Remove Unused Edges
Testing out SketchUp Pro 2021 and was wondering where "Remove Unused Edges" under the "Edit" menu went. Been using SketchUp 2017.
That must be an extension, certainly not a default tool.
You might want to have a look at Thom Thom's CleanUp3. It can clean up more than just unneeded edges.
That was it, thanks. It's a 15 year old ruby named "cleanup_model.rb" that's in my 2017 plugins directory. Got used to using it. I basically copy and pasted my SU 8 plugins directory into the the SU 2017 plugins directory. I thought it was a default plugin because it was under "edit."
The good news is it works in SU 2021.
Thanks. Installed that (which I've used on 2017) before finding the old ruby. "Erase Stray Edges" works the same way.
So far installing plugins in SU 2021 has been relative a piece of cake. Including the payware without even having to re-register any licenses.
