    New to DC: topic for my simple questions to the pros
    Scheduled Pinned Locked Moved Dynamic Components
    74 Posts 3 Posters 73.3k Views 3 Watching
    • P
      pibuz
      It's me again!
      I'm struggling since a couple days about one thing I think should be doable but I can't get in any way
      to work in my DC.
      Basically I have a wall, made of two side pillars and a series of panels in the middle. My wall can be stretched to match some precise measures, which I set. The measures are exact multiples of the panels but may also admit an half-panel on the end, if needed.
      When I stretch the wall, the start pillar must stay still (works now), the end pillar must reach the final point (works now) and in the middle I want the panel to copy a number of times. It works when I fix the length of the panels to a value, but I'm not able to tell SketchUp that it must stretch the last panel to half its dimension if needed.
      Do you guys know a way to do that? Thanks in advance!!!
      sistema Arty_v3.skp
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • P
        pcmoor
        To work out the number divide the opening by the whole door size and convert to integer
        To get the remainder take this number times the size from opening
        For door lenx, use condition if remainder then the last copy (= copies) is to be remainder
        There were some issues with the geometry and scaling, first applied lenX to two faces, then had to make a group of the edges so that it obeyed the formula rather than its natural scale
        made outline to size to opening, added some copy function to the support
        sistema Arty_v3.skp
        • P
          pibuz
          Thanks a lot pc!!! I'll have a look at it immediately!
          EDIT
          Everything is clear, I don't understand the syntax of these two formulas though:
          =parete Arty!d_mod_num-1 +if(parete Arty!remain,1,0)
          Here I don't understand the space between "-1" and "+if" and I don't know the meaning of the "parete Arty!remain" without any checks to perform.
          =if(and(parete Arty!remain,copy=copies),parete Arty!remain,98)
          Here I don't understand the meaning of "parete Arty!remain" without any checks: what will it solve into?
          MANY MANY THANKS!
          • P
            pcmoor
            The condition is either true or false, 0 or any negative number is read as false whereas any positive number is true.
            A bit of a short cut in logic.
            The space is not required for mathematical functions, just there for my own readability
            • P
              pibuz
              I have a new question for the community: I have an attribute which ALWAYS include alternatively the words "OPACO" "LUCIDO" or "SEMILUCIDO" (name of the material applied). The words are always at the end of the text string, but the number of digits before may change.
              I want another attribute to report ONLY the occuring word from case to case.
              EG: my material attribute returns "grey RAL7040 OPACO", I want another attribute to report only "OPACO".
              Is there a way to do this?
              • K
                kostiaarh
                try so: =RIGHT(Material, 5)
                • P
                  pibuz
                  Thanks Kostiaarh!
                  Sadly this formula returns always the last 5 characters, while the number of letters I have to report varies from 5, 6 and 10 digits.
                  • P
                    pcmoor
                    You can use find with the item to be found included in the text to avoid the error , and test if the result is within the length of the original text
                    Note that semi is placed before in the conditional statements otherwise will not be selected
                    using find without error.skp
                    • P
                      pibuz
                      wonderful! Thanks!!
                      • P
                        pibuz
                        hi guys! I have a new question: I have a DC which features a choice between type1 and type2. I'd like to have an hyperlink to a pdf showing the technical specs of each choice, so I uploaded both pdfs to an S3 amazon server to have get a valid url.
                        Is there a way I can insert the <a href> tag inside a formula, so that the hyperlink changes based on the type1/type2 choice?
                        condiz. monoblocco Gazebo.skp.zip
                        • P
                          pcmoor
                          I am using 2018. however can see problem when referencing in a formula, a suggestion is to put the pages in the value section of the options list
                          web page options.skp
                          • P
                            pibuz
                            As always, thanks a lot!
                            • P
                              pibuz
                              Hi all you DCs experts!
                              I have one silly question: for several reasons, the most complex DCs I have made make themselves unique after a simple copy of the original instance. Given the fact that I have to further investigate why this happens in specific cases, would it be possible to write a plugin which searches all the instances of the same DC and substitutes the identical copies with one single component?
                              • P
                                pcmoor
                                Any DC with nested DC(s) will become unique on a redraw, so I recommend using the definition name as a category rather than an identity, and use the instance name or a custom attribute as the identity. the #number is not considered, the reports "group by" is the instance or custom attribute.
                                If you simplify a DC so its nested components are not dynamic, then the definition #number will remain, so one could consider a method of simplification via a script as a possible solution depending on the DCs concerned.
                                Although you could script a swap for same, that "same" would have to be a simple DC with no nested DCs as the uniqueness would only be triggered again if there is a redraw
                                • P
                                  pibuz
                                  thanks Phil! Completely understood! Thank you!
                                  • P
                                    pibuz
                                    Sorry to bother again...
                                    I have another tricky question: I have issues trying to report attributes assigned to COPIES of the original instance. I mean: the fields areactually correclty compiled but the native reporting tool keeps only the result of the "original" instance.
                                    I attach my component (which I'm particularly proud of, maybe naively...).
                                    You can spot the issue, for example, if you change the size of the main component eg to 150x100cm. In this case I replicate the inner "Riser_strutt.quadrotta", and the copy is resized to 100x50. If you now enter the component you will see that the copy of the original instance has a "COMP_FIN" attribute changed to 50x100 (dimensions of the tile after the copy).
                                    If I generate report using the "8_PRELIEVO" template, I get a quantity of 2 on the string of "quadrotta truciolare Riser", and the "comp_fin" field still reports "100x100".
                                    Is there a way I can make this work? or is it impossible?
                                    In this second case, my solution would be NOT to modify the copy of the original instance but instead include an invisible pre-set 100x50 component, appearing in the right places(s) when needed... Could this work?
                                    THANKS A LOT IN ADVANCE!
                                    pedana Riser struttura.skp
                                    • P
                                      pcmoor
                                      It has been reported that modified DC copies do not list in the writer, however still no fix, probably unlikely now LCs are the flavor, so we wait while they re-event the wheel instead of fixing thats broken or out of round...
                                      https://forums.sketchup.com/t/generate-report-does-not-include-component-copies/80600 (2 years)
                                      I believe this your best option, plus a 50x50
                                      • P
                                        pibuz
                                        Thanks a lot, as usual.
                                        I ask you a personal opinion: do you think that the trimble team will dismiss the Dynamic Component system? I've writtena whole load of them..... 😢 😢 😢
                                        • P
                                          pcmoor
                                          You should be proud, you have grasp the technical challenges of a relative difficult scripting language and now adding you own spin on it. This is what is going to help you adapt and improve whatever the future changes are.
                                          It is clear that LCs is where the development is, hardwired and web savvy.
                                          DCs will still be around for 5 years but likely, as before, no development'
                                          We intend to launch authoring tools for Live Components sometime next year. Being able to author Live Components is just the beginning though. Those apps/tools will expand over the next several years to offer new ways of modeling in conjunction with SketchUp.
                                          Introducing a new kind of SketchUp object: Live Components
                                          Today, we are extremely pleased to introduce a new type of configurable object for SketchUp: Live Components. Live Components are built on Materia, a new modeling platform that aims to deliver smart 3D content to Trimble…
                                          SketchUp Community (forums.sketchup.com)
                                          I understand they acquired the concept
                                          https://forums.sketchup.com/t/introducing-a-new-kind-of-sketchup-object-live-components/139815/33
                                          I would agree with Dan on the period ahead...
                                          The Dynamic Components extension has not had any new features for many many years, and will (most likely) not get any more. SketchUp team has said this before. There are too many extensions (some Trimble) that now rely upon the DCs to remain as they are.
                                          It has also been like ā€œpulling teethā€ to get errors in the Dynamic Components extension fixed. I do hope (and politic) for all existing easily fixed errors in DC code to be fixed, before it is ā€œretiredā€ to an optional extension.
                                          So, it is most likely [speculating] that the Dynamic Components extension would be ā€œfrozenā€ at some version, and thereafter remain as such in the Extension Warehouse as an optional extension. (Ie, it may no longer be distributed as a ā€œdefaultā€ extension with the SketchUp installer. But [speculating] this is not likely to happen for several major cycles until after Live Components is mature enough.)
                                          LiveComponents vs. DynamicComponents
                                          So far I do not see a big difference between Live Components (LCs) and Dynamic components (DC). DCs can react on a click event, so that when clicked on them, an action is performed on the component and they can be scaled…
                                          • P
                                            pibuz
                                            Hi again! I've encontered a critical misfunction, I'm posting this in the hope someone can help me figure out how to dodge this.
                                            In the file I attach there's a panel. If I copy the panel, select both copies and change the length, both component react correctly BUT the formulas contained in the last 3 top-level attribute rows are deleted, substituted by their value as fixed number.
                                            What can cause this?
                                            And secondary: is there a way to apply a certain DC configuration to another DC of the same "family"?
                                            Thanks in advance!
                                            EDIT
                                            Found another user's post showing same issue. Seems to be related to the attribute state set to "User can see". Thanks!
                                            auto-erasing formulas.zip
                                            With your input, this post could be even better šŸ’—
