    [New Plugin] Windows Builder
    28 Posts 18 Posters 25.2k Views 18 Watching
    • pbacotP
      I'm surprised I missed this. Looks great! Thank you for sharing!
      • utilerU
        utiler
        Wow that's quite a plugin!!!
        Just Curious...
        • K
          kenancakir
          Thank you, for this usefull plugin..
          • E
            eallard
            Hi, I'm trying to see the other images but they aren't available...
              Which other images? I don't see that there are any missing ones.
              • jujuJ
                juju
                @didier bur said:
                Thanks for all your feedback 😉
                @juju: nice ideas, i'll work on these asap
                Didier, have you been able to spend some time with this yet?
                • Didier BurD
                  Didier Bur
                  Hi Juju,
                  I wish I had the time to enhance Windows Builder (and LOD Labels plugin too), but I'm busy on SU/Twinmotion projects for a couple of months now. I'll be back on Ruby coding asap 😉
                  DB
                  • jujuJ
                    juju
                    @didier bur said:
                    Hi Juju,
                    ... enhance Windows Builder (and LOD Labels plugin too) ... I'll be back on Ruby coding asap
                    You just brought tears to my eyes, thanks for your valued support of the SU Extensions and community! 👍
                      ajmwd
                      This looks like a great extension! I am running SU Pro 2017. When I try to install this extension from the Extension Warehouse it says "This extension is marked as being not compatible with your Operating System or SketchUp Version. Proceed anyway?".
                      Is this extension incompatible with SU Pro 2017? Extension Warehouse shows "Compatibility: SketchUp 2016."
                      Any clarification from anybody using this extension would appreciate. Thanks!
                        You could try it an see what happens. Very often the compatibility list is slow to be updated if it is at all.
                        • Didier BurD
                          Didier Bur
                          Windows Builder is compatible with SU2017 (Make and Pro).
                          Regards,
                          DB
                          • G
                            Glenn at home
                            I'm probably doing something wrong but I can't get it to cut the opening. Do walls have to be grouped? I've tried both ways.
                            TIA
                            • Didier BurD
                              Didier Bur
                              Hi Glenn
                              It works in both cases.
                              First example shows that "Cuts opening" and "punch window" both work on a regular face of a wall, and second example shows that only "punch window" works if the wall is a group.
                              But it will work OK if the context is the group (if you are within the group when launching WB)
                              Regards,
                              DB
                              • G
                                Glenn at home
                                Thanks Didier, I’ll give it another try. 😄
                                • K
                                  Koffi
                                  merci de m'aider a avoir ce logiciel
                                  Didier BurD 1 Reply Last reply
                                  • Didier BurD
                                    Didier Bur @Koffi
                                    @Koffi
                                    You can get it here: https://extensions.sketchup.com/extension/381166fa-6fe4-4b07-9303-5ff922533bfa/windows-builder
                                    DB
                                    • C
                                      criba
                                      It seems the Windows Builder is not working in Skethcup 2024.
                                      Is there a newer version or a workaround?
                                      Dave RD 1 Reply Last reply
                                        Dave R @criba
                                        @criba there are a number of other extensions for making windows. Look here at the Sketchucation ExtensionStore and in the SketchUp Extension Warehouse.
                                        You might also look at the 3D Warehouse. Loads of window components available there. Many of them are dynamic.
                                          diseño
                                          hhola nos podrías ayudar con la actualizacipon de windows builder para la version sketchup 2024 . gracias
                                            Ahmadsl12 Newcomers
                                            when I download its says "This extension is marked as being not compatible with your Operating System or SketchUp Version. Proceed anyway? "
                                            any how after installation plugin appear but when i put values and press create nothing (no window available) how to fix
