    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      Iain
      One thing to check is whether the binary file has been successfully copied.
      Could you do the following in SU2019
      1. Open the RubyConsole
      2. Type File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
      3. The console should display the result, something like
        /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles
      4. Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
      5. If you open the directory in the finder, could you check if there is
        • a subfolder: binaries
        • and within it a subfolder SU19 with a file bin_LibFredo6.bundle
      If there is no file, then we have the explanation. This might be a problem of security settings.
      If there is a file, then this is another problem.
      • I Offline
        iaincsthorp
        @fredo6 said:
        Iain,
        Does LibFredo (and my other plugins) still load and work despite of that?
        I cannot reproduce the problem on my Mac (Catalina and MBP too). So, I need to investigate why you get the problem.
        No, unfortunately not. No Fredo toolbars are showing up.
        • fredo6F Offline
          Did you reboot your Mac?
            dr1416
            hallo , i have install on my Mac book last version of fredolibrary and new version of fredo corner, but have an error,
            the precedent version goes whiteout any problem.
            the error message after install and restart sketchup are the follow:
            Error Loading File Fredo6_!LibFredo6.rb
            Error: #<LoadError: dlopen(/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
            Referenced from: /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
            Reason: image not found - /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
            /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require' /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in require'
            /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:in load_binary' /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in startup'
            /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process' /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in module:LibFredo6_Loader'
            /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
              I am merging this into the main thread - where Fredo is more likely to see it !
                dr1416
                thanks , sorry I don't see an other post exit.
                  dr1416
                  for fredo6,
                  i ave look your message but system say I'm not able to reply at PM
                    dr1416
                    last update I have manual cancelled any files of fredo lib and reinstall,
                    now go
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v11.1c - 08 Sep 20
                      LibFredo6 11.1c includes various bug fixes.
                      • jujuJ Offline
                        juju
                        It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
                        • Y Offline
                          yhjeong
                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                          c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
                          c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
                          c:/users/μ •μ˜ν˜Έ/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
                          C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/μ •μ˜ν˜Έ/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
                          i experienced load errors.
                          Plz tell me how to fix it
                            @yhjeong
                            Fredo will reply in detail, but it looks like your Korean user-name [μ •μ˜ν˜Έ] is causing the issue.
                            Ruby expects any text-strings to be UTF-8 encoded.
                            In earlier Ruby versions non-ASCII characters always caused problems.
                            In the newer versions of SketchUp there is text-encoding possibilities.
                            I know Fredo uses these latest methods.
                            But somehow your Korean user-name is almost certainly causing the problem...
                              Arkitekto1994
                              Hi. Im having a trouble finding the file via extension manager. The files are in .rbz.skp, how can I convert it to purely .rbz file?
                                Why are the files .RBZ.SKP ??
                                A downloaded .RBZ file from the PluginStore should be saved with that file-type.
                                How did it get changed ?
                                I suspect your web-browser settings for downloaded file-types are FUBAR...
                                Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
                                However, you need to fix your download options...
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v11.2a - 27 Sep 20
                                  LibFredo6 11.2a includes technical adjustments for some dialogs.
                                    mexicano31
                                    @fredo6 said:
                                    Iain
                                    The same problem. But in the folder Binaries\SU19 i have a file bin_body_Lib6G6.so
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v11.2b - 09 Oct 20
                                      LibFredo6 11.2b includes technical adjustments for video generation used by Animator
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v11.2c - 11 Oct 20
                                        LibFredo6 11.2c fixes a bug in the generation of videos for Animator (.MOV format can now be excluded)
                                          loesshill
                                          I've installed several extensions plus Libfredo6 months ago, and they all worked well,(thank you).
                                          Today they do not work. Please advise.
                                          • fredo6F Offline
                                            Maybe you can indicate which one and give more info on the issues. This would help....
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 108
                                            • 109
                                            • 12 / 109
