    [Plugin][Code]SKMtools,Material/ImageTools
    177 Posts 37 Posters 296.5k Views 37 Watching
      If I flatten your PNG it works fine !
      See attached...
      So it must be some weird interaction of pixels ?
        I thought it's because you have several pixels within the main image [eyes/glasses] that are transparent...
        I filled them, flattened the PNG, then made the blue background the alpha-channel and it still crashes !
        I'm still investigating...
        • deaneauD Offline
          deaneau
          https://s12.directupload.net/images/200612/y73e5rhy.png
          without glasses this works hm, very mysterious
          • deaneauD Offline
            deaneau
            TIG if you want you can try this here. I have only safe the svg to the PNG in different resolutions.
            https://charactercreator.org/#sex=m&skinColor=%23f0d5be&irisColor=%23197c60&hairColor=%238d7c7c&pupils=round&nose=syrid&facialhair=beard_boxed&hair=wreckingball&emotion=amusement&shirt=tshirt&vest=yellow&body=default&pants=leather&shoes=leather&shirtColor=%23111010&vestColor-bet=%23e9e0cf&vestColor=%23eba008&glassesColor-del=%2300ffc4&glassesColor-bet=%2342ba9e&body_head=default&glasses=hipster
              It is something to do with some semi-transparent pixels around the eyes/glasses which mess up the outline of the form when the main transparent areas are discounted...
              Try flattening the image then deleting only the main 'blue' areas around the body to add back in the transparent alpha-channel...
              • deaneauD Offline
                deaneau
                ok Thank you TIG.
                and stay healthy.
                • joshtaysJ Offline
                  joshtays
                  Java default.JPGStumped:
                  Deleted root level plugin folder and rb file
                  Downloaded fresh from Sketchucation
                  re-installed from extension manager
                  Uninstalled ALL compresssion apps
                  Ensured all jar files default to java
                  Ran 2021 installer as admin, repair
                  deleted SKMTools temp folder
                  Still getting creating edges, then no dialogue box for simplify, standup, etc, like plugin used to do, processing ends, image remains png.
                  File is 100% alpha on image and 0% on background, confirmed in PS
                  TrimmedImages folder with png from SU file is generated in root folder that SU file lives in.
                    What version of SketchUp are you using? SketchUp 7 as indicated in your profile?
                      Run it with the Ruby Console open and see if there are any error messages.
                      Also you PNG image has not been 'optimized' there are large areas of 'blank-space' around the tree...
                      Ensure that only the background pixels have transparency and that the image is cropped to minimize those, to speed up processing...
                      What files in in the temp folder after processing ?
                      • joshtaysJ Offline
                        joshtays
                        Dave R, no sorry been a while since I've updated my profile, LOL. I'll update shortly
                        SU V20.0.391 Win 64
                        Machine is a gen 10 I7 desktop with RTX 3070 64GB RAM
                        TIG - I'll try cropping the image harder, but this is happening with images that I have had success with in the past as well. In the temp folder that comes up in model location, the only file inside is a copy of the PNG.Edit not the temp folder you were asking about... Going to run with console on then check the temp folder and get back.
                        • joshtaysJ Offline
                          joshtays
                          -Ruby console-
                          Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - C:\Users\2atay\Desktop\TrimmedImages\Etsy_Oaxacan_rug_zapotec[Edges].dat>
                          C:/Users/2atay/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:277:in readlines' C:/Users/2atay/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:277:in make_edges'
                          C:/Users/2atay/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:201:in process_image' C:/Users/2atay/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:170:in initialize'
                          C:/Users/2atay/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in new' C:/Users/2atay/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in block in <top (required)>'
                          -Temp Folder-
                          EdgeDetector.jar
                          from.ini
                          to.ini
                          the ini files are pointing to the trimmed images folder, which for this test happens to be on my desktop
                            The error relating to the creation of the ..\TrimmedImages\Etsy_Oaxacan_rug_zapotec[Edges].dat file suggest several possible issues...
                            A possibility...
                            1. Could you post the PNG you are using...
                              If that image has all of its pixels with even some transparency, then they will get ignore because they'll be regarded as 'background', so you might end up with nothing to form 'edges' - and no .dat file...
                            A known cause...
                            2. Are your .JAR file-types set to be executed [opened] in Java ?
                            Some compression applications can hijack that file-type, and so they try to open the file instead of letting it run as a the small Java applet [aka JAR] - vital to parse the image's pixel-data.
                            Check any compression app's setting for file-types and do NOT include .JAR...
                            • MikeG73M Offline
                              MikeG73
                              Hello TIG,
                              Your extension offers a lot of promise, and I would like to know your recommendations for trimming and using this image as stampers for an F-14D Tomcat. Thank you!
                              F-14D:
                              https://3dwarehouse.sketchup.com/model/72e1cdcb882b6993c1006ed55bc1a3fc/Grumman-F-14D-Super-Tomcat
                              Stampers:
                              https://3dwarehouse.sketchup.com/model/691a25cbb1e7c3b420ca70e6f850f66e/Stampers-Tutoral
                              https://3dwarehouse.sketchup.com/model/eaa7f7401f84d2ef67939c61bbcfb315/LOGO-Star-of-Life
                              Decals:
                              https://3dwarehouse.sketchup.com/model/0804427b-632e-436b-a445-768fd47e8ab2/German-Decals
                              Cheers Mate! 😎
                                rustar123
                                I cannot install this. Why?
                                Please help me!
                                  Please help me!
                                  According to your screen shot it is installed. Unsigned doesn't mean it's not installed. As long as you have the loading policy set to allow unsigned extensions to load, they will load. This extension works just fine.
                                    rustar123
                                    @dave r said:
                                    Please help me!
                                    So how to make it work? pls help!!
                                      If you have your Extension Manager's Loading Policy set to 'Unrestricted' then you need to restart SketchUp...
                                      Then the SKM toolset loads...
                                      There are several code method additions defined.
                                      However, I suspect you want to use one of its specialize tools - e.g. ImageTrimmer...
                                      you haven't explained what your exact problem is...
                                      ImageTrimmer has its own thread in which its usage is explained and discussed in great detail...
                                      It runs from an entry in the Tools menu...
                                      Please explain what you want to do...
                                        What do you want to use the extension for? There are some different tools included in the set.
                                          rustar123
                                          I want to import this jpg to sketchup for push/pull. Then print 3d.
                                          So what is the easiest way to do this? thank's
                                            The Image Trimmer feature of SKM Tools would be a good way to go but you need to follow the directions. It requires a PNG not a JPG and the white area needs to be transparent, not white. Use an image editor to make a suitable image and go to town.
                                            Frankly, it's not a very complex thing. I'd probably just import the image as an image and use it as a reference for drawing it with the native drawing tools. The image you uploaded isn't very high resolution either so running Image Trimmer will likely result in pixelated edges.
                                            Here's an example. This was with simplification set to 0.25. Any higher and the curves get straightend out quite a bit.
                                            • 7 / 9
