    Foundation Plugin
    451 Posts 15 Posters 614.6k Views 15 Watching
    • medeekM
      medeek
      Version 1.5.7 - 03.04.2020
      • Updated the polyline stemwall draw tool to terminate (point selection) with the "Enter" key instead of the down arrow.
      • Updated the strip footing draw tool to terminate (point selection) with the "Enter" key instead of the down arrow.
      I've never been really happy with using the down arrow as the termination key for the polyline stemwall and strip footing tools, it was always a placeholder until I could figure out how to use the Enter key instead. I've now enabled the plugin so that the Enter/Return key can be used. I have not disabled the down arrow key so actually either can be used at this time but eventually I will remove the down arrow key so that only the enter key will terminate point selection for the two draw tools.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I’m utilizing key code 36 for MacOS, however I need to verify that this is actually working for everyone as it should. If you are using the Foundation plugin on a Mac please download this latest version and let me know if the Enter key will now allow you to terminate a polyline stemwall.
        design.medeek.com
        • medeekM
          medeek
          After some further testing I think I will switch from the Enter key to the End key to terminate point selection. The problem with using the Enter key is that it conflicts with the manual entry of a segment length.
          design.medeek.com
          • medeekM
            medeek
            Version 1.5.7b - 03.05.2020
            • Updated the polyline stemwall draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
            • Updated the strip footing draw tool to terminate (point selection) with the "End" key instead of the "Enter" key.
            For now the point selection termination will be either the down arrow or the "End" key. Using the "Enter" key causes a conflict when the user is manual entering a dimension for a segment length (key in the dimension and then click enter). Until I can figure out how to resolve this conflict this will be the key assignment for terminating both polyline stemwall and strip footings.
            design.medeek.com
            • medeekM
              medeek
              Version 1.5.7c - 03.05.2020
              • Added the "Enter" key method to the strip footing and polyline stemwall draw tools for point selection termination.
              After a couple of tries I think I've finally got it right now. One should be able to use the Enter/Return key to terminate point selection as well as still use the down arrow (for users who are in the habit of using the down arrow now). I apologize on the back and forth on this fix, sometimes things just don't go as smoothly as planned.
              design.medeek.com
              • medeekM
                medeek
                Version 1.5.8 - 04.27.2020
                • Added a Global Reset button in the General tab of the Global Settings.
                • Plugin files switched from .rbs to .rbe encryption.
                http://design.medeek.com/resources/trussplugin/images/truss_su690_800.jpg
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.5.9 - 05.15.2020
                  • Fixed a bug when the Auto Assign Materials parameter was turned off.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.6.0 - 05.28.2020
                    • Added a footing concrete layer in the Global Settings under the "Layers" tab.
                    • Fixed a bug for metric templates with the strip footing tool and the polyline stemwall tool.
                    https://design.medeek.com/resources/foundationplugin/images/foundation_su66_800.jpg
                    Note, that if you want the footing concrete layer to remain the same as the rest of the foundation (ie. stemwall) you can always assign it to the same layer name: "fnd_conc"
                    Also note, that any and all of these layer names are user configurable, the names shown are just default names I have assigned, the user can utilized their own naming convention that suites their workflow.
                    design.medeek.com
                    • medeekM
                      medeek
                      After giving this suggestion some additional thought:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/f/d/fdd7d73095b533bf57d74a1ef859a2e0c99f0def.jpeg
                      I think I will introduce two additional parameters for stemwall foundations which will make them more applicable for use as retaining walls in foundation design.
                      The two parameters will be:
                      Ftg. Bar Development: None, Hook, Full Ext., Full Int.
                      Ftg. Offset: 0.0 in (default)
                      Currently footings are drawn symmetrically with respect to the foundation wall, this will enable the user to offset the footing in or out (+/-).
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.6.1 - 08.31.2020
                        • Added a footing offset parameter to polyline stemwalls.
                        • Enabled options for 90 deg. footing hooks for vertical rebar in polyline stemwall.
                        http://design.medeek.com/resources/foundationplugin/images/foundation_su67_800.jpg
                        View model here:
                        3D Warehouse
                        (3dwarehouse.sketchup.com)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.6.2 - 10.09.2020
                          • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
                          http://design.medeek.com/resources/foundationplugin/images/foundation_su68_800.jpg
                          design.medeek.com
                          • jujuJ
                            juju
                            your website isn't reflecting the new version yet
                            • medeekM
                              medeek
                              It should be showing version 1.6.2 now.
                              design.medeek.com
                              • jujuJ
                                juju
                                not yet, and I did press "F5" so the page would load fresh
                                • medeekM
                                  medeek
                                  Try it now.
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    @medeek said:
                                    Try it now.
                                    working now 👍
                                    • medeekM
                                      medeek
                                      Version 1.6.3 - 10.22.2020
                                      • Fixed a bug in the strip footing "Outline" edit menu.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.6.4 - 01.11.2021
                                        • Added the option for post bases for the (Post & Beam) Interior Bearing tool: BC40, BC60.
                                        http://design.medeek.com/resources/foundationplugin/images/foundation_su69_800.jpg
                                        Post base hardware added per customer request.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.6.4b - 01.14.2021
                                          • Added the following additional post bases to the Interior Bearing tool: ABU44, ABU66.
                                          http://design.medeek.com/resources/foundationplugin/images/foundation_su70_800.jpg
                                          Two additional post bases added per customer request.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            When the foundation segment lengths in a polyline stemwall foundation are too short this is what you get (notice the anchor bolt placement):
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/b/a/ba1443b0e345add3c636dbc40bc9ded984787e76.jpeg
                                            I'm working up some additional logic to properly deal with anchor bolt placement with short segment lengths.
                                            design.medeek.com
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
