Updating to LibFredo6 v10.9
I got a notice that I should update LibFredo6. Where can I find instructions on how to do that?
Thank you.
You should always have the latest versions of Extensions downloaded and installed.
Some complex extensions - like Fredo's - need a support Library - so download and install the latest version from the PluginStore...
https://sketchucation.com/pluginstore?pln=LibFredo6You can get the latest versions of his extensions from there too - just use the filter/search function...
Restart SketchUp to ensure proper syncing after these extensions are installed...
I've downloaded the version, but I need instructions as to how to install it.
Go to Window>Extension Manager and click on Install Extension. Navigate to where you saved it, select it and choose Open.
You might find it easier to download and install the Sketchucation Extension Store from Resources at the top of the page. Install it as above and then use it to install extensions from SCF. If you use it to install extensions it can help you keep them up to date. The tool has a number of other useful features as well.
As DaveR says:
Go to SketchUp menu item: Window > Extension Manager - click on Install Extension... Navigate to where you saved the RBZ file, select it and choose Open.
It's then auto-installed for you...
But I find you difficulty hard to understand...
You say you understand you need a newer version of LibFredo [from a message?].
So you must have aversion already installed ?
You must also have some of Fredo's Extensions installed to have got the message ??So why do you have trouble installing the newer RBZ, when somehow earlier ones were installed ??
