    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      First look at a 3D batten cladding on rectangular walls:
      https://aws1.discourse-cdn.com/sketchup/original/3X/4/3/43c2627535449580d6c8f37caca2fe9e0d50f446.jpeg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Some more screenshots of battens:
        https://aws1.discourse-cdn.com/sketchup/original/3X/2/1/21870ccdede52556701ee38a76e6bbed69957400.jpeg
        https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cd9b943b4178a81693faadcb8252543bd40938e.jpeg
        https://aws1.discourse-cdn.com/sketchup/original/3X/3/e/3efd578cb0ad1f8b9a3e216118cabb4f0e3ef85e.jpeg
        *Notice the format of the batten material and its three numeric values within the name of the material.
        design.medeek.com
        • medeekM
          medeek
          Texture vs. 3D Battens:
          https://aws1.discourse-cdn.com/sketchup/original/3X/9/b/9b14475c2c73f7239e17a162176a26833f8aeed5.gif
          Personally I prefer the texture myself, lower poly and it looks just as good or better than the real deal.
          design.medeek.com
          • medeekM
            medeek
            Version 1.6.9 - 10.17.2020
            • Added the ability to create custom "Board and Batten" wall cladding materials within the Material Library.
            • Enabled "3D" Board and Batten wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
            http://design.medeek.com/resources/wallplugin/images/wall_su432_800.jpg
            For the plugin to recognize the wall cladding material as a "board and batten" material is must be in this format:
            battens_{decimal value}{decimal value}{decimal_value}
            The three values are: batten spacing, batten width, batten depth respectively.
            There should be no white spaces inserted into the name, only the underscore character in three places as shown.
            design.medeek.com
            • medeekM
              medeek
              Another view of board and battens:
              https://aws1.discourse-cdn.com/sketchup/original/3X/e/7/e7d8baa965a4ae4dae412d16c7bc98c1ac5da9d8.jpeg
              Just over five years into programming these plugins, I released the first version of the Truss plugin Oct. 7, 2015.
              The further I go it seems like I just keep coming up with more things "todo". I really need to take myself and clone me about five times and then set each clone at developing the various plugins, maybe then I might get somewhere with all of this.
              design.medeek.com
              • medeekM
                medeek
                Version 1.7.0 - 10.23.2020
                • Fixed a bug in the Walls tab of the Global Settings.
                design.medeek.com
                • medeekM
                  medeek
                  The Medeek Wall plugin (and mdkBIM) was featured in this 3D Basecamp Fireside Chat:
                  Crowdcast
                  Where the world gathers
                  Crowdcast (www.crowdcast.io)
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.7.1 - 11.15.2020
                    • Added additional HSS and Wide Flange Beam options to the free standing column (post) tool.
                    http://design.medeek.com/resources/wallplugin/images/wall_su433_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.7.2 - 11.16.2020
                      • Added the ability to create custom "Shiplap" wall cladding materials within the Material Library.
                      • Enabled "3D" Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                      http://design.medeek.com/resources/wallplugin/images/wall_su434_800.jpg
                      http://design.medeek.com/resources/wallplugin/images/wall_su435_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        View example model of 3D shiplap here:
                        3D Warehouse
                        design.medeek.com
                        • medeekM
                          medeek
                          Medeek Wall Plugin Tutorial 17 - Tag/Layer Folders:
                          View model here:
                          3D Warehouse
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.7.3 - 11.20.2020
                            • Fixed a bug with zero height gable, shed and hip walls when using the "No Framing" or "CMU" mode.
                            • Fixed a minor bug with man door and garage door jambs with walls panels that are isolated in groups.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.7.4 - 11.21.2020
                              • Completed the "Garage Doors" tab within the Global Settings.
                              http://design.medeek.com/resources/wallplugin/images/wall_su436_800.jpg
                              Some more slightly tedious code, but necessary.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.7.4b - 11.22.2020
                                • Completed the "SSW" tab within the Global Settings.
                                http://design.medeek.com/resources/wallplugin/images/wall_su437_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.7.4c - 11.22.2020
                                  • Completed the "Beams" tab within the Global Settings.
                                  • Fixed a critical bug with the default settings for the following two window parameters: Jamb Ext. Reveal, Shim Gap.
                                  http://design.medeek.com/resources/wallplugin/images/wall_su438_800.jpg
                                  ***** CRITICAL BUG FIX *****
                                  When you first load the plugin it sets default parameters for walls, door, windows etc...
                                  A previous update introduced a typo into the code which incorrectly set the two window parameters listed above. This update corrects those two typos. It is highly recommended to update to the latest version of the plugin.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.7.4d - 11.23.2020
                                    • Completed the "Columns" tab within the Global Settings.
                                    http://design.medeek.com/resources/wallplugin/images/wall_su439_800.jpg
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      We’ve all had a trying year these last few months but somehow, thanks to our customers, we’ve managed to keep up the good fight and are still actively developing our extensions here at Medeek Design.
                                      In recognition of the overwhelming support I have received from the SketchUp community these last few months I will be immediately offering 40% off of the mdkBIM bundle price using the coupon code GIVETHANKS20. (ends Dec. 1, 2020).
                                      This will reduce the bundle price from $170.00 USD to $102.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer also ends on Dec. 1 and no rain checks will issued thereafter.
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/e/6/e65c772c8d42bd77b622f2dae3749fc6d310a6f8.jpeg
                                      design.medeek.com
                                      • Gus RG
                                        Gus R
                                        Sold!
                                        This is a great suite.
                                        www.instagram.com/gusrobatto/
                                        www.facebook.com/gusrobatto
                                        • medeekM
                                          medeek
                                          Version 1.7.5 - 11.25.2020
                                          • Updated the Global Settings Reset button with additional parameters.
                                          • Fixed multiple minor bugs with the default settings (storage) for Doors, Windows and Garage Doors.
                                          design.medeek.com
                                          • Gus RG
                                            Gus R
                                            Nathaniel,
                                            I have a question.
                                            Does right mouse button "Edit Truss Assembly" work with a "Truss Assembly?"
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 80
                                            • 81
                                            • 48 / 81
