    Animation lost when exiting Animation tool
    renderpluginsextensions
    25 Posts 6 Posters 16.2k Views 6 Watching
    • fredo6F Offline
      @jonorman said:
      Hope i have done it right, added a GIF for observation πŸ˜„
      Useful. thanks.
      For the Undo, I mean the Sketchup Undo in the Edit menu of Sketchup.
        jonorman
        Good Morning Fredo..
        Nope, the undo menu does not have any save data to undo πŸ˜„ Attaced a screendump, and it is the same allwaays, no mather what I do..
        • fredo6F Offline
          I mean Create the animation, Save it from within Animator (so blue disk turns gray) and check the Sketchup Undo label/tooltip.
          By the way, could you type the folloiwng command in the Ruby Console:
          Sketchup.active_model.path
          This should return the file path name of the SKP or nothing.
            jonorman
            Hope I`v done it right now πŸ˜„ Same result as before πŸ˜•
            • fredo6F Offline
              It's a little bit of a mystery!!
              I think I have to send you a special version of Animator with traces to see what is going on.
              Could you PM me your email address, as the rbz file is above the 2 Mb.
              By the way, could you also check in Tools > Fredo6 Collection > Animator > Default_parameters.... that you have set up the auto-save.
              Thank you very much
                jonorman
                Autosave and confirm Temp exit both checked. Will send you a PM later on..
                Thank you πŸ˜„
                  sigasiempre
                  Was this issue solved? My issue is similar. Movements and cameras I put in disappear when I re-open the file?
                    jonorman
                    Nope, not yet... Current conclusion is my computer is "Haunted" and filled with Gremlins.. Ha ha ha ha ha πŸ˜„
                    • I Offline
                      ignaciocarreras
                      Hi Fredo! First of all thank you for this amazing plug in.
                      And hi forum!
                      I came back to a model I was working last night and there's nothing saved in the Animator-Clip Editor, but I think I probably didn't save it as I was very sleepy.
                      So if the clip settings are not in the Clip Editor that means that I didn't save it?
                      Or there is any way to find previous clips? Hopefully it's saved somewhere in a folder in my PC?
                      Many thanks!
                      • fredo6F Offline
                        All Animator information is saved within the model. So, if you retrieve a previous version or the last backup save (.skb), it should be there.
                        This assumes however that you did save the animation at some point.
                        • 2 / 2
