    Proxies from Maxtree are not loading
    renderpluginsextensions
    4 Posts 3 Posters 5.2k Views 3 Watching
    • K
      KikoIta
      Hi there,
      So I wanted to test some of Maxtree beautiful trees so I downloaded some free samples. I use Sketchup and Vray so I need to convert the FBX trees with Transmurt to Sketchup then since they are HUUUUGE I open the file once (between 1 to 4 GB) and I convert them to PROXY and add them on my library in Vray.
      Now I converted 3 species about 6 different model from each plant. the first and second group work perfectly but the third one....made with the same steps is now working properly. I can load max 2 models of that group, can be the 1 and 2 or the 4 and 6 or the 3 and 6 doesn't matter which but load only 2 of them in vray. I don't understand why does that.
      I tested each of them and they all work on a single file with max 2 of them per file
      I cancel them all and re-make all the proxy from scratch but still the same thing I can load only 2 of them
      Group 1 and 2 I can load them all in a single file and they are 13 different proxy
      Anyone knows what I'm doing wrong?
      • GD3DesignG
        GD3Design
        Are you rendering on GPU? If so, does your GPU have enough RAM capacity handle the scene? (when you say 'load', do you mean importing them into the skp drawing or actually rendering?)
        • jiminy-billy-bobJ
          jiminy-billy-bob
          As you use Transmutr, you can export then directly as V-Ray proxies: https://help.transmutr.com/manual/geometry-tab/proxies
          • K
            KikoIta
            I don't think it's a problem with transmurt.... the proxy are working but I cannot load more than 2 on a sketchup file after when I drag them from the library to the file nothing is happening
            GD3Design is not a rendering problem I just cannot load the geometry on the file
