    [Plugin] Material Browser - v1.1.1 - 15 Nov 2025
    51 Posts 10 Posters 33.2k Views 10 Watching
    • judedouchJ Offline
      judedouch
      Thank you for your two above, prompt actions. It’s greatly appreciated.
      judedouch
      • samuel_tS Offline
        samuel_t
        1.0.9 version improves user experience. You don't need anymore to reopen Material Browser UI after you've checked "Display only model materials", etc.
        • E Offline
          EvilBoris
          Amazing!
          Thanks for letting me know you fixed the extension store issue 😄 😄
            Something weird is going on with your extension for some users...
            It's reported over at SketchUp.com
            It seems to be copying/moving its zip.rb and zip folder from your ../Libraries/ subfolder into the Plugin folder.
            First off it looked like SCF toolset doing this, as it has a similar Rubyzip set up, bt it seems to narrow down to you !
            Ideas ??
            https://forums.sketchup.com/t/what-is-zip-in-extension-manager-can-i-uninstall-it/172133
            • samuel_tS Offline
              samuel_t
              My bad. Old versions of material_browser.rbz file include Rubyzip library at root… That’s why there’s a zip.rb file and a zip folder at root of Plugins folder. You can safely uninstall the “zip” library with native Extension Manager. Then, if you want to continue to use Material Browser plugin: upgrade it. New versions of Material Browser plugin include Rubyzip library in a proper way.
              Source: https://forums.sketchup.com/t/what-is-zip-in-extension-manager-can-i-uninstall-it/172133/29
                Thanks for the explanation and the fix...
                  db-3d
                  Is it possible to create a custom filter? I'm doing work for a client that has unique filters for different material types. I have the material library created (over 200 materials) but would like to filter it for specifics like "wall covering", tile wall, tile floor, fabric, concrete, plastic, window film, etc.
                  I want to hand this to the team with the filters the other designers uses and not these defaults.
                  -Daniel Brown: SketchUp & Google Earth Trainer
                  http://db-3d.com: design|modeling|training|consulting
                  • samuel_tS Offline
                    samuel_t
                    If I understand well, you use a custom collection of .skm files?
                    Today, plugin categorizes materials automatically depending on a subtype-type dictionary... For example: "D:\Textures\Floor\Red Marble 02.skm" is categorized automatically in "Stone" because of "Marble" word.
                    Do you think it would be more relevant if plugin categorizes materials depending on filesystem hierarchy? We could filter materials by categories with a classic tree view at left.
                    • samuel_tS Offline
                      samuel_t
                      Next version of Material Browser plugin will support Poly Haven's PBR textures, on SketchUp 2025:
                        Yummy. Great feature to add.
                        • samuel_tS Offline
                          samuel_t
                          Hello,
                          I have the joy to announce availability of Material Browser v1.1.0! ☺️
                          So, what's new in this version?
                          • Poly Haven textures: Access 701 textures made by Poly Haven (formerly Texture Haven).
                          • Photoreal materials: If you use SketchUp 2025-2026, plugin sets all necessary PBR maps for you.
                          • Host acceleration: Material Browser has no more impact on SketchUp startup time! 🚀
                          • Longer SKM caching: Local collections thumbnails are kept until they are outdated or unused.
                          • Polished interface: Colored tooltips, loading screens, etc.
                          • Materials types: Brick is now categorized as Ceramic, more materials are guessed by words.
                          • Link to plugin FAQ: Help is accessible through question mark icon.
                          • Link to donate page: Heart icon opens my Ko-fi page. Consider donating if you like this plugin ❤️
                          • Better integration: Material Browser has finally... a toolbar! 😄
                          • Plugin compatibility: It should be compatible with Fredo6's LordOfTheToolbars plugin.
                          • Cleaner codebase: A lot of code refactoring has been done.
                          Download latest Material Browser plugin from SketchUcation PluginStore.
                            Great update Sam. Thanks for sharing.
                            samuel_tS 1 Reply Last reply Reply Quote 1
                            • samuel_tS Offline
                              samuel_t @Rich O Brien
                              @Rich-O-Brien You're welcome!
                                Material Browser Error
                                Getting this for Polyhaven imports
                                samuel_tS 2 Replies Last reply Reply Quote 0
                                • samuel_tS Offline
                                  @Rich-O-Brien
                                  Thanks for your report. It works on my side. Can you please retry?
                                    Rich O Brien Moderator @samuel_t
                                    @samuel_t Weird there is lots on console errors. In some instances it Sketchucation in others it Material Browsers. I wonder if there's a clash?
                                    @TIG might know more?
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/ioextras.rb:3: warning: already initialized constant Zip::IOExtras::CHUNK_SIZE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras.rb:4: warning: previous definition of CHUNK_SIZE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/ioextras.rb:5: warning: already initialized constant Zip::IOExtras::RANGE_ALL
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/ioextras.rb:6: warning: previous definition of RANGE_ALL was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/entry.rb:4: warning: already initialized constant Zip::Entry::STORED
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/entry.rb:3: warning: previous definition of STORED was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/entry.rb:5: warning: already initialized constant Zip::Entry::DEFLATED
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/entry.rb:4: warning: previous definition of DEFLATED was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/entry.rb:7: warning: already initialized constant Zip::Entry::EFS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/entry.rb:6: warning: previous definition of EFS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/extra_field.rb:3: warning: already initialized constant Zip::ExtraField::ID_MAP
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field.rb:3: warning: previous definition of ID_MAP was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/extra_field/universal_time.rb:4: warning: already initialized constant Zip::ExtraField::UniversalTime::HEADER_ID
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/universal_time.rb:4: warning: previous definition of HEADER_ID was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/extra_field/old_unix.rb:4: warning: already initialized constant Zip::ExtraField::OldUnix::HEADER_ID
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/old_unix.rb:4: warning: previous definition of HEADER_ID was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/extra_field/unix.rb:4: warning: already initialized constant Zip::ExtraField::IUnix::HEADER_ID
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/unix.rb:4: warning: previous definition of HEADER_ID was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/extra_field/zip64.rb:5: warning: already initialized constant Zip::ExtraField::Zip64::HEADER_ID
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/zip64.rb:5: warning: previous definition of HEADER_ID was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/extra_field/zip64_placeholder.rb:6: warning: already initialized constant Zip::ExtraField::Zip64Placeholder::HEADER_ID
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/extra_field/zip64_placeholder.rb:6: warning: previous definition of HEADER_ID was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/central_directory.rb:5: warning: already initialized constant Zip::CentralDirectory::END_OF_CDS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/central_directory.rb:5: warning: previous definition of END_OF_CDS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/central_directory.rb:6: warning: already initialized constant Zip::CentralDirectory::ZIP64_END_OF_CDS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/central_directory.rb:6: warning: previous definition of ZIP64_END_OF_CDS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/central_directory.rb:7: warning: already initialized constant Zip::CentralDirectory::ZIP64_EOCD_LOCATOR
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/central_directory.rb:7: warning: previous definition of ZIP64_EOCD_LOCATOR was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/central_directory.rb:8: warning: already initialized constant Zip::CentralDirectory::MAX_END_OF_CDS_SIZE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/central_directory.rb:8: warning: previous definition of MAX_END_OF_CDS_SIZE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/central_directory.rb:9: warning: already initialized constant Zip::CentralDirectory::STATIC_EOCD_SIZE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/central_directory.rb:9: warning: previous definition of STATIC_EOCD_SIZE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/file.rb:46: warning: already initialized constant Zip::File::CREATE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb:47: warning: previous definition of CREATE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/file.rb:47: warning: already initialized constant Zip::File::SPLIT_SIGNATURE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb:48: warning: previous definition of SPLIT_SIGNATURE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/file.rb:48: warning: already initialized constant Zip::File::ZIP64_EOCD_SIGNATURE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb:49: warning: previous definition of ZIP64_EOCD_SIGNATURE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/file.rb:49: warning: already initialized constant Zip::File::MAX_SEGMENT_SIZE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb:50: warning: previous definition of MAX_SEGMENT_SIZE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/file.rb:50: warning: already initialized constant Zip::File::MIN_SEGMENT_SIZE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb:51: warning: previous definition of MIN_SEGMENT_SIZE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/file.rb:51: warning: already initialized constant Zip::File::DATA_BUFFER_SIZE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/file.rb:52: warning: previous definition of DATA_BUFFER_SIZE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/decompressor.rb:3: warning: already initialized constant Zip::Decompressor::CHUNK_SIZE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/decompressor.rb:3: warning: previous definition of CHUNK_SIZE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:2: warning: already initialized constant Zip::RUNNING_ON_WINDOWS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:2: warning: previous definition of RUNNING_ON_WINDOWS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:4: warning: already initialized constant Zip::CENTRAL_DIRECTORY_ENTRY_SIGNATURE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:4: warning: previous definition of CENTRAL_DIRECTORY_ENTRY_SIGNATURE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:5: warning: already initialized constant Zip::CDIR_ENTRY_STATIC_HEADER_LENGTH
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:5: warning: previous definition of CDIR_ENTRY_STATIC_HEADER_LENGTH was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:7: warning: already initialized constant Zip::LOCAL_ENTRY_SIGNATURE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:7: warning: previous definition of LOCAL_ENTRY_SIGNATURE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:8: warning: already initialized constant Zip::LOCAL_ENTRY_STATIC_HEADER_LENGTH
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:8: warning: previous definition of LOCAL_ENTRY_STATIC_HEADER_LENGTH was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:9: warning: already initialized constant Zip::LOCAL_ENTRY_TRAILING_DESCRIPTOR_LENGTH
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:9: warning: previous definition of LOCAL_ENTRY_TRAILING_DESCRIPTOR_LENGTH was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:10: warning: already initialized constant Zip::VERSION_MADE_BY
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:10: warning: previous definition of VERSION_MADE_BY was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:11: warning: already initialized constant Zip::VERSION_NEEDED_TO_EXTRACT
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:11: warning: previous definition of VERSION_NEEDED_TO_EXTRACT was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:12: warning: already initialized constant Zip::VERSION_NEEDED_TO_EXTRACT_ZIP64
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:12: warning: previous definition of VERSION_NEEDED_TO_EXTRACT_ZIP64 was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:14: warning: already initialized constant Zip::FILE_TYPE_FILE
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:14: warning: previous definition of FILE_TYPE_FILE was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:15: warning: already initialized constant Zip::FILE_TYPE_DIR
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:15: warning: previous definition of FILE_TYPE_DIR was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:16: warning: already initialized constant Zip::FILE_TYPE_SYMLINK
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:16: warning: previous definition of FILE_TYPE_SYMLINK was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:18: warning: already initialized constant Zip::FSTYPE_FAT
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:18: warning: previous definition of FSTYPE_FAT was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:19: warning: already initialized constant Zip::FSTYPE_AMIGA
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:19: warning: previous definition of FSTYPE_AMIGA was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:20: warning: already initialized constant Zip::FSTYPE_VMS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:20: warning: previous definition of FSTYPE_VMS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:21: warning: already initialized constant Zip::FSTYPE_UNIX
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:21: warning: previous definition of FSTYPE_UNIX was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:22: warning: already initialized constant Zip::FSTYPE_VM_CMS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:22: warning: previous definition of FSTYPE_VM_CMS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:23: warning: already initialized constant Zip::FSTYPE_ATARI
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:23: warning: previous definition of FSTYPE_ATARI was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:24: warning: already initialized constant Zip::FSTYPE_HPFS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:24: warning: previous definition of FSTYPE_HPFS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:25: warning: already initialized constant Zip::FSTYPE_MAC
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:25: warning: previous definition of FSTYPE_MAC was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:26: warning: already initialized constant Zip::FSTYPE_Z_SYSTEM
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:26: warning: previous definition of FSTYPE_Z_SYSTEM was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:27: warning: already initialized constant Zip::FSTYPE_CPM
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:27: warning: previous definition of FSTYPE_CPM was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:28: warning: already initialized constant Zip::FSTYPE_TOPS20
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:28: warning: previous definition of FSTYPE_TOPS20 was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:29: warning: already initialized constant Zip::FSTYPE_NTFS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:29: warning: previous definition of FSTYPE_NTFS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:30: warning: already initialized constant Zip::FSTYPE_QDOS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:30: warning: previous definition of FSTYPE_QDOS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:31: warning: already initialized constant Zip::FSTYPE_ACORN
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:31: warning: previous definition of FSTYPE_ACORN was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:32: warning: already initialized constant Zip::FSTYPE_VFAT
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:32: warning: previous definition of FSTYPE_VFAT was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:33: warning: already initialized constant Zip::FSTYPE_MVS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:33: warning: previous definition of FSTYPE_MVS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:34: warning: already initialized constant Zip::FSTYPE_BEOS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:34: warning: previous definition of FSTYPE_BEOS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:35: warning: already initialized constant Zip::FSTYPE_TANDEM
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:35: warning: previous definition of FSTYPE_TANDEM was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:36: warning: already initialized constant Zip::FSTYPE_THEOS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:36: warning: previous definition of FSTYPE_THEOS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:37: warning: already initialized constant Zip::FSTYPE_MAC_OSX
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:37: warning: previous definition of FSTYPE_MAC_OSX was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:38: warning: already initialized constant Zip::FSTYPE_ATHEOS
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:38: warning: previous definition of FSTYPE_ATHEOS was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/constants.rb:40: warning: already initialized constant Zip::FSTYPES
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/constants.rb:40: warning: previous definition of FSTYPES was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/errors.rb:12: warning: already initialized constant Zip::ZipError
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb:10: warning: previous definition of ZipError was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/errors.rb:13: warning: already initialized constant Zip::ZipEntryExistsError
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb:11: warning: previous definition of ZipEntryExistsError was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/errors.rb:14: warning: already initialized constant Zip::ZipDestinationFileExistsError
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb:12: warning: previous definition of ZipDestinationFileExistsError was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/errors.rb:15: warning: already initialized constant Zip::ZipCompressionMethodError
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb:13: warning: previous definition of ZipCompressionMethodError was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/errors.rb:16: warning: already initialized constant Zip::ZipEntryNameError
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb:14: warning: previous definition of ZipEntryNameError was here
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/material_browser/Libraries/zip/errors.rb:17: warning: already initialized constant Zip::ZipInternalError
                                    C:/Users/rclub/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/SketchUcation/Data/Rubyzip/zip/errors.rb:15: warning: previous definition of ZipInternalError was here
                                    The above occurs whe starting Sketchup.
                                    samuel_tS 1 Reply Last reply Reply Quote 0
                                    • samuel_tS Offline
                                      @Rich-O-Brien It's because our plugins use same library: Rubyzip.
                                      This duplication causes warnings you see in Ruby console.
                                      Shouldn't impact features...
                                        @samuel_t
                                        Issue persists at the moment...
                                        What is strange is that recently we encounter an error unzipping with Sketchucation Tools 5 that was related to IPv6.
                                        Not sure if this is similar just sharing as much info as I can.
                                          This looks like a great tool Samuel. Unfortunately I'm not seeing a way to use the textures from it. I am not seeing the error message Rich shows but clicking on a material doesn't seem to do anything unless the material is already in the local Materials folder. This is also with SU2026 on Windows 11.
                                            Same in v2023
                                            • 2 / 3
