    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.8m Views 343 Watching
      AISmebel
      Hello. Please tell me if you can use your plugins FredoScale and VisuHole so that the components do not lose contact with each other?
      I do not use these plugin functions because the connection between the components is broken. This is very inconvenient for me and for many users using this plugin.
      • fredo6F Offline
        Application to other component instances is something I can try to manage for VisuHole and FredoScale stretch is some situations.
        But be aware that this may not work, because, for instance, you could make a hole in 2 instances of the same component at different location.
        That's why I make the instances unique in the general case.
          AISmebel
          For this, we need components! Work in one component should be displayed in others. Otherwise, I would use groups. And unique component, I can do it myself.
          You can add an icon that allows you to make the component unique or change it in all similar components.
          The plugin Bolt Maker (Final) does not break the connection between the components.
            kubap
            • Would it be possible to Scale/Stretch by a specified additional lenght? For example if you want to stretch something so it's 20cm longer. Then instead of putting a scale factor you put +20 (or respectively -20 if you want to shorten it by 20cm).[/quote]
              The best is that you just hover the handle you wish to move, then type TAB. In the dialog box, you can type formulas, so add a "+20cm" at the end of the current value.[/quote]
            Thanks 😄 it was there all the time. Sorry it took me so long to reply, I had notifications disabled.
            Is it possible to stretch within the component? I mean within it's boundaries, not changing it's outer size but stretching it's inner parts. I'll try to explain it with attached image:
            • fredo6F Offline
              This is not supported by FredoScale currently, but this could be an additional feature in the feature.
              In the meantime, you can simply use the Sketchup native Move tool to achieve it in most situations. Actually the Stretch tool of FredoScale is based on the native Move tool.
                kubap
                Yes, I use Move for this but I prefer FredoScale, it's more precise and easy to use 😄 For example FredoScale works even with stretching a few closed groups, while Move needs everything exploded to polygon level.
                  rv1974
                  use this:
                  https://sketchucation.com/pluginstore?pln=t2h_stretch_by_area
                    kubap
                    @rv1974 said:
                    use this:
                    Thanks 😄
                      bharralure
                      Bonjour Fredo
                      Lanceur FredoScale ne fonctionne pas sous :
                      • SU 20.0.373
                      • FredoScale v3.1a
                      • LibFredo6 v10.3.b
                      Les outils (lancés soit depuis le menu contextuel, soit depuis depuis Menu > Outils > FredoScale) fonctionnent
                      La console affiche le message suivant :
                      FredoScale_Error
                      Error: #<TypeError: no implicit conversion of Symbol into Integer>
                      c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6quicklauncher.rbe:60:in []' c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6quicklauncher.rbe:60:in block in initialize'
                      c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6quicklauncher.rbe:57:in each' c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6quicklauncher.rbe:57:in each_with_index'
                      c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/body_lib6quicklauncher.rbe:57:in initialize' c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:47:in new'
                      c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:47:in invoke' c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:444:in invoke_quick_launcher'
                      c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:291:in block in configure' c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1320:in command_invoke'
                      c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1302:in block (2 levels) in build_config_commands' c:/users/bharr/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1372:in block in add_command'
                      "Add help menu!"
                      "create new"
                      "created"
                      #Sketchup::Menu:0x000001bb92babab8
                      Par contre, Lanceur FredoScale fonctionne très bien sous :
                      • SU 19.3.373
                      • FredoScale v3.1a
                      • LibFredo6 v9.5.b, qui n'est pas mis à jour
                      Est-ce grave Docteur ?
                      • fredo6F Offline
                        • SU 20.0.373
                        • FredoScale v3.1a
                        • LibFredo6 v10.3.b
                        Bizarre...J'ai l'impression que FredoScale n'est pas vraiment à jour. Pourrais-tu le réinstaller, en prenant soin de supprimer le repertoire Fredo6_FredoScale auparavant dans le repertoire Plugins de Sketchup.
                          bharralure
                          Merci pour la réponse rapide.
                          Après avoir supprimé manuellement le dossier et le fichier du dossier Plugins, je l'ai réinstallé une première fois à l'aide de l'outil SketchUcation (ma méthode habituelle), le lanceur n'a pas fonctionné.
                          J'ai ensuite supprimé/réinstallé, mais cette fois manuellement depuis le gestionnaire d'extension, sans succès.
                          J'ai supprimé/réinstallé LibFredo6 en appliquant successivement les 2 méthodes ci-dessus, toufours sans succès.
                          J'ai téléchargé à nouveau FredoScale et LibFredo6 puis comparé les Hachages SHA-256 sans trouvé de différence avec les versions installées.
                          Y a-t-il quelque chose d'autre que je puisse faire?
                          • fredo6F Offline
                            N'y aurait-il pas de vieux fichiers de mes plugins qui traînent dans le repertoire Plugin?
                              bharralure
                              Je ne vois pas, ou sinon Windows les à bien caché ...
                              Je viens de lancer l'outil "purger les fichiers obsolètes" depuis Fenêtre > LibFredo6, il n'a rien trouvé.
                              Bon il ne faut arrêter de ce prendre la tête pour un problème qui n'est pas majeur. Je vais afficher la barre d'outil complète. Elle va prendre plus de place que le lanceur seul, mais c'est le seul inconvénient.
                              Merci pour l'aide.
                                bharralure
                                Bonsoir Fredo,
                                Je viens d'installer LibFredo6 v10.4.a et là Miracle! le lanceur Fredo Scale fonctionne à nouveau.
                                Du bon travail comme d'habitude.
                                Merci
                                  rv1974
                                  Si vous permettez I'd continue in English 😄
                                  Would it be possible to implement 'preserve texture' mode?
                                  In this mode, all texture's transforms (scale,proportions,orientation) would stay untouched.
                                  I'd like it to be as default even in standard scale tool, but Trimble and adding new features don't compose well in these latter days
                                  • fredo6F Offline
                                    Actually, FredoScale does not more or less than what the Sketchup native tool (Scale, Move or deform) would do. Even if it's possible to alter the behavior, I think it would make things complicated because it would have to be an option and would potentially slow down the live deformations (to re-apply texture).
                                    The best in my opinion is that deformation is done before texturing and then use the dedicated tools for texturing or re-texturing.
                                      rv1974
                                      I'll be more precise:
                                      It'd be way more logical if at least Boxing Scaling would preserve textures exactly like your Box stretching (already existing tool! )
                                      I doubt. Rescale a simple box group without material and then apply some bitmap material. The texture sizing will be wrong.
                                        LostArkitekt
                                        This program isn't without issue. I used the Box Scale to "flatten" a bunch of things so I can bring them into AutoCAD (for our consultants). It creates objects that appear to be there, but then when you go to open them up, they disappear.
                                        • fredo6F Offline
                                          I would need more information on this issue
                                          After applying FredoScale flattening, do you see the objects correctly in Sketchup?
                                          If so, if the problem is in the Export, it might be because they have a thickness of zero.
                                          • E Offline
                                            Einstein
                                            Hello,
                                            I got two questions.
                                            First one is:
                                            Is there any way/shortcut to force scaling box align to group's/ world axes?
                                            Second one is a request:
                                            When we use shear tool for specific edges/faces, not for entire groups, it kind of "pulls" any edges/faces attached to transformed part of mesh. This is very nice behaviour because we can not only shear groups/ components but also fragments of meshes and they will keep continuity - they will stay "glued together" as they were originally. On the other hand, taper tool doesn't behave that nicely. Do you think you could change the plugin a little (if you have time) so that taper behaviour would be similar to shear tool?
                                            Here's a screenshot:
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 57
                                            • 58
                                            • 50 / 58
