    Remove Unused Edges
    5 Posts 3 Posters 3.3k Views 3 Watching
    • Gus RG Offline
      Gus R
      Testing out SketchUp Pro 2021 and was wondering where "Remove Unused Edges" under the "Edit" menu went. Been using SketchUp 2017.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • BoxB Offline
        That must be an extension, certainly not a default tool.
          You might want to have a look at Thom Thom's CleanUp3. It can clean up more than just unneeded edges.
          • Gus RG Offline
            Gus R
            That was it, thanks. It's a 15 year old ruby named "cleanup_model.rb" that's in my 2017 plugins directory. Got used to using it. I basically copy and pasted my SU 8 plugins directory into the the SU 2017 plugins directory. I thought it was a default plugin because it was under "edit."
            The good news is it works in SU 2021.
            • Gus RG Offline
              Gus R
              Thanks. Installed that (which I've used on 2017) before finding the old ruby. "Erase Stray Edges" works the same way.
              So far installing plugins in SU 2021 has been relative a piece of cake. Including the payware without even having to re-register any licenses.
