    Foundation Plugin
    441 Posts 15 Posters 445.0k Views 15 Watching
    • medeekM Offline
      medeek
      After giving this suggestion some additional thought:
      https://aws1.discourse-cdn.com/sketchup/original/3X/f/d/fdd7d73095b533bf57d74a1ef859a2e0c99f0def.jpeg
      I think I will introduce two additional parameters for stemwall foundations which will make them more applicable for use as retaining walls in foundation design.
      The two parameters will be:
      Ftg. Bar Development: None, Hook, Full Ext., Full Int.
      Ftg. Offset: 0.0 in (default)
      Currently footings are drawn symmetrically with respect to the foundation wall, this will enable the user to offset the footing in or out (+/-).
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.6.1 - 08.31.2020
        • Added a footing offset parameter to polyline stemwalls.
        • Enabled options for 90 deg. footing hooks for vertical rebar in polyline stemwall.
        http://design.medeek.com/resources/foundationplugin/images/foundation_su67_800.jpg
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.6.2 - 10.09.2020
          • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
          http://design.medeek.com/resources/foundationplugin/images/foundation_su68_800.jpg
          design.medeek.com
          • jujuJ Offline
            juju
            your website isn't reflecting the new version yet
            • medeekM Offline
              medeek
              It should be showing version 1.6.2 now.
              design.medeek.com
              • jujuJ Offline
                juju
                not yet, and I did press "F5" so the page would load fresh
                • medeekM Offline
                  medeek
                  Try it now.
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    @medeek said:
                    Try it now.
                    working now πŸ‘
                    • medeekM Offline
                      medeek
                      Version 1.6.3 - 10.22.2020
                      • Fixed a bug in the strip footing "Outline" edit menu.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.6.4 - 01.11.2021
                        • Added the option for post bases for the (Post & Beam) Interior Bearing tool: BC40, BC60.
                        http://design.medeek.com/resources/foundationplugin/images/foundation_su69_800.jpg
                        Post base hardware added per customer request.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.6.4b - 01.14.2021
                          • Added the following additional post bases to the Interior Bearing tool: ABU44, ABU66.
                          http://design.medeek.com/resources/foundationplugin/images/foundation_su70_800.jpg
                          Two additional post bases added per customer request.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            When the foundation segment lengths in a polyline stemwall foundation are too short this is what you get (notice the anchor bolt placement):
                            https://aws1.discourse-cdn.com/sketchup/original/3X/b/a/ba1443b0e345add3c636dbc40bc9ded984787e76.jpeg
                            I'm working up some additional logic to properly deal with anchor bolt placement with short segment lengths.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.6.5 - 02.09.2021
                              • Fixed a bug with anchor bolt placement for polyline stemwalls.
                              • Added an option for a zero depth footing for polyline stemwalls, which eliminates the footing for this foundation type.
                              http://design.medeek.com/resources/foundationplugin/images/foundation_su72_800.jpg
                              By setting the depth of the footing to zero you can eliminate the footing from a polyline stemwall, so only the stemwall portion of the foundation is drawn. This is per customer request.
                              Also the algorithm for anchor bolt placement for polyline stemwalls is greatly improved, however there can always be further improvements, any feedback is always appreciated.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.6.6 - 02.12.2021
                                • Added logic to the final assembly routine to allow for electrical components (Medeek Electrical) to be retained within all foundation assemblies.
                                http://design.medeek.com/resources/foundationplugin/images/foundation_su73_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.6.7 - 03.07.2021
                                  • Fixed a bug with brick ledges (and drain pipe) for slab-on-grade foundations.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.6.8 - 03.14.2021
                                    • Standardized the naming convention of the plugin toolbars.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.6.9 - 03.25.2021
                                      • Fixed a bug with footing offsets when a (polyline) stemwall terminates non-orthogonally.
                                      http://design.medeek.com/resources/foundationplugin/images/foundation_su76_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.6.9b - 03.26.2021
                                        • Fixed a bug with footing extensions (polyline stemwalls) for SketchUp Pro 2021.
                                        • Enabled hidden edges for polyline stemwalls that terminate non-orthogonally.
                                        http://design.medeek.com/resources/foundationplugin/images/foundation_su77_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          First look at a hole cut using the new SUBTRACT keyword system:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/f/c/fcfa3a82d747e94b0e665eed71592e96d3eaa409.jpeg
                                          Now I just need to set this up for the other various foundation types (ie. stemwall, stemwall steps, strip footings etc...)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.7.0 - 05.09.2021
                                            • Added an option for subtractive geometry into the General tab of the Global Settings.
                                            • Sub-groups within foundations and footings can be made persistent and "subtractive" by naming these groups to (subtract1, subtract2, subtract3, etc...)
                                            http://design.medeek.com/resources/foundationplugin/images/foundation_su78_800.jpg
                                            http://design.medeek.com/resources/foundationplugin/images/foundation_su80_800.jpg
                                            Interestingly the code to make this happen was staring me in the face for months. I essentially took the "roof connections" complex roof module, changed up the logic slightly, simplified it, and arrived at this new feature/ability.
                                            Notice that the subtractive groups cut through the rebar as well as the concrete. Certain other elements such as anchor bolts (groups within groups) are not removed. I may need to give this some additional consideration.
                                            I guess we need to make this new feature available with the Truss plugin as well now.
                                            design.medeek.com
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
