    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 1.6.0 - 08.23.2020
      • Enabled variable king stud and trimmer stud widths for garage doors (non-portal frame).
      http://design.medeek.com/resources/wallplugin/images/wall_su415_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.6.0b - 08.23.2020
        • Added the ability to create, load and delete garage door presets within the Edit and Draw (HTML) Menus.
        • Fixed a bug with reading in presets from the door and window edit menus.
        http://design.medeek.com/resources/wallplugin/images/wall_su416_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.6.1 - 08.26.2020
          • All gable wall types (gable, hip, shed) now include the option to enter in the wall slope as a pitch or angle.
          http://design.medeek.com/resources/wallplugin/images/wall_su417_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            For completeness I think it would be a good idea to add the option for arched garage doors and dutch corners. The algorithms for arched doors already exist within the man door module and the geometry of dutch corners is very simple. Give me a couple of days and I will knock this one out.
            https://i.pinimg.com/originals/99/3c/3b/993c3b99ce7a89ff86fde61a4de63a36.jpg
            https://greyswoodworks.com/wp-content/uploads/2018/02/24_-X-24_-Classic-Main-Picture.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.6.2 - 09.01.2020
              • Added three additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus.
              http://design.medeek.com/resources/wallplugin/images/wall_su419_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                View model here:
                3D Warehouse
                (3dwarehouse.sketchup.com)
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.6.3 - 09.06.2020
                  • Added (segmental) arched garage doors to the garage door module.
                  http://design.medeek.com/resources/wallplugin/images/wall_su420_800.jpg
                  I still need to add the option for dutch corners.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.6.4 - 09.07.2020
                    • Added Dutch Corners to garage doors within the garage door module.
                    http://design.medeek.com/resources/wallplugin/images/wall_su421_800.jpg
                    View model here:
                    3D Warehouse
                    Now the garage door module feels a little more complete.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.6.5 - 09.10.2020
                      • Added a parameter into the global settings to allow for adjustment of the size of labels and annotations.
                      • Added a parameter into the global settings to allow for adjustment of the font for text found within annotations and labels.
                      http://design.medeek.com/resources/wallplugin/images/wall_su422_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        An example of a detached garage with arched doors set into a stemwall foundation:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/f/f/ff1c7d971424e9fb209849dfc2c8eb6db26e6126.jpeg
                        View model here:
                        3D Warehouse
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 16 - Garage Doorsย (19:17 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.6.6 - 09.15.2020
                            • Fixed a bug with Tyvek and ZIP Systems sheathing when the sheathing is lapped at the corners (rectangular walls only).
                            http://design.medeek.com/resources/wallplugin/images/wall_su425_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.6.7 - 09.26.2020
                              • Added additional tool tips to the Wall Corners tab of the Global Settings.
                              http://design.medeek.com/resources/wallplugin/images/wall_su426_800.jpg
                              I've been fielding a lot of questions recently about the corner offset parameter and related wall end/corner conditions. I may need to still provide additional documentation and diagrams to further clarify these parameters.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.6.8 - 09.28.2020
                                • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
                                http://design.medeek.com/resources/wallplugin/images/wall_su427_800.jpg
                                Previously when you renewed your license you would need to go through some convoluted steps to refresh you license data within the plugin. This new feature reduces this process to a single mouse click.
                                Previously the required steps were:
                                1.) Remove the existing serial number.
                                2.) Click the Save Settings button.
                                3.) Re-enter your serial number.
                                4.) Click the Save Settings button again.
                                5.) Restart SketchUp.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  First look at a 3D batten cladding on rectangular walls:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/4/3/43c2627535449580d6c8f37caca2fe9e0d50f446.jpeg
                                  View model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Some more screenshots of battens:
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/2/1/21870ccdede52556701ee38a76e6bbed69957400.jpeg
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cd9b943b4178a81693faadcb8252543bd40938e.jpeg
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/3/e/3efd578cb0ad1f8b9a3e216118cabb4f0e3ef85e.jpeg
                                    *Notice the format of the batten material and its three numeric values within the name of the material.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Texture vs. 3D Battens:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/9/b/9b14475c2c73f7239e17a162176a26833f8aeed5.gif
                                      Personally I prefer the texture myself, lower poly and it looks just as good or better than the real deal.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.6.9 - 10.17.2020
                                        • Added the ability to create custom "Board and Batten" wall cladding materials within the Material Library.
                                        • Enabled "3D" Board and Batten wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                                        http://design.medeek.com/resources/wallplugin/images/wall_su432_800.jpg
                                        For the plugin to recognize the wall cladding material as a "board and batten" material is must be in this format:
                                        battens_{decimal value}{decimal value}{decimal_value}
                                        The three values are: batten spacing, batten width, batten depth respectively.
                                        There should be no white spaces inserted into the name, only the underscore character in three places as shown.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Another view of board and battens:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/e/7/e7d8baa965a4ae4dae412d16c7bc98c1ac5da9d8.jpeg
                                          Just over five years into programming these plugins, I released the first version of the Truss plugin Oct. 7, 2015.
                                          The further I go it seems like I just keep coming up with more things "todo". I really need to take myself and clone me about five times and then set each clone at developing the various plugins, maybe then I might get somewhere with all of this.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.7.0 - 10.23.2020
                                            • Fixed a bug in the Walls tab of the Global Settings.
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 74
                                            • 75
                                            • 20 / 75
