    Rogue's W.I.P's!
    922 Posts 55 Posters 169.0k Views 55 Watching
    • Bryan KB Offline
      I particularly like the Falcon XC one, nice work! I've only ever done a few renders, but I can't remember the name of the software I used. I might try and find it again...
      Thanks Ben.
      I was trying two different types of lighting. One in the shade and one in direct sunlight.
      The Falcon is more of a "glamour / studio set" shot and the Milano is more of natural, "from a phone cam" shot.
      • Roguer1R Offline
        Roguer1
        Well, I found my old licence for KeyShot and reinstalled to play with some renders. I've spent the best part of 6 hours playing with textures and lighting. It's not perfect, they're a little dark, but I'm happy enough with the results. It doesn't hurt that my new models are significantly more well optimised for rendering and that my PC is dozens of times more powerful than my old laptop. Renders at 1080p would have taken me an hour before, but these took me about 2-3 min each...
        First set is of some of the Milano Sedan set, I'll upload more as I play around a bit more
        Find all my models on the [3D Warehouse](https://3dwarehouse.sketchup.com/user/d8bb4d13-3b01-44a0-a007-4a77a32b6433/Ben-B?tab)
        • Roguer1R Offline
          Roguer1
          Here is the Azione R-Spec. It sort of disappears into the background, but I liked the colour too much
          • Bryan KB Offline
            Very nice!
            • Bryan KB Offline
              Ben, I noticed when I was rendering your models that you used some kind of subdivide on you models. Could you explain your work flow? The subdivide seems to be the key to making smooth curved surfaces, but when I try using Artisan I get very crude and unusable results.
              • Roguer1R Offline
                Roguer1
                I do occasionally use a tool called 'Subdivide and Smooth'. I've an older (paid?) version which isn't fully compatible with SU anymore but still subdivides fine. I only usually use it when I really can't be bothered adding detail to smooth out the poly lines on an edge, for example; a wheel arch curve.
                I typically group off only a section of mesh (a single surface of a panel or just around the area where the line is I want to smooth), use sub-smooth, copy the edge that's been subdivided, back up a few steps, delete the old mesh in that area, paste the line in place and then manually stitch it in. I do this because the resulting sub-smoothed can be quite messy and I really just want the clean/ smooth edge that would be more accurate than what I can create by eyeing it.
                A lot of subdivision I do manually, just by filling in extra lines into the mesh and moving them into place to smooth out a surface or edge. I'm rather envious of the tools in blender than can cleanly turn a fairly low detail mesh into a very clean subdivided one, but I really can't get my head around all the tools in Blender and find it much easier to do most of it manually.
                Also, felt like adding my latest render. This is my new desktop background
                • Bryan KB Offline
                  Thanks.
                  Artisan has a Subdivide and Smooth function but it sometime feels crude. Mostly likely it is me not using it right.
                  Could I ask you to post a small example of how you do it?
                  That said, nice renders!
                  • Roguer1R Offline
                    Roguer1
                    No problem Bryan. I've attached a small example of how to do it how I do. This is a round-about method because I prefer to have a cleaner mesh, so I do it by hand. I've saved it as SU 2016 format for compatibility reasons, just in case someone is using an older version and still wants to access it
                    Switch tabs to see the different steps, or just pan to the right
                    SDS Example (2016 format).skp
                    • Bryan KB Offline
                      Thanks Ben! I really do appreciate it.
                      • Roguer1R Offline
                        Roguer1
                        So, did that explain it sufficiently Bryan?
                        Here is another update. Have been trying something a little different with the panel gap, in trying to make it look a lot more realistic, while not going all out on poly count. So far I can say that the results are fairly good, but it requires a lot of work and likely won't be done for future models.
                        I also want to do something like the Zakspeed Capri
                        • Bryan KB Offline
                          Thanks Ben.
                          Yes, sort of. I am experimenting now with the current WIP.
                          2 days later I was able to recreate the technique and it's work great.
                          Thanks again!
                          • Roguer1R Offline
                            Roguer1
                            Here is an update on the engine bay, which is quickly becoming my most detailed yet
                            • Bryan KB Offline
                              Looking good!
                              • Roguer1R Offline
                                Roguer1
                                Here it is!
                                https://3dwarehouse.sketchup.com/model/e54c705c-3af0-4873-8506-24a772b6c95b/2020-Rogue-Puma
                                • Roguer1R Offline
                                  Roguer1
                                  Started work on the race version
                                  • Bryan KB Offline
                                    Wow! That's looking great!
                                    • Roguer1R Offline
                                      Roguer1
                                      Front tube-frame basically complete
                                      • Bryan KB Offline
                                        Nice!
                                        • Roguer1R Offline
                                          Roguer1
                                          Uploaded a 'new wheel', it's a rebuild of my D-011
                                          https://3dwarehouse.sketchup.com/model/50325f50-4567-4796-af31-d15168372230/Rogue-D-045
                                          Also started work on a new model after coming up with some ideas. It's a bit of a mix between an MR2, a 300ZX and a Ferrari F355
                                            Very sharp. 👍
                                            • 46
                                            • 47
                                            • 3 / 47
