    Point To Center
    22 Posts 5 Posters 4.0k Views 5 Watching
    • Joe WoodJ
      Joe Wood
      Right on Tig, would that be better then the one offered by Chris? I really only need to find center of arcs, can't even remember wanting to find center of a circle.
      Joe Wood
      woodsshop.com/
        Chris's tool doesn't actually find the center of an arc unless you have exploded it, then it works backwards to work out the center of a possible arc from two of the [now] separate edges, which could have been before !
        So my version is probably the best for you.
        If you only want to find Arc centers it's fine - with one [arc-curve] selected the context-menu says "Point at Center of Arc".
        If it's a circle then it's actually an arc that loops back on itself in 360° - it then says "...of Circle".
        Because a polygon is really a special kind of circle that doesn't produce smoothed extrusions in that case it says "...of Polygon".
        But if you find yourself with some edges which were once an arc, then using Chris's tool will help...
        • Joe WoodJ
          Joe Wood
          Hhmmm, trying to install that rb, went to SUp 2015 but don't see a Plugins folder, only a ifc plugins, and I don't see any other rb files in there?
          also I went to Preferences>Extensions and clicked on Install Extension, browsed to th Downloads folder but only see the other rb I downloaded yesterday. I dragged it out of downloads to my desktop but can't see it there either?
          Joe Wood
          woodsshop.com/
          • Joe WoodJ
            Joe Wood
            I see other rb in the Tools folder?
            Joe Wood
            woodsshop.com/
              You can only install RBZ files using the Extension Manager dialog.
              These go into your user's Plugins folder...
              For such a simple RB you just put it directly into your Plugins folder.
              Your user's Plugins folder [in all newer SketchUp versions] is now 'hidden', and it's in your AppData tree.
              So that's why I gave you [what I thought were] clear instructions on how to open the Plugins folder using the Ruby Console...
              To reiterate... In SketchUp open the menu item Window > Ruby Console and paste the text in and press <enter>
              UI.openURL("file:///#{Sketchup.find_support_file('Plugins')}")
              Your Plugins folder will open and you then simply drop the RB into it...
              Restart SketchUp to auto-load the new RB file...
                Sorry if I was a bit terse - the unseasonal gales are blowing half my garden away !
                Here's an RBZ equivalent to the previous RB file - I simply zipped the .rb file and changed its .zip to .rbz
                Download this RBZ, then use the built-in Extension Manager's dialog's red-button to auto-install it...
                ArcContextmenu.rbz
                • Joe WoodJ
                  Joe Wood
                  No terseness detected Tig!
                  we're almost there I think. I found the Preferences>Extensions, but don't see a red button??
                  Joe Wood
                  woodsshop.com/
                    Sorry, I'm keep forgetting your version of SketchUp predates Noah !
                    In the older SketchUp versions you install extensions' RBZ files using Window > Preferences [it opens a dialog] > Extensions [open that tab] > Install Extension... [a button - default-gray color]
                    Then you find the RBZ, OK... and it installs.
                    In newer SketchUp versions it's pretty much the same tool, but now it is accessed from Window > Extension-Manager [opens a dialog] and that dialog has a button saying 'Install Extension...' [and in that case it is colored red !]
                    • Joe WoodJ
                      Joe Wood
                      I have the ArcContextmenu.rb,
                      do I need to rename it to rbz?
                      Joe Wood
                      woodsshop.com/
                        Luckily I have the patience of Job !
                        An RB file cannot just be renamed as an RBZ file.
                        I already gave you an RBZ version that was properly prepared [via zipping].
                        Have you downloaded that RBZ ?
                        Install that RBZ using the native 'install' button... as I've recently explained...
                        The RB version can only be installed using the alternative methods I initially outlined a day or two ago...
                        BUT for simplicity's sake I then gave you an RBZ version, and instructions on getting the 'install' button opened etc...
                        • jujuJ
                          juju
                          That's very funny (Joe Wood's on SU2015) considering Pilou insists people downsave files to SU6 for them to get help...
                          • 2 / 2
