    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      Version 1.6.6 - 09.15.2020
      • Fixed a bug with Tyvek and ZIP Systems sheathing when the sheathing is lapped at the corners (rectangular walls only).
      http://design.medeek.com/resources/wallplugin/images/wall_su425_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.6.7 - 09.26.2020
        • Added additional tool tips to the Wall Corners tab of the Global Settings.
        http://design.medeek.com/resources/wallplugin/images/wall_su426_800.jpg
        I've been fielding a lot of questions recently about the corner offset parameter and related wall end/corner conditions. I may need to still provide additional documentation and diagrams to further clarify these parameters.
        design.medeek.com
        • medeekM
          medeek
          Version 1.6.8 - 09.28.2020
          • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
          http://design.medeek.com/resources/wallplugin/images/wall_su427_800.jpg
          Previously when you renewed your license you would need to go through some convoluted steps to refresh you license data within the plugin. This new feature reduces this process to a single mouse click.
          Previously the required steps were:
          1.) Remove the existing serial number.
          2.) Click the Save Settings button.
          3.) Re-enter your serial number.
          4.) Click the Save Settings button again.
          5.) Restart SketchUp.
          design.medeek.com
          • medeekM
            medeek
            First look at a 3D batten cladding on rectangular walls:
            https://aws1.discourse-cdn.com/sketchup/original/3X/4/3/43c2627535449580d6c8f37caca2fe9e0d50f446.jpeg
            View model here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            design.medeek.com
            • medeekM
              medeek
              Some more screenshots of battens:
              https://aws1.discourse-cdn.com/sketchup/original/3X/2/1/21870ccdede52556701ee38a76e6bbed69957400.jpeg
              https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cd9b943b4178a81693faadcb8252543bd40938e.jpeg
              https://aws1.discourse-cdn.com/sketchup/original/3X/3/e/3efd578cb0ad1f8b9a3e216118cabb4f0e3ef85e.jpeg
              *Notice the format of the batten material and its three numeric values within the name of the material.
              design.medeek.com
              • medeekM
                medeek
                Texture vs. 3D Battens:
                https://aws1.discourse-cdn.com/sketchup/original/3X/9/b/9b14475c2c73f7239e17a162176a26833f8aeed5.gif
                Personally I prefer the texture myself, lower poly and it looks just as good or better than the real deal.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.6.9 - 10.17.2020
                  • Added the ability to create custom "Board and Batten" wall cladding materials within the Material Library.
                  • Enabled "3D" Board and Batten wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                  http://design.medeek.com/resources/wallplugin/images/wall_su432_800.jpg
                  For the plugin to recognize the wall cladding material as a "board and batten" material is must be in this format:
                  battens_{decimal value}{decimal value}{decimal_value}
                  The three values are: batten spacing, batten width, batten depth respectively.
                  There should be no white spaces inserted into the name, only the underscore character in three places as shown.
                  design.medeek.com
                  • medeekM
                    medeek
                    Another view of board and battens:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/e/7/e7d8baa965a4ae4dae412d16c7bc98c1ac5da9d8.jpeg
                    Just over five years into programming these plugins, I released the first version of the Truss plugin Oct. 7, 2015.
                    The further I go it seems like I just keep coming up with more things "todo". I really need to take myself and clone me about five times and then set each clone at developing the various plugins, maybe then I might get somewhere with all of this.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.7.0 - 10.23.2020
                      • Fixed a bug in the Walls tab of the Global Settings.
                      design.medeek.com
                      • medeekM
                        medeek
                        The Medeek Wall plugin (and mdkBIM) was featured in this 3D Basecamp Fireside Chat:
                        Crowdcast
                        Where the world gathers
                        Crowdcast (www.crowdcast.io)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.7.1 - 11.15.2020
                          • Added additional HSS and Wide Flange Beam options to the free standing column (post) tool.
                          http://design.medeek.com/resources/wallplugin/images/wall_su433_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.7.2 - 11.16.2020
                            • Added the ability to create custom "Shiplap" wall cladding materials within the Material Library.
                            • Enabled "3D" Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                            http://design.medeek.com/resources/wallplugin/images/wall_su434_800.jpg
                            http://design.medeek.com/resources/wallplugin/images/wall_su435_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              View example model of 3D shiplap here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM
                                medeek
                                Medeek Wall Plugin Tutorial 17 - Tag/Layer Folders:
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.7.3 - 11.20.2020
                                  • Fixed a bug with zero height gable, shed and hip walls when using the "No Framing" or "CMU" mode.
                                  • Fixed a minor bug with man door and garage door jambs with walls panels that are isolated in groups.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.7.4 - 11.21.2020
                                    • Completed the "Garage Doors" tab within the Global Settings.
                                    http://design.medeek.com/resources/wallplugin/images/wall_su436_800.jpg
                                    Some more slightly tedious code, but necessary.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.7.4b - 11.22.2020
                                      • Completed the "SSW" tab within the Global Settings.
                                      http://design.medeek.com/resources/wallplugin/images/wall_su437_800.jpg
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.7.4c - 11.22.2020
                                        • Completed the "Beams" tab within the Global Settings.
                                        • Fixed a critical bug with the default settings for the following two window parameters: Jamb Ext. Reveal, Shim Gap.
                                        http://design.medeek.com/resources/wallplugin/images/wall_su438_800.jpg
                                        ***** CRITICAL BUG FIX *****
                                        When you first load the plugin it sets default parameters for walls, door, windows etc...
                                        A previous update introduced a typo into the code which incorrectly set the two window parameters listed above. This update corrects those two typos. It is highly recommended to update to the latest version of the plugin.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.7.4d - 11.23.2020
                                          • Completed the "Columns" tab within the Global Settings.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su439_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            We’ve all had a trying year these last few months but somehow, thanks to our customers, we’ve managed to keep up the good fight and are still actively developing our extensions here at Medeek Design.
                                            In recognition of the overwhelming support I have received from the SketchUp community these last few months I will be immediately offering 40% off of the mdkBIM bundle price using the coupon code GIVETHANKS20. (ends Dec. 1, 2020).
                                            This will reduce the bundle price from $170.00 USD to $102.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer also ends on Dec. 1 and no rain checks will issued thereafter.
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/e/6/e65c772c8d42bd77b622f2dae3749fc6d310a6f8.jpeg
                                            design.medeek.com
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 80
                                            • 81
                                            • 47 / 81
