[Plugin][$] FredoCorner - v2.7a - 31 Mar 24
@mrkidd said:
error message every time.
What's the error message?
Did you install the current version of LibFredo6 which is required by FredoCorner? See Fredo's post immediately before yours.
NEW RELEASE: FredoCorner v1.7b - 02 Nov 19
Requirement: LibFredo6 9.1b
FredoCorner 1.7b for bug fixing.
Please note that, in the current version of FredoCorner:
- there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
- there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
- Terminal corners (that is ending on a single edge) may present issues and bugs
- No documentation yet, so watch the videos that I will publish.
Please report issues, questions and any feedback in the present thread
Home Page of FredoCorner for information and Download.
What was the exact error message? Did you also install the required LibFredo6 files?
I was excited to use this plugin but after installing and restarting sketchup I got an error message stating there was an error loading, could not find loader file. Help!
Yes, I installed the "lib" file.
Error message:
Error Loading File Fredo6_FredoCorner/__loader__FredoCorner
Could not find included file 'Fredo6_FredoCorner/__loader__FredoCorner' -
NEW RELEASE: FredoCorner v1.7c - 21 Dec 19
FredoCorner 1.7c for extenson of validity.
Hi Fredo,
I get this message when using bevel (same for Round) when selecting three edges.
Is this tool limit so it just can´t do or I am doing something wrong here?Also,
Thank You very much for all the plugins you have created and made my work easier doing so.
This seems to be a limitation of FredoCorner. I can reproduce it on my computer.
The message is not informative, because, when there is a problem in the geometry, FredoCorner assumes that it could come from an offset which is too large. I know where the error happens, but this seems to be an issue in the heart of the algorithm, which is quite complex for this type of geometry. So I put your model in the stack of models I have already for when I'll dig into FredoCorner deep core to see how to make it more robust.
At a first glance, I am scratching my head on what could be the correct result with a selection of only 3 edges at this 6-edge corner, convex / concave.
It works fine however if you select the 6 edges.
HI, today I just installed latest FredoCorner 1.7c and the Library 9.5c (Fredo6_!LibFredo6) folder and ruby files in the proper location – User > Library > Application Support > SketchUp > Plugins.
The Extension Manager says they are installed and active. And I see it in the Sketchup menu. But (after making a cube and selecting it, to test) when I click on the FredoCorner menu icon, or choose it from the menu, nothing happens. The FredoCorner menu does not come up at all.
I tried uninstalling and reinstalling the plugins, quitting and restarting Sketchup a few times. Still nothing.
Please help!
Cheers,
Mike -
Could you open the Ruby console to see if there are errors displayed.
This is fabulous, I have been going nuts trying to fudge fillets on my models. Now I can do it easily. I have added the extension, although it is telling me I need LibFredo6 9.1b. Which I can't find anywhere. Thanks in advance for any help here.
Mim
Cant open sketchup when this is in the folder. It crashes Sketchup as soon as i start it. When i remove FredoCorner from the extensions folder Sketchup is able to run again. Wierd
I Donno why it's showing this comment, its not a group, nor a component...
Any one can help?
Yes its done
Its rectified.
"EDGE PROF. FILTER " WAS NOT SELECTED
NEW RELEASE: FredoCorner v1.7d - 18 Feb 20
FredoCorner 1.7d for extenson of validity.
It's a great plagin indeed, I used it for a short period of time. But now I can't get it work at all ((( I installed the latest versions of both LibFredo6 and FredoCorner plugins. The FredoCorner toolbar shows up but when I try to click on it nothing happens ((( I reinstalled SU and plugins, but still the problem is there (( Please, help me make it work!!! Thank you in advance for all your help and guidance!
What version of SketchUp are you using? Your profile indicates a version that doesn't exist and that could be the cause.
Dave, I use SketchUp 2018 Pro version. It has to be compatible with FredoCorner, at least the notation to the plugin says that.
FredoCorner works on SU2018.
Can you open the Ruby console before you launch FredoCorner. Thanks.
