    Can't open skp 2021 file directly
    9 Posts 4 Posters 4.4k Views 4 Watching
    • studio43S Offline
      studio43
      If i try to open a file created in SU 2021 pro I get an error message
      "this file was created in a newer version...."
      I have to open SU 2021 then open file thru it What is the fix for this
      I have reinstalled 2021 as Admin still no good
        When you say you 'installed as admin it's not 100% clear'...
        Here's how it needs to be done/redone...
        Log into Windows as your normal user-account.
        Ensure that SketchUp, Layout etc are closed.
        Find the SketchUp v2021 installer's exe file - usually in your Downloads folder ?
        Select its icon, right-click > context-menu > "Run as administrator"
        When prompted choose "Repair" [or, for a completely new installation, choose "Install"]
        When it completes restart SketchUp...
        Any improvement ?
        Perhaps restart your PC to ensure everything syncs...
        Your user-account having admin-powers is not enough.
        Using 'Run' on a installer's exe file, or double-clicking it is also not the same thing...
        • studio43S Offline
          studio43
          I can open SU from the desktop shortcut. I create and save the file in the project folder but I can only open that file if I open SU from the desktop shortcut then choose the that file.
          Yes I have tried reinstalling as admin. I am on subscription and have the most up to date version
          This same thing happened with the 2020 version, I searched for a solution to the problem back then a luckily found a post someone had a file to download to correct this exact issue. Which they said was a bug with SU2020 message.jpg
            If you open v2021 from its shortcut or from its Program-Files exe, I assume you can open any selected SKP files from within its 'Open' menu item ?
            If you select a SKP file in Windows Explorer and double-click it to open it, then I assume it's trying to use v2020 ??
            If you select a SKP in Windows Explorer and right-click > context-menu do you see a list of possible SketchUp versions to open it ?
            Is v2021 there on the list ?
            And if so, if you select option that does the SKP open OK ??
            PS:
            Please update your profile version from 2013 !
            • studio43S Offline
              studio43
              I can only open a file created in V2021 if I open the program first. If I right click on the v2021 file there is no option in the list to open with v2021. This is exactly the same problem I had with v2020.
              The v2021 file I have created also has the older red SU icon no the new blue icon
              • mogrenM Offline
                mogren
                Same to me and no 2021 it was also same problem on 2020
                No 2021 in contextual menu
                I might have moved my installer so I cannot repair
                • mogrenM Offline
                  mogren
                  I found a solution:
                  download SU 2021
                  open the exe
                  CLICK ON OPTION REPAIR
                  wait until the beast has finished install
                  now you can open normally your 2021 😉
                  All my plugins&co are still there
                  • studio43S Offline
                    studio43
                    Still no luck. I have tried running the repair as admin. No v2021 in right click contextual.
                    I tried deleting v2020 then running repair again. Still can not open a file creating in v2021
                    unless I open the v2021 first via the desktop icon/ shortcut and use "open file"
                      Have you tried associating .skp files with SketchUp 2021?
                      Just a moment...
                      (www.computerhope.com)
