    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      babak
      @fedser said:
      @TIG
      This action does not solve the problem. I always install SU with administrator rights. I tried to install it on another computer. Problem still exists. The "Portrait" plugin also has a problem with svg. The plugin itself is working properly. SU2019 doesn't have this problem. Maybe this problem is only with me, I wanted to know how it works on your SU2020?
      Exactly same problem here with SU 2020. After reinstalling Windows 10 and upgrading Sketchup 2019 to 2020 on a new ssd on my asus notebook INTEL i7-6700 (windows 10 pro 1909), some Fredo6 plugins are missing svg icons.
      I have the same w10 configuration on my Desktop computer AMD RYZEN 7 and everything is absolutely fine.
      Tried upgrading nvidia drivers, downgrading them, reinstalling Sketchup.
      Many thanks for your plugins anyway...
      • fredo6F Offline
        The problem has to do with the default web browser on Windows.
        For whatever reason, SU2020 seems to use an old version of IE which is not compatible with HTML 5 and does not support SVG.
        Why is it OK on SU2019 and not on SU2020 is a mystery.
        I don't know how to help on that. I'll try to get some info.
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v10.0a - 20 Apr 20
          LibFredo6 10.0a is the first release of LibFredo6 for SU2016+.
          All subsequent versions of LibFredo6 will only be maintained for SU2016+. This is due to a recent change in Trimble policy for the releasing of signed extensions.
          For users of Sketchup versions up to SU2015, I have archived the frozen version of LibFredo6 and my other plugin in this post.
            babak
            Problem solved, also I am not sure wether I identified the real cause...
            I installed sketchup 2019 and I observed it installed Microsoft Visual C++ 2015-2019 which was not installed with sketchup 2020 probably.
            Why is a question that I cannot answer but it may be worth exploring for those who are more competent than me.
            I then launched sketchup 2020 and everything was fine. I uninstalled skp 2019 and Fredos's plugins aren't missing anything now.
            Thank you!
            • fredo6F Offline
              Sketchup uses an embedded web-browser which comes from Windows and maybe the VC++. So there is an external dependency.
              Good to hear that it now works.
              • F Offline
                fedser
                @babak
                Just a mystery ... thanks for the solution
                but ...
                Indeed, if you install both SU2019 and SU2020 everything works fine. But if you remove SU2019, the problem reappears. The problem is not in VC++ 2015-2019 (v14.25.28508), I have this package installed earlier than SU2020.
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v10.1a - 27 Apr 20
                  LibFredo6 10.1a is a maintenance release
                  1. Fixes a bug in the interpolation of camera in parallel projections in Animator
                  2. Provide 'eye' icons for Quick Launchers dialogs for Mac
                  • W Offline
                    WaChT79
                    Fredo6 plugins don't work anymore.
                    Have a error message on the front page bij starting Sketchup 2020 on Window 10 pro since I load LibFredo6 - v10.1a.
                    No plugin are available anymore. I have downloading Sketchup 2020 and the Fredo6 plugin again with the same error message as shown below.
                    I ask for help, thanks.
                    Error Loading File C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                    Failed to read RBE/RBS file.
                    Error Loading File Fredo6_!LibFredo6.rb
                    Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                    C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:65:in process' C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:72:in module:LibFredo6_Loader'
                    C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>' Error Loading File Fredo6_FredoSpline.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in -'
                    • fredo6F Offline
                      Very strange, because you get the infamous message "Failed to read RBE/RBS file.", which usually comes from a permissions problem arising from the incorrect installation of Sketchup itself (you must Run the installer's exe as Administrator).
                      Did you try to reinstall Sketchup?
                      • W Offline
                        WaChT79
                        I reinstall Sketchup 2020 pro again and also Fredo6 Lib with the same result.
                          For the avoidance of doubt...
                          SketchUp must be installed in a certain way, otherwise weird permission errors can appear unexpectedly.
                          You do not need to reinstall - just do a "Repair", as follows...
                          Here are the steps.
                          Login to Windows as your normal user-account.
                          Ensure that SketchUp/Layout are not running.
                          Find the SketchUp installer's exe file - usually in your Downloads folder ?
                          Select its icon, right-click > context-menu > "Run as administrator"
                          When prompted choose "Repair".
                          When it completes retry SketchUp an see what happens...
                          Installing in any other way causes issues - e.g. never 'Run' an installer's exe file by double-clicking it, or by logging in as the system administrator - BUT if your normal user-account has admin-powers that is OK, but you must always use "Run as administrator" !
                          There have been some reports of Fredo's preferences files getting messed up because of them getting incorrect permissions from a bad SketchUp installation, these aren't fixed by the main installer's exe "Repair".
                          You can delete that hidden folder and it gets recreated when a good SketchUp next runs...
                          So if your problems persist after you have done a "Repair", then you could try this...
                          Close SketchUp, find the following folder...
                          C:\Users\Hugo\AppData\Local\LIBFREDO6_DATA_Dir
                          Delete the folder and its contents...
                          Restart SketchUp...
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v10.2a - 29 Apr 20
                            LibFredo6 10.2a is a maintenance release fixing various issues, for FredoSpline and generic
                            • W Offline
                              WaChT79
                              TIG,
                              Bad news, the error message is always there after doing:
                              I erase Sketchup from my computer, folders, projects and plugins,
                              I erase Sketchup also from my downloads,
                              I redownload Sketchup 2020 Pro from my Sketchup account,
                              I reinstall Sketchup 2020 Pro via the context-menu as Administrator,
                              It goes very well and without any problems,
                              After launching the error message appear on the first page.
                              Error Loading File C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_advancedcameratools/actloader.rbe
                              Error Loading File C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe
                              Error Loading File C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_sandbox/sandboxmenus.rbe
                              Error Loading File C:/Users/Hugo/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_trimble_connect/boot.rbe
                              As you can see I erased all plugins from Fredo6 without succes.
                              • fredo6F Offline
                                As TIG said, this is not a problem with the plugins (mine or someone else's) but with the installation of Sketchup.
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v10.3a - 29 Apr 20
                                  LibFredo6 10.3a is a maintenance release fixing various issues, for FredoSpline and generic, as well as some side-effects on Curviloft and Curvizard.
                                  • W Offline
                                    WaChT79
                                    Thanks for your help.
                                    I will ask it Sketchup.
                                    I am very happy with the plugins from Fredo6 and they give always plain satisfaction.
                                      Hugo / Pencil
                                      I'll continue over at SketchUp.com, as it's clearly not an extension issue, because the shipped su_... ones are also failing - strongly indicating a permissions issue...
                                        craigcclick
                                        Trying to install LibFredo6 - v10.3a for the first time, not having installed LibFred06 before. SU Pro/Mac/Mojave. Successfully downloaded, saying it'll open with SU, but I cannot find it anywhere; neither going directly to the Sk'ucation Plug-In Manager, SU/Extension Manager, or ~/Library/Application Support/SU2020/SU/Plugins. I've restarted, quit and restarted several times. Is it my issue or SU?
                                          Craig, extensions aren't opened by SketchUp. They need to be installed. Go to Window>Extension Manager. At the bottom find Install Extension. Click on it, find the downloaded file and install it. Quit out of SketchUp and restart it to make sure it loads correctly. Better, go to Resources at the top of this page, download and install the Sketchucation Plugin Store. Then use it to install extensions from Sketchucation. That will automatically install them without cluttering your Downloads folder and it'll make it easier to keep track of updates.
                                            As Dave R says [beat me to the draw !]
                                            It's your problem...
                                            This all depends on your browser settings on how to deal with downloaded file-types.
                                            It looks like you have set downloaded extension's RBZ files to be opened with SketchUp.
                                            This is completely wrong.
                                            All RBZ downloads should be set to save - usually these end up in your Downloads folder.
                                            You then use the native Extension Manager > Install Extension button ... navigate to/choose the RBZ file and auto-install it.
                                            All of the necessary files/folders are downloaded into the right places without you having to do anything further...
                                            In the case of a 'Lib' you need to restart SketchUp to get everything in sync...
                                            A 'Lib' does nothing on its own.
                                            It's a collection of code that add functionality to other related extensions.
                                            So to get any useful you need to download/install one of Fredo's other extensions, which will then use the appropriate parts of the Lib to do their magic...
                                            If you download the SketchUcation Toolset's RBZ and install that as outlined above, then it creates a menu-entry / toolbar which opens a dialog which lets you browse through all of the [hundreds of] Plugins/Extensions housed at SketchUcation - e.g. Fredo's or mine... - and then one-click auto-install them, without worrying about manually getting the RBZ file at all !
                                            It also has update reminders etc...
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 108
                                            • 109
                                            • 103 / 109
