    Fredo tools not working . Please help !!!!!!
    7 Posts 4 Posters 1.2k Views 4 Watching
    • I Offline
      iainteriors
      Hello
      Please help anyone
      I have tried reinstall repair deleting tgat file from app data : local : lib ....
      But still my fredo tools are not working
      Now this is appearing in ruby console .
      Let me know what i can do next to reaolve this issue
      I have sketchup 2017 and 2020
      It was working fine yesterday morning but suddenly it stoped working
      Error: #<NoMethodError: undefined method set_min_max_width' for #<Traductor::Wdlg:0x000001a39db79548>> c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6quicklauncher.rbe:81:in initialize'
      c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:47:in new' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:47:in invoke'
      c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredotools/fredotools.rbe:200:in invoke_quick_launcher' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredotools/fredotools.rbe:222:in block in startup'
      c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1095:in command_invoke' c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1077:in block (2 levels) in build_config_commands'
      c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1285:in `block in add_command'
        First thing I would do is update LibFredo6 to the current version. Then close SketchUp and start it again.
        • I Offline
          iainteriors
          I did that already . Stil i doesn't work
            Have you installed SketchUp properly ?
            Try a 'repair' as follows...
            Whilst you are logged into your normal Windows user-account, ensure that SketchUp [and Layout] are no running.
            Find the installer's exe file - usually in your Downloads folder ?
            Select the installer's exe file, right-click > context-menu > "Run as administrator"
            When prompted choose "Repair".
            When it completes restart SketchUp...
            Any better ?
            Running any complex app's installer exe file in another way will lead to unpredictable weird issues, often involving file/folder permissions - sometimes these problems don't appear immediately, leading to extra confusion !
            Never double-click an installer's exe file to 'Run' it.
            Even if your normal user has admin-powers it is NOT the same as doing it as outlined above.
            • I Offline
              iainteriors
              Yes i did the repair method also it doesn't work
                Hopefully Fredo can chip in with some ideas... 😲
                • fredo6F Offline
                  I would suggest to have a look at the Plugins directory and clean up the LibFredo6 file and folder, check if there are old ones, and then re-install LibFredo6.
