    [Plugin] Edge Tools
    211 Posts 74 Posters 297.5k Views 74 Watching
    • F Offline
      filatelik
      Hi Thomthom, first of all many thanks for this useful plugin.
      Just would like to ask you if exist or you plan to make its equivalent for newer versions of Sketchup? I mean *.rbz suffix of file. Many thanks in advance for your answer.
      Filip
        Filip
        The rbz file is already available and has been for a long time. Look in the PluginStore by clicking on the button at the top of this page. Or better, install the Sketchucation Extension Store tool (look under Resources at the top of this page.) and use it to install Edge Tools. Don't forget to also install the current TT_Lib as well.
        • E Offline
          Einstein
          Very handy tool, thank you 😄
          I'd have a little upgrade suggestion - the first tool "Split faces into multiple pieces" could remember the last distance used and snap cursor to it 😄
          • E Offline
            Einstein
            Hi!
            I use these tools a lot but unfortunately I cannot set a key shortcut for any of them because thery're not listed in SketchUp's tools list in Preferences > Shortcuts. Please, if you could, make some upgrade that would include them into the list.
            Also remembering last distance in the first tool: "Split faces into multiple pieces" would be a great feature. With these two things Edge Tools would be not only cool and handy, but also very fast to use.
            • BoxB Offline
              Look for them under Tools/edge...
                @einstein said:
                Hi!
                C'mon Einstein. As Box wrote...
                Filter for 'edge' to shorten the list.
                • E Offline
                  Einstein
                  Thank you.
                  I was confused because the tool called "Split faces into multiple pieces" stood in the list as "Divide faces" and I firstly didn't come up it's the same thing.
                    maszka
                    THe plugin Egde and Lib are installed properly but I cannot find anything in tools/ view toolbars to swich on. I cannot find this pludins in interface of sketchup anywhere.
                    Anybody could help me?
                      Are you still using SketchUp 8 as indicated in your profile?
                      How exactly did you install them?
                        asder
                        thank
                          ct103stu0
                          When I use "Find all edge gaps", I see the circles. And I can click each one and repair. But, due the large number, I then use "Close all edge gaps", and none of the gaps are closed. Should "Close all edge gaps" close all gaps identified by the "Find all edge gaps"?
                            maheswari19
                            Hey thomthom!
                            I am currently using sketchup 2020. I installed edge tools plugin but it does not show up on my palette. And i checked on my extension manager it shows enabled but is does not shop up. Please help me.
                              Did you also install the current version of tt_lib2? It is required for Edge Tools to work. And did you install SketchUp 2020 correctly by right clicking on the downloaded installer exe file and selecting Run as administrator from the context menu?
                              • E Offline
                                Einstein
                                It would be cool to have the same tool names in the toolbar and Preferences. For example: a tool called "Split faces into multiple pieces" lives in the Prefs hotkey list as "Divide faces" and I couldn't figure out it's the same thing. It is very confusing.
                                • JonFarJ Offline
                                  JonFar
                                  Hi.
                                  This is a very useful plugin that I use everyday, however I would like to modify just a little thing that I think might be easy but I don't know how.
                                  When I click the icon in the toolbar to DIVIDE/SPLIT faces, the line created is always a regular line. So far so good.
                                  However if I assign a shortcut to DIVIDE/SPLIT faces, the line created is a construction line -- I have to use CONTROL to change it to a regular line.
                                  Is there a way to change it so that the shortcut command also creates a regular line without need to press CONTROL?
                                  I know it's a nitpick, but maybe it's something easy to change in the code, if you could tell me what line to change.
                                  Thanks in advance
                                  • MatteM Offline
                                    Matte
                                    Would this be the best tool for...
                                    -Imported CAD DWG (General Floor Plan) into sketchup 2016
                                    -Most walls are not a single line from corner to corner but 15-20 segments from corner to corner.
                                    -Can I window the entire drawing - Run the edge tool, and each wall run will just be single lines?
                                    Thanks Mattee
                                      It probably will but it might weld edges you don't want welded, too. Corners, for example might show as softened when you raise the walls to 3D. That can be fixed but it would be something to be aware of.
                                      Generally I find dxf and dwg files are so sloppily made that I rarely ever use the geometry directly. I find it's usually less work to use the import as a reference for drawing my own edges without all those breaks. My geometry tends to be cleaner. Once I've finished using the import for reference I delete the component and purge it from the model.
                                        mfipekci
                                        Hello. This is one of my favourite plugins. I uninstall and install again Sketchup. Because I got Sketchup 2026.
                                        But where is the Edge tools. I download it from sketchucation. I install from extension manager but it never appears. Please help me.
                                          This is explained under its 'More Info' link...
                                          https://community.sketchucation.com/topic/117065/plugin-edge-tools
                                          Its entry appears under the Tools menu.
                                          It also has its own Toolbar, that can be activated.
                                          It also needs TT_Lib2 installing.
                                          After the installations of these restart Sketchup to sync everything...
                                          Run it with the Ruby Console open to see if there are any errors...
                                          • 11
                                          • 11 / 11
