    Rogue's W.I.P's!
    922 Posts 55 Posters 434.2k Views 55 Watching
    • Roguer1R
      Roguer1
      I do occasionally use a tool called 'Subdivide and Smooth'. I've an older (paid?) version which isn't fully compatible with SU anymore but still subdivides fine. I only usually use it when I really can't be bothered adding detail to smooth out the poly lines on an edge, for example; a wheel arch curve.
      I typically group off only a section of mesh (a single surface of a panel or just around the area where the line is I want to smooth), use sub-smooth, copy the edge that's been subdivided, back up a few steps, delete the old mesh in that area, paste the line in place and then manually stitch it in. I do this because the resulting sub-smoothed can be quite messy and I really just want the clean/ smooth edge that would be more accurate than what I can create by eyeing it.
      A lot of subdivision I do manually, just by filling in extra lines into the mesh and moving them into place to smooth out a surface or edge. I'm rather envious of the tools in blender than can cleanly turn a fairly low detail mesh into a very clean subdivided one, but I really can't get my head around all the tools in Blender and find it much easier to do most of it manually.
      Also, felt like adding my latest render. This is my new desktop background
      Find all my models on the 3D Warehouse
      • Bryan KB
        Thanks.
        Artisan has a Subdivide and Smooth function but it sometime feels crude. Mostly likely it is me not using it right.
        Could I ask you to post a small example of how you do it?
        That said, nice renders!
        • Roguer1R
          Roguer1
          No problem Bryan. I've attached a small example of how to do it how I do. This is a round-about method because I prefer to have a cleaner mesh, so I do it by hand. I've saved it as SU 2016 format for compatibility reasons, just in case someone is using an older version and still wants to access it
          Switch tabs to see the different steps, or just pan to the right
          SDS Example (2016 format).skp
          • Bryan KB
            Thanks Ben! I really do appreciate it.
            • Roguer1R
              Roguer1
              So, did that explain it sufficiently Bryan?
              Here is another update. Have been trying something a little different with the panel gap, in trying to make it look a lot more realistic, while not going all out on poly count. So far I can say that the results are fairly good, but it requires a lot of work and likely won't be done for future models.
              I also want to do something like the Zakspeed Capri
              • Bryan KB
                Thanks Ben.
                Yes, sort of. I am experimenting now with the current WIP.
                2 days later I was able to recreate the technique and it's work great.
                Thanks again!
                • Roguer1R
                  Roguer1
                  Here is an update on the engine bay, which is quickly becoming my most detailed yet
                  • Bryan KB
                    Looking good!
                    • Roguer1R
                      Roguer1
                      Here it is!
                      https://3dwarehouse.sketchup.com/model/e54c705c-3af0-4873-8506-24a772b6c95b/2020-Rogue-Puma
                      • Roguer1R
                        Roguer1
                        Started work on the race version
                        • Bryan KB
                          Wow! That's looking great!
                          • Roguer1R
                            Roguer1
                            Front tube-frame basically complete
                            • Bryan KB
                              Nice!
                              • Roguer1R
                                Roguer1
                                Uploaded a 'new wheel', it's a rebuild of my D-011
                                https://3dwarehouse.sketchup.com/model/50325f50-4567-4796-af31-d15168372230/Rogue-D-045
                                Also started work on a new model after coming up with some ideas. It's a bit of a mix between an MR2, a 300ZX and a Ferrari F355
                                  Very sharp. ๐Ÿ‘
                                  • Roguer1R
                                    Roguer1
                                    Just updated the previous wheel, wasn't entirely happy with it
                                    Also just made a 5 spoke version of my D-044
                                    and a race version of my D-039, from my upcoming Puma R-Spec
                                    Find these in my signature below
                                    • Roguer1R
                                      Roguer1
                                      @mike amos said:
                                      Very sharp. ๐Ÿ‘
                                      Thanks Mike!
                                      Here is a reworking of another one of my old wheels.
                                      https://3dwarehouse.sketchup.com/model/817a6f0a-cf8b-404a-b79d-0dbfc00318ab/Rogue-D-048
                                      • Roguer1R
                                        Roguer1
                                        Yet another wheel, this is basically an Enkei RPF1
                                        https://3dwarehouse.sketchup.com/model/56fd00e3-c20c-40a7-8a31-0e09fddb992b/Rogue-D-049
                                        • Bryan KB
                                          Top notch!
                                          • Roguer1R
                                            Roguer1
                                            Had a fairly productive day again today, hope you enjoy these wheels!
                                            3DWarehouse link below
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 46 / 47
