    [New Plugin] Windows Builder
    28 Posts 18 Posters 25.2k Views 18 Watching
      New but copious! ๐Ÿ˜Ž
        dtrarch
        Didier
        You really started it all with your copious and special plugins to make Sketchup so complete.
        Thank you so very much for all of your efforts.
        Respect and super to see you still with new ideas and help to us all.
        dtrarch
          rv1974
          So feature rich tool, thank you so much!
          Is it possible to add in the future:
          1. some pin button to keep settings window open
          2. right frame texturizing. The texture of material will be alighed in accordance the longest edge of the element (horizontal\vertical). Obviously, it'd demand to split window frame to horizontal\vertical parts.
            Thank you once again
          • srxS
            srx
            Thank you for this wonderful present.
            Making holes in grouped geometry...Can it be done?
            www.saurus.rs
            • Didier BurD
              Didier Bur
              Thanks for all your feedback ๐Ÿ˜‰
              @srx: if you mean creating a hole for a window in a wall made of grouped geometry, yes you can. Just select the window and click the right-most icon of the toolbar.
              @juju: nice ideas, i'll work on these asap
              DB
              • pbacotP
                I'm surprised I missed this. Looks great! Thank you for sharing!
                • utilerU
                  utiler
                  Wow that's quite a plugin!!!
                  Just Curious...
                  • K
                    kenancakir
                    Thank you, for this usefull plugin..
                    • E
                      eallard
                      Hi, I'm trying to see the other images but they aren't available...
                        Which other images? I don't see that there are any missing ones.
                        • jujuJ
                          juju
                          Didier, have you been able to spend some time with this yet?
                          • Didier BurD
                            Didier Bur
                            Hi Juju,
                            I wish I had the time to enhance Windows Builder (and LOD Labels plugin too), but I'm busy on SU/Twinmotion projects for a couple of months now. I'll be back on Ruby coding asap ๐Ÿ˜‰
                            DB
                            • jujuJ
                              juju
                              @didier bur said:
                              Hi Juju,
                              ... enhance Windows Builder (and LOD Labels plugin too) ... I'll be back on Ruby coding asap
                              You just brought tears to my eyes, thanks for your valued support of the SU Extensions and community! ๐Ÿ‘
                                ajmwd
                                This looks like a great extension! I am running SU Pro 2017. When I try to install this extension from the Extension Warehouse it says "This extension is marked as being not compatible with your Operating System or SketchUp Version. Proceed anyway?".
                                Is this extension incompatible with SU Pro 2017? Extension Warehouse shows "Compatibility: SketchUp 2016."
                                Any clarification from anybody using this extension would appreciate. Thanks!
                                  You could try it an see what happens. Very often the compatibility list is slow to be updated if it is at all.
                                  • Didier BurD
                                    Didier Bur
                                    Windows Builder is compatible with SU2017 (Make and Pro).
                                    Regards,
                                    DB
                                    • G
                                      Glenn at home
                                      I'm probably doing something wrong but I can't get it to cut the opening. Do walls have to be grouped? I've tried both ways.
                                      TIA
                                      • Didier BurD
                                        Didier Bur
                                        Hi Glenn
                                        It works in both cases.
                                        First example shows that "Cuts opening" and "punch window" both work on a regular face of a wall, and second example shows that only "punch window" works if the wall is a group.
                                        But it will work OK if the context is the group (if you are within the group when launching WB)
                                        Regards,
                                        DB
                                        • G
                                          Glenn at home
                                          Thanks Didier, Iโ€™ll give it another try. ๐Ÿ˜„
                                          • K
                                            Koffi
                                            merci de m'aider a avoir ce logiciel
                                            Didier BurD 1 Reply Last reply
