    FFmpeg: Instructions for download and Install
    renderpluginsextensions
    46 Posts 24 Posters 127.7k Views 24 Watching
      jstahlman
      The download link is not working. I found a version that works here https://ffmpeg.org/download.html#build-mac
      • fredo6F
        Thanks for signaling. It seems that the hosting site Zeranoe has closed on 18 Sep 2020.
        There seems to be alternative sites. I'll check and update the documentation.
        • kimgaK
          kimga
          Thank you very much for the ANIMATOR and for the FFmpeg.
          I am just trying to generate my first video, but after completing all the instruction bove I still only get a folder with images instead of a video in the selected format.
          I downloaded the latest WINDOW compatible FFmpeg, unzipped, copied the ffmpeg.exe to the PLUGIN folder and located it within ANIMATOR. Then I restarted the computer. After all that I tried to generate the video I already set up before all this process. It showed the pictures and a text file in the folder, but when I pressed save and exit the images did disappear and the only thing left is an "FFmpeg_log_mp4" file.
          Any suggestions, what could have gone wrong, please?
          Cheers
          • fredo6F
            Strange...
            Did you regenerate the video after you installed FFmpeg?
            • kimgaK
              kimga
              I tried and tried over the last week. Re-installed the plugin many times, restarted the computer and set up a new film and movement.
              Unfortunately, the outcome is the same. The window shows all the possible formats once the FFmpeg file is located. Starts to generate the imagines into the folder. And at the end, when pressing the "save and finish" - or something similar on the bottom-right corner of the window, all the image files would disappear from the folder, no video is created at all and only the above mentioned txt file left behind....
              Couldn`t figure what can be the problem.
              I am planning to buy a new computer, workstation for Christmas. I will try if it works then.
              Thank you for trying to help.
              Cheers,
              • fredo6F
                @kimga
                At the end of the generation, do you see a 'black' window appearing for a few seconds (this is the FFmpeg video stitching).
                Also, in the folder, there is a text file, FFmpeg_log.text. Could you look into it and see there is an error, or post it here or PM it to me.
                • C
                  cleatus269
                  i get the same error. i can navigate to the folder while the video is generating and see the images stacking up, but once it completes the render and i hit save and exit, the ENTIRE folder is empty. no txt files, no images, nothing. just an empty folder and another 2hrs wasted... please help. i have already missed my deadline once and would like to meet the next one.
                  thanks
                    sistemasIPS
                    What is the updated link to download the file corresponding to win64?
                      sistemasIPS
                      After successfully installing (I think) the ffmpeg, I get an error when exporting, in any format:
                      "error in the video file generation"
                      This is the file that the program generates:
                      ffmpeg version n4.3.1-20-g8a2acdc6da Copyright (c) 2000-2020 the FFmpeg developers
                      built with gcc 9.3-win32 (GCC) 20200320
                      configuration: --prefix=/ffbuild/prefix --pkg-config-flags=--static --pkg-config=pkg-config --cross-prefix=x86_64-w64-mingw32- --arch=x86_64 --target-os=mingw32 --enable-gpl --enable-version3 --disable-debug --enable-iconv --enable-zlib --enable-libxml2 --enable-libfreetype --enable-libfribidi --enable-gmp --enable-lzma --enable-fontconfig --enable-opencl --enable-libvmaf --disable-vulkan --enable-libvorbis --enable-amf --enable-libaom --enable-avisynth --enable-libdav1d --enable-libdavs2 --enable-ffnvcodec --enable-cuda-llvm --disable-libglslang --enable-libass --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvpx --enable-libwebp --enable-libmfx --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librav1e --enable-schannel --enable-sdl2 --enable-libsoxr --enable-libsrt --enable-libtwolame --enable-libvidstab --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libzimg --extra-cflags=-DLIBTWOLAME_STATIC --extra-cxxflags= --extra-ldflags=-pthread --extra-libs=-lgomp
                      libavutil 56. 51.100 / 56. 51.100
                      libavcodec 58. 91.100 / 58. 91.100
                      libavformat 58. 45.100 / 58. 45.100
                      libavdevice 58. 10.100 / 58. 10.100
                      libavfilter 7. 85.100 / 7. 85.100
                      libswscale 5. 7.100 / 5. 7.100
                      libswresample 3. 7.100 / 3. 7.100
                      libpostproc 55. 7.100 / 55. 7.100
                      [image2 @ 000001cab0794640] Could find no file with path 'Image%02d.png' and index in the range 0-4
                      Image%02d.png: No such file or directory
                      • P
                        PeterThistle
                        I am having a similar issue as the above, after following the instructions I am only getting a Text Document named 'FFmpeg_log_mp4'
                        Below is the what is in the text file, any help would be great thanks!
                        ffmpeg version N-99816-g3da35b7cc7 Copyright (c) 2000-2020 the FFmpeg developers
                        configuration: --prefix=/ffbuild/prefix --pkg-config-flags=--static --pkg-config=pkg-config --cross-prefix=x86_64-w64-mingw32- --arch=x86_64 --target-os=mingw32 --enable-version3 --disable-debug --enable-iconv --enable-zlib --enable-libxml2 --enable-libfreetype --enable-libfribidi --enable-gmp --enable-lzma --enable-fontconfig --enable-opencl --enable-libvmaf --disable-vulkan --enable-libvorbis --enable-amf --enable-libaom --disable-avisynth --enable-libdav1d --disable-libdavs2 --enable-ffnvcodec --enable-cuda-llvm --disable-libglslang --enable-libass --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvpx --enable-libwebp --enable-libmfx --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librav1e --disable-librubberband --enable-schannel --enable-sdl2 --enable-libsoxr --enable-libsrt --enable-libsvtav1 --enable-libtwolame --enable-libuavs3d --disable-libvidstab --disable-libx264 --disable-libx265 --disable-libxavs2 --disable-libxvid --enable-libzimg --extra-cflags=-DLIBTWOLAME_STATIC --extra-cxxflags= --extra-ldflags=-pthread --extra-libs=-lgomp
                        libavutil 56. 60.100 / 56. 60.100
                        libavcodec 58.112.100 / 58.112.100
                        libavformat 58. 64.100 / 58. 64.100
                        libavdevice 58. 11.102 / 58. 11.102
                        libavfilter 7. 88.100 / 7. 88.100
                        libswscale 5. 8.100 / 5. 8.100
                        libswresample 3. 8.100 / 3. 8.100
                        Input #0, image2, from 'Image%03d.png':
                        Duration: 00:00:34.04, start: 0.000000, bitrate: N/A
                        Stream #0:0: Video: png, rgb24(pc), 1916x929 [SAR 3780:3780 DAR 1916:929], 25 fps, 25 tbr, 25 tbn, 25 tbc
                        Unknown encoder 'libx264'
                        • fredo6F
                          Did you install a recent version of FFmpeg? or which date and version (maybe, on the contrary, it is too recent).
                          For whatever reason, it seems to disable the encode which is precisely needed for MP4 file.
                          • P
                            PeterThistle
                            Thanks for your help so far
                            The zip file I extracted the FFmpeg.exe from was "ffmpeg-N-99818-g993429cfb4-win64-lgpl"
                            after re-downloading and extracting it I now see all the stills in the animator videos file, the black window does appear at the end of the the generation but I am still getting just a text file in the animator video file. I don't know if it's different from before but below is what is in the file...
                            ffmpeg version N-99818-g993429cfb4 Copyright (c) 2000-2020 the FFmpeg developers
                            Stream #0:0: Video: png, rgb24(pc), 1632x929 [SAR 3780:3780 DAR 1632:929], 25 fps, 25 tbr, 25 tbn, 25 tbc
                            • fredo6F
                              @PeterThistle
                              I don't know what's going on with the recent versions of FFmpeg, but some seem to not include the right codec libraries. Apparently this is the case with the zip file you downloaded.
                              Could you try this one, which is with Fulllibraries at this link. I tested it on my laptop Win10-6 and it works. The file size of FFmpeg.exe is 105 Mb.
                              https://www.gyan.dev/ffmpeg/builds/ffmpeg-release-full.7z
                              More generally there is a mess in how the builds of FFmpeg are now released. I cannot find older versions. I need to have a closer look to how to have robust instructions.
                                jayhuss9
                                i am only getting a mp4.txt file once animating my video. any ideas how i can get the mp4 will be much appreciated.
                                • fredo6F
                                  See the post just above. It may depend on which version of FFmpeg you downloaded.
                                  • Bryan KB
                                    Just downloaded both Animator and FFmpeg. Played with it just enough to make sure it works.
                                    Looking forward to using it fully.
                                    Thanks for the fantastic plug ins!
                                      jhandgraaf
                                      Hi all,
                                      I have installed the ffmpeg on my mac but I still get the permission denied file after rendering it. I can't seem to locate in the system preferences where to authorise it? Nothing is mentioning ffmpeg?
                                      Thanks in advance, Jerry
                                      • fredo6F
                                        @jhandgraaf said:
                                        Hi all,
                                        It's normally in the Security panel...
                                        • Q
                                          quillpro
                                          Working on a MAC (OS 11) and when I try to save a movie. The video generation dialog builds all the frames but does not change once it shows 100%. The resulting folder shows all the png's. But the log file reads...
                                          sh: /Applications/ffmpeg: Permission denied
                                          If I click the "Interrupt" button it moves to next screen and when I click Save and Exit the png's disappear and just the log file is left showing the permissions error.
                                          Also the only options for format I can choose is MPG4 or Image sequence.
                                          • Q
                                            quillpro
                                            @jhandgraaf said:
                                            Hi all,
                                            Did this ever get resolved?
                                            • 1 / 3
