there are error messages.
        jweaver100
        Cheers. I see this
        Error: #<NoMethodError: undefined method machine_id' for G6B:Module> c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1720:in tem_context'
        c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:751:in activate' c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:194:in select_tool'
        c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:194:in launch' c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:176:in action__mapping'
        c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:129:in call' c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:129:in launch_action'
        c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:227:in launch_action' c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:103:in launch_action'
        c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:118:in block in startup' c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1347:in call'
        c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1347:in command_invoke' c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1328:in block (2 levels) in build_config_commands'
        c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1377:in call' c:/users/jonpw/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1377:in block in add_command'
        SketchUp:1:in `call'
        But as I am out of the evaluation period, its not fair to ask for support... I would have no problem buying FredoCorner if I used it enough.. But I don't and its just not worth it for me..
        Edit: Turned out to be a bigger issue.. Other Fredotools (i.e Fredospine) also not working.. It turns out it was a rogue instance of Sketchup which was running in the background.. Killed the tasks from the taskmanager and now its working again.
          jweaver100
          Now that I have realised that my time with FredoCorner is limited, I need to "evaluate" it to see if there is any functionality that I can find to justify buying it.
          One of the things I have always wondered is whether its possible to do an unsymetrical corner?
          By this, I mean longer on one axis, than another..
          Here is a simulation of what I am trying to explain.
          https://jweaver.tinytake.com/tt/NTA5NzQyM18xNjAwMzM2Nw
          Is this possible?
            Your picture didn't upload.
            Like this?
            Yes. It's possible.
              jweaver100
              Like this?
              [attachment=1:20mh5rlz]<!-- ia1 -->Screenshot - 2_11_2021 , 4_40_29 PM.png<!-- ia1 -->[/attachment:20mh5rlz]
              Yes. It's possible.
              [attachment=0:20mh5rlz]<!-- ia0 -->Screenshot - 2_11_2021 , 4_39_09 PM.png<!-- ia0 -->[/attachment:20mh5rlz]
              Yes.. EXACTLY that.. How? I have pressed every button I can find, and its always symetrical (i.e the Offset is the same on both axis..
                Start the tool and set the initial offset and then click on the green lines that need to get a different offset. Then type that offset. It'll show in the Measurements window.
                Go to the first post of this thread and watch the videos.
                  jweaver100
                  I am such a d***.. I got to this point many times.. And when I clicked on the green line it says "Select other Offset Lines or enter a new offset in the VCB"... And I expected a popup to come up, like it does when you set the "normal" offset.
                  I didn't realise that you just have to type.
                  Makes perfect sense now.. Never even thought to try that before now...
                  • kelly13K
                    kelly13
                    I am from Russia, I do not always understand complicated instructions in English. Explain with simple sentences: "come here, click here .." HOW TO BUY A PLUG-IN LICENSE FOR 3 COMPUTERS
                    I do not need a premium plan for this site "sketchucation.com"
                    I just want to buy a license plagin fredocorner for $ 22
                    please duplicate the answer to my mail: tysha1231@yandex.ru
                    I will translate your answers on google translator
                    where is the buy button?
                    I don't need a premium, I want to buy for $ 22
                    • fredo6F
                      In the main post about Sketchucation License, there is a link to a PDF explaining the whole process (in English).
                      If you have been able to post here in this forum, it means you are already registered on Sketchucation (and I assume you know how to do it, so you can explain it in Russian).
                      For the license of FredoCorner,
                      1 - In Sketchup just go to menu Tools > Fredo6 Collection > FredoCorner > License...
                      2 - In the Licensing dialog box, click on the 'Obtain License Button'.
                      3 - You are redirected to Sketchucation.com to purchase the license
                      4 - Once done, you receive an email with the purchased license file attached. Save it on your computer in a safe place.
                      5 - To activate the license, go to the same licensing dialog and click on 'Validate License'
                      6 - Browse and select the purchased license file which was sent to you by email.
                      7 - This is done.
                      • kelly13K
                        kelly13
                        If you have been able to post here .......
                        7 - This is done.
                        thank you, I was able to buy and install
                        • L
                          LEGOsketcher
                          re: seat limit and licenses
                          God day, I am The LEGO companies Sketchup admin and wonder would like to include the latest Fredocorner release to our plugin collection.
                          The company scripts a SU package with plugins included, Sketchucation should not be part of the basic package as most users won't use the Sketchucation plugins and it adds a level of complexity. Some users might use FredoCorner, most not. (maybe 5 -15 users)
                          I wonder how to best approach the licensing issue as it will be hard administer individual seats / usage. Would that mean I need to install the SUcation plugin and seat license for the users that actually need Fredo corner? I'm also worried about budget for individual seats run up compared to the SU budget. They might ask me to find an alternative if the setup is too complex/time consuming.
                          Will there be something like a studio license so I can avoid individual seats or floating licenses?
                          Feel free to PM me, looking forward to hearing from you
                            mwkinley
                            Loving this plugin but my trial has expired and I can't buy the license...any tips?
                            I have tried uninstalling , restarting , downloading again but of course it remembers the trial version had expired...all I get is this when I click on 'manage license'.
                            Any help greatly appreciated.
                            Matt
                            • fredo6F
                              Could you reinstall the Sketchucation Tools v4.0.0.e.
                              There must be something wrong in its current installation (most likely out of date).
                              Please advise if it does not solve the problem.
                                mwkinley
                                Fixed, thankyou Fredo.
                                I will buy the license now!
                                Regards
                                Matt
                                • B
                                  Buckyman
                                  I am getting Ruby error when I try to round corners.
                                  Can you review the files attached and tell me if it is possible?
                                  The JPG shows the parameters that I need
                                  51140_drain_cap.skp
                                  • fredo6F
                                    The errors comes from the rounding of the upper part and the large offset.
                                    Currently FredoCorner does not round edges when one of the edge has a length smaller than the offset.
                                    So, it works with an offset of 2'', but not beyond.
                                    I am planning to evolve the algorithm to overcome this limitation, but this is quite complex. So, not for an immediate release...
                                    PS: RoundCorner does not do a better job
                                    • B
                                      bsfranza
                                      hey there,
                                      i have a problem, the fredo corner toolbar does not show up?!
                                      in the extension manager its shown, also in sketchucatino licence manager etc, plugin manager, .. its tehre everywhere but i cant get the "toolbar" or menue items to show up?! also removing the plugina and reinstalling from rbz dos not help :I
                                      im running the latest su 2021..
                                      any help much appreciated,
                                      best, bsfranz
                                      • fredo6F
                                        Did you install the companion library LibFredo6?
                                        • B
                                          bsfranza
                                          oh silly me :I .. sorry for stealing your time - i have installed the library now it works as expected...
                                          thx
                                          • B
                                            Buckyman
                                            Yes I did see success with 2", and I did try RoundCorner
                                            Thanks for your quick response and all your great plugins 😄
                                            • 11
                                            • 12
                                            • 13
                                            • 22
                                            • 23
                                            • 11 / 23
