    [New Plugin] Windows Builder
    28 Posts 18 Posters 25.2k Views 18 Watching
    • Didier BurD
      Didier Bur
      Hi Juju,
      I wish I had the time to enhance Windows Builder (and LOD Labels plugin too), but I'm busy on SU/Twinmotion projects for a couple of months now. I'll be back on Ruby coding asap šŸ˜‰
      DB
      • jujuJ
        juju
        @didier bur said:
        Hi Juju,
        ... enhance Windows Builder (and LOD Labels plugin too) ... I'll be back on Ruby coding asap
        You just brought tears to my eyes, thanks for your valued support of the SU Extensions and community! šŸ‘
          ajmwd
          This looks like a great extension! I am running SU Pro 2017. When I try to install this extension from the Extension Warehouse it says "This extension is marked as being not compatible with your Operating System or SketchUp Version. Proceed anyway?".
          Is this extension incompatible with SU Pro 2017? Extension Warehouse shows "Compatibility: SketchUp 2016."
          Any clarification from anybody using this extension would appreciate. Thanks!
            You could try it an see what happens. Very often the compatibility list is slow to be updated if it is at all.
            • Didier BurD
              Didier Bur
              Windows Builder is compatible with SU2017 (Make and Pro).
              Regards,
              DB
              • G
                Glenn at home
                I'm probably doing something wrong but I can't get it to cut the opening. Do walls have to be grouped? I've tried both ways.
                TIA
                • Didier BurD
                  Didier Bur
                  Hi Glenn
                  It works in both cases.
                  First example shows that "Cuts opening" and "punch window" both work on a regular face of a wall, and second example shows that only "punch window" works if the wall is a group.
                  But it will work OK if the context is the group (if you are within the group when launching WB)
                  Regards,
                  DB
                  • G
                    Glenn at home
                    Thanks Didier, I’ll give it another try. šŸ˜„
                    • K
                      Koffi
                      merci de m'aider a avoir ce logiciel
                      Didier BurD 1 Reply Last reply
                      • Didier BurD
                        Didier Bur @Koffi
                        @Koffi
                        You can get it here: https://extensions.sketchup.com/extension/381166fa-6fe4-4b07-9303-5ff922533bfa/windows-builder
                        DB
                        • C
                          criba
                          It seems the Windows Builder is not working in Skethcup 2024.
                          Is there a newer version or a workaround?
                          Dave RD 1 Reply Last reply
                            Dave R @criba
                            @criba there are a number of other extensions for making windows. Look here at the Sketchucation ExtensionStore and in the SketchUp Extension Warehouse.
                            You might also look at the 3D Warehouse. Loads of window components available there. Many of them are dynamic.
                              diseƱo
                              hhola nos podrĆ­as ayudar con la actualizacipon de windows builder para la version sketchup 2024 . gracias
                                Ahmadsl12 Newcomers
                                when I download its says "This extension is marked as being not compatible with your Operating System or SketchUp Version. Proceed anyway? "
                                any how after installation plugin appear but when i put values and press create nothing (no window available) how to fix
                                With your input, this post could be even better šŸ’—
                                • 2 / 2
