    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • medeekM Offline
      medeek
      Version 1.7.1 - 11.15.2020
      • Added additional HSS and Wide Flange Beam options to the free standing column (post) tool.
      http://design.medeek.com/resources/wallplugin/images/wall_su433_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.7.2 - 11.16.2020
        • Added the ability to create custom "Shiplap" wall cladding materials within the Material Library.
        • Enabled "3D" Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
        http://design.medeek.com/resources/wallplugin/images/wall_su434_800.jpg
        http://design.medeek.com/resources/wallplugin/images/wall_su435_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          View example model of 3D shiplap here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • medeekM Offline
            medeek
            Medeek Wall Plugin Tutorial 17 - Tag/Layer Folders:
            View model here:
            3D Warehouse
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.7.3 - 11.20.2020
              • Fixed a bug with zero height gable, shed and hip walls when using the "No Framing" or "CMU" mode.
              • Fixed a minor bug with man door and garage door jambs with walls panels that are isolated in groups.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.7.4 - 11.21.2020
                • Completed the "Garage Doors" tab within the Global Settings.
                http://design.medeek.com/resources/wallplugin/images/wall_su436_800.jpg
                Some more slightly tedious code, but necessary.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.7.4b - 11.22.2020
                  • Completed the "SSW" tab within the Global Settings.
                  http://design.medeek.com/resources/wallplugin/images/wall_su437_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.7.4c - 11.22.2020
                    • Completed the "Beams" tab within the Global Settings.
                    • Fixed a critical bug with the default settings for the following two window parameters: Jamb Ext. Reveal, Shim Gap.
                    http://design.medeek.com/resources/wallplugin/images/wall_su438_800.jpg
                    ***** CRITICAL BUG FIX *****
                    When you first load the plugin it sets default parameters for walls, door, windows etc...
                    A previous update introduced a typo into the code which incorrectly set the two window parameters listed above. This update corrects those two typos. It is highly recommended to update to the latest version of the plugin.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.7.4d - 11.23.2020
                      • Completed the "Columns" tab within the Global Settings.
                      http://design.medeek.com/resources/wallplugin/images/wall_su439_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        We’ve all had a trying year these last few months but somehow, thanks to our customers, we’ve managed to keep up the good fight and are still actively developing our extensions here at Medeek Design.
                        In recognition of the overwhelming support I have received from the SketchUp community these last few months I will be immediately offering 40% off of the mdkBIM bundle price using the coupon code GIVETHANKS20. (ends Dec. 1, 2020).
                        This will reduce the bundle price from $170.00 USD to $102.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer also ends on Dec. 1 and no rain checks will issued thereafter.
                        https://aws1.discourse-cdn.com/sketchup/original/3X/e/6/e65c772c8d42bd77b622f2dae3749fc6d310a6f8.jpeg
                        design.medeek.com
                        • Gus RG Offline
                          Gus R
                          Sold!
                          This is a great suite.
                          www.instagram.com/gusrobatto/
                          www.facebook.com/gusrobatto
                          • medeekM Offline
                            medeek
                            Version 1.7.5 - 11.25.2020
                            • Updated the Global Settings Reset button with additional parameters.
                            • Fixed multiple minor bugs with the default settings (storage) for Doors, Windows and Garage Doors.
                            design.medeek.com
                            • Gus RG Offline
                              Gus R
                              Nathaniel,
                              I have a question.
                              Does right mouse button "Edit Truss Assembly" work with a "Truss Assembly?"
                              • medeekM Offline
                                medeek
                                @gus r said:
                                Nathaniel,
                                I have a question.
                                Yes, but not every type of truss assembly is editable yet. The most common are but I am still working on quite a few of them.
                                design.medeek.com
                                • Gus RG Offline
                                  Gus R
                                  OK, I tried with all three and I can't edit any of them.
                                  Stepdown, northeast and terminal.
                                  I just tested the 3 using default settings.
                                  @medeek said:
                                  @gus r said:
                                  Nathaniel,
                                  I have a question.
                                  Truss Assembly Test.skp
                                  • medeekM Offline
                                    medeek
                                    This should be moved to the Truss Plugin thread but correct the hip sets are not yet editable. Common trusses and other truss types are see details here:
                                    404 - File or directory not found.
                                    (design.medeek.com)
                                    Enter a Ctrl-F and then search for the term "edit". This will show you which assemblies have had the edit function enabled.
                                    design.medeek.com
                                    • Gus RG Offline
                                      Gus R
                                      OK, thanks.
                                      (design.medeek.com)
                                      • medeekM Offline
                                        medeek
                                        I have some questions about double wall construction lately.
                                        I don't have a specific double wall algorithm however it is possible to create double wall structures with openings using the Wall plugin in its current state, see model below for an example:
                                        3D Warehouse
                                        P.S. Note how the window ext. trim and installation is enabled on the exterior wall and then the interior casing is enabled on the interior wall. I then adjusted the casing extension depth in the edit menu of the interior wall so that it extends to meet the window in the exterior wall. No manual editing and everything is still parametric.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.7.6 - 12.04.2020
                                          • Added a wall justification hotkey/option (Tab key) to the rectangular draw wall tool: Front, Center, Back.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su440_800.jpg
                                          Note, that when the wall justification is set to "Center" or "Back" the draw tool switches from polyline mode to simple line mode, this is by design.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.7.6b - 12.05.2020
                                            • Added a wall justification hotkey/option (Tab key) to the gable, shed and hip draw wall tools: Front, Center, Back.
                                            • Enabled the left and right arrow keys for each of the draw wall tools in order to constrain the tool to the X or Y axis.
                                            http://design.medeek.com/resources/wallplugin/images/wall_su441_800.jpg
                                            The behavior of the draw wall tool is now similar to the native SketchUp line/edge tool.
                                            The right and left arrow keys will constrain the wall to the X and/or Y axis. Additionally the Ctrl key will toggle the wall to the 45 deg. and 135 deg. directions. You will notice that when the constraint is active the primary line will indicate either Red, Green, Blue (45 deg) or Purple (135 deg) and the line thickness will increase from two to three.
                                            design.medeek.com
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 79
                                            • 80
                                            • 48 / 80
