    New to DC: topic for my simple questions to the pros
    Scheduled Pinned Locked Moved Dynamic Components
    74 Posts 3 Posters 70.7k Views 3 Watching
    • P
      pcmoor
      see the link to topic
      403 Forbidden
      (sketchucation.com)
      • P
        pibuz
        thanks Moor!
        Sorry, but maybe I misexplained what I need, I'm attaching an example.
        In this case I'd like that if I rename the component to whatever else, I get the new name in the Option dialog title. At the moment, this wont' happen: it keeps titling "elemento da prelevare_shell".
        190913_template prelievo da magazzino.skp
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • P
          pcmoor
          you can use the component instance name to give each instance an unique name which is reflected in all the dialog, which is the natural inbuilt way
          otherwise set
          Name = _name
          in the DC then
          use a button from the toolbar extension to fire the code snippet to alter the _name attribute, which reads the current definition name, updates the original name to update the option dialog
          • P
            pibuz
            Sorry Moor, I don't understand. In the file I sent you, if I change the Instance name of "elemento da prelevare_shell" NOTHNG CHANGES in any window...
            • P
              pcmoor
              saveas the DC to a folder then bring it into another file, for some reason it does not initially work within its created file, after that, should work, regardless of the number of changes, the references are still maintained
              • P
                pibuz
                OH BIG THANKS! I WAS MISSING THE FACT THAT IT DOESN'T WOTK ON THE ORIGINAL FILE!
                • P
                  pibuz
                  Hi again! is there a way I can LOCK the rotation of a DC along specific axis'?
                  I have a panel which I don't want users to be able to use as ceiling, so I only want it to be rotateable along its blue axis
                  • P
                    pibuz
                    It's me again!
                    I'm struggling since a couple days about one thing I think should be doable but I can't get in any way
                    to work in my DC.
                    Basically I have a wall, made of two side pillars and a series of panels in the middle. My wall can be stretched to match some precise measures, which I set. The measures are exact multiples of the panels but may also admit an half-panel on the end, if needed.
                    When I stretch the wall, the start pillar must stay still (works now), the end pillar must reach the final point (works now) and in the middle I want the panel to copy a number of times. It works when I fix the length of the panels to a value, but I'm not able to tell SketchUp that it must stretch the last panel to half its dimension if needed.
                    Do you guys know a way to do that? Thanks in advance!!!
                    sistema Arty_v3.skp
                    • P
                      pcmoor
                      To work out the number divide the opening by the whole door size and convert to integer
                      To get the remainder take this number times the size from opening
                      For door lenx, use condition if remainder then the last copy (= copies) is to be remainder
                      There were some issues with the geometry and scaling, first applied lenX to two faces, then had to make a group of the edges so that it obeyed the formula rather than its natural scale
                      made outline to size to opening, added some copy function to the support
                      sistema Arty_v3.skp
                      • P
                        pibuz
                        Thanks a lot pc!!! I'll have a look at it immediately!
                        EDIT
                        Everything is clear, I don't understand the syntax of these two formulas though:
                        =parete Arty!d_mod_num-1 +if(parete Arty!remain,1,0)
                        Here I don't understand the space between "-1" and "+if" and I don't know the meaning of the "parete Arty!remain" without any checks to perform.
                        =if(and(parete Arty!remain,copy=copies),parete Arty!remain,98)
                        Here I don't understand the meaning of "parete Arty!remain" without any checks: what will it solve into?
                        MANY MANY THANKS!
                        • P
                          pcmoor
                          The condition is either true or false, 0 or any negative number is read as false whereas any positive number is true.
                          A bit of a short cut in logic.
                          The space is not required for mathematical functions, just there for my own readability
                          • P
                            pibuz
                            I have a new question for the community: I have an attribute which ALWAYS include alternatively the words "OPACO" "LUCIDO" or "SEMILUCIDO" (name of the material applied). The words are always at the end of the text string, but the number of digits before may change.
                            I want another attribute to report ONLY the occuring word from case to case.
                            EG: my material attribute returns "grey RAL7040 OPACO", I want another attribute to report only "OPACO".
                            Is there a way to do this?
                            • K
                              kostiaarh
                              try so: =RIGHT(Material, 5)
                              • P
                                pibuz
                                Thanks Kostiaarh!
                                Sadly this formula returns always the last 5 characters, while the number of letters I have to report varies from 5, 6 and 10 digits.
                                • P
                                  pcmoor
                                  You can use find with the item to be found included in the text to avoid the error , and test if the result is within the length of the original text
                                  Note that semi is placed before in the conditional statements otherwise will not be selected
                                  using find without error.skp
                                  • P
                                    pibuz
                                    wonderful! Thanks!!
                                    • P
                                      pibuz
                                      hi guys! I have a new question: I have a DC which features a choice between type1 and type2. I'd like to have an hyperlink to a pdf showing the technical specs of each choice, so I uploaded both pdfs to an S3 amazon server to have get a valid url.
                                      Is there a way I can insert the <a href> tag inside a formula, so that the hyperlink changes based on the type1/type2 choice?
                                      condiz. monoblocco Gazebo.skp.zip
                                      • P
                                        pcmoor
                                        I am using 2018. however can see problem when referencing in a formula, a suggestion is to put the pages in the value section of the options list
                                        web page options.skp
                                        • P
                                          pibuz
                                          As always, thanks a lot!
                                          • P
                                            pibuz
                                            Hi all you DCs experts!
                                            I have one silly question: for several reasons, the most complex DCs I have made make themselves unique after a simple copy of the original instance. Given the fact that I have to further investigate why this happens in specific cases, would it be possible to write a plugin which searches all the instances of the same DC and substitutes the identical copies with one single component?
                                            • 3 / 4
