    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      For completeness I think it would be a good idea to add the option for arched garage doors and dutch corners. The algorithms for arched doors already exist within the man door module and the geometry of dutch corners is very simple. Give me a couple of days and I will knock this one out.
      https://i.pinimg.com/originals/99/3c/3b/993c3b99ce7a89ff86fde61a4de63a36.jpg
      https://greyswoodworks.com/wp-content/uploads/2018/02/24_-X-24_-Classic-Main-Picture.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.6.2 - 09.01.2020
        • Added three additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus.
        http://design.medeek.com/resources/wallplugin/images/wall_su419_800.jpg
        design.medeek.com
        • medeekM
          medeek
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • medeekM
            medeek
            Version 1.6.3 - 09.06.2020
            • Added (segmental) arched garage doors to the garage door module.
            http://design.medeek.com/resources/wallplugin/images/wall_su420_800.jpg
            I still need to add the option for dutch corners.
            design.medeek.com
            • medeekM
              medeek
              Version 1.6.4 - 09.07.2020
              • Added Dutch Corners to garage doors within the garage door module.
              http://design.medeek.com/resources/wallplugin/images/wall_su421_800.jpg
              View model here:
              3D Warehouse
              Now the garage door module feels a little more complete.
              design.medeek.com
              • medeekM
                medeek
                Version 1.6.5 - 09.10.2020
                • Added a parameter into the global settings to allow for adjustment of the size of labels and annotations.
                • Added a parameter into the global settings to allow for adjustment of the font for text found within annotations and labels.
                http://design.medeek.com/resources/wallplugin/images/wall_su422_800.jpg
                design.medeek.com
                • medeekM
                  medeek
                  An example of a detached garage with arched doors set into a stemwall foundation:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/f/f/ff1c7d971424e9fb209849dfc2c8eb6db26e6126.jpeg
                  View model here:
                  3D Warehouse
                  design.medeek.com
                  • medeekM
                    medeek
                    Tutorial 16 - Garage Doors (19:17 min.)
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.6.6 - 09.15.2020
                      • Fixed a bug with Tyvek and ZIP Systems sheathing when the sheathing is lapped at the corners (rectangular walls only).
                      http://design.medeek.com/resources/wallplugin/images/wall_su425_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.6.7 - 09.26.2020
                        • Added additional tool tips to the Wall Corners tab of the Global Settings.
                        http://design.medeek.com/resources/wallplugin/images/wall_su426_800.jpg
                        I've been fielding a lot of questions recently about the corner offset parameter and related wall end/corner conditions. I may need to still provide additional documentation and diagrams to further clarify these parameters.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.6.8 - 09.28.2020
                          • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
                          http://design.medeek.com/resources/wallplugin/images/wall_su427_800.jpg
                          Previously when you renewed your license you would need to go through some convoluted steps to refresh you license data within the plugin. This new feature reduces this process to a single mouse click.
                          Previously the required steps were:
                          1.) Remove the existing serial number.
                          2.) Click the Save Settings button.
                          3.) Re-enter your serial number.
                          4.) Click the Save Settings button again.
                          5.) Restart SketchUp.
                          design.medeek.com
                          • medeekM
                            medeek
                            First look at a 3D batten cladding on rectangular walls:
                            https://aws1.discourse-cdn.com/sketchup/original/3X/4/3/43c2627535449580d6c8f37caca2fe9e0d50f446.jpeg
                            View model here:
                            3D Warehouse
                            design.medeek.com
                            • medeekM
                              medeek
                              Some more screenshots of battens:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/2/1/21870ccdede52556701ee38a76e6bbed69957400.jpeg
                              https://aws1.discourse-cdn.com/sketchup/original/3X/4/c/4cd9b943b4178a81693faadcb8252543bd40938e.jpeg
                              https://aws1.discourse-cdn.com/sketchup/original/3X/3/e/3efd578cb0ad1f8b9a3e216118cabb4f0e3ef85e.jpeg
                              *Notice the format of the batten material and its three numeric values within the name of the material.
                              design.medeek.com
                              • medeekM
                                medeek
                                Texture vs. 3D Battens:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/9/b/9b14475c2c73f7239e17a162176a26833f8aeed5.gif
                                Personally I prefer the texture myself, lower poly and it looks just as good or better than the real deal.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.6.9 - 10.17.2020
                                  • Added the ability to create custom "Board and Batten" wall cladding materials within the Material Library.
                                  • Enabled "3D" Board and Batten wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                                  http://design.medeek.com/resources/wallplugin/images/wall_su432_800.jpg
                                  For the plugin to recognize the wall cladding material as a "board and batten" material is must be in this format:
                                  battens_{decimal value}{decimal value}{decimal_value}
                                  The three values are: batten spacing, batten width, batten depth respectively.
                                  There should be no white spaces inserted into the name, only the underscore character in three places as shown.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Another view of board and battens:
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/e/7/e7d8baa965a4ae4dae412d16c7bc98c1ac5da9d8.jpeg
                                    Just over five years into programming these plugins, I released the first version of the Truss plugin Oct. 7, 2015.
                                    The further I go it seems like I just keep coming up with more things "todo". I really need to take myself and clone me about five times and then set each clone at developing the various plugins, maybe then I might get somewhere with all of this.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.7.0 - 10.23.2020
                                      • Fixed a bug in the Walls tab of the Global Settings.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        The Medeek Wall plugin (and mdkBIM) was featured in this 3D Basecamp Fireside Chat:
                                        Crowdcast
                                        Where the world gathers
                                        Crowdcast (www.crowdcast.io)
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.7.1 - 11.15.2020
                                          • Added additional HSS and Wide Flange Beam options to the free standing column (post) tool.
                                          http://design.medeek.com/resources/wallplugin/images/wall_su433_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.7.2 - 11.16.2020
                                            • Added the ability to create custom "Shiplap" wall cladding materials within the Material Library.
                                            • Enabled "3D" Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                                            http://design.medeek.com/resources/wallplugin/images/wall_su434_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images/wall_su435_800.jpg
                                            design.medeek.com
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 80
                                            • 81
                                            • 47 / 81
