[Plugin] Universal Importer - v1.2.4 - 28 April 2024
Well re-installing Microsoft Visual C++ library with stl files. Thanks for the help.
1.1.3 version allows you, during import, to reassign textures which are not referenced nor embedded in model.
Download latest Universal Importer plugin from SketchUcation PluginStore.
@einstein said:
Hi, Samuel!
Hi Einstein!
@einstein said:
I have reinstalled MS Visual C++ as you advised and now I can import stuff Thank you!
@einstein said:
- The plugin always asks how big the imported model should be. It doesn't preserve its original size.
Scaling feature doesn't work for all formats.
@einstein said:
- I was thinking of remesher tool as one working on selection, which would be more comfortable than remeshing entire model, as it goes now.
I tried to make it work with selection only but I don't know why it was VERY slow. So I gave up this idea...
@einstein said:
- When I import a model with multiple textures, I can only select one texture file and that texture is applied.
Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one). I'm attaching both OBJ and FBX version of the model.
I inspected attached model. Indeed, it doesn't reference any texture.
In this case: you have to remap textures in a external software before importing model in SketchUp.Since v1.1.3, it's no more an issue. -
@einstein said:
3. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
[...]Einstein, your issue has been fixed with 1.1.3 version of plugin.
hi samuel thanks a lot for this amazing plugin
but sadly it seems not workin with me for some reasoni try use the plugin for importing an .blend .obj and .dae but none of them work
and i got some error ( i attach the image error)if u not busy please help me and once again thanks a lot
im using mac os high siera , sketchup 2019, and blender 2.81a
The .blend files of 2.80 don't work dought to changes in the API, try with .blend files of Blender 2.79, for me these work fine.
Samuel , really the Model height (cm) option do something, I changed this parameter to different values but the imported model has the same dimensions always.
Hi Oxer! This feature works pretty well on Windows. I don't know why it doesn't work at all on macOS.
1.1.4 version fixes rendering of some high-density models (typically trees).
In the image the height issue on Mac.
Hello man, thanks in advance for the app.
But every time I try to import an FBX, messages like that appear.Universal Importer Error: Command failed: "C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/Assimp/Win/assim p.exe- info 'C:WrogramData/Universal Importer/tmp/import.FEOC > "C:WrogramData/Universal Importer/tmp/assimp.nfo-
C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/assimp.rb:166:in 'get_texture_refs'
Universal Importer Version: 1.1.4 -
Universal Importer Version: 1.1.4"WrogramData"?
Does it actually say "WrogramData" instead of "ProgramData"?
Universal Importer Version: 1.1.4Hello. Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
Hello. Importer Error. What does that mean
Maybe this has been asked, I tried to search it just in case, so apologies if it has been answered already... Is there any plan to support PDF in the future? Lack of PDF import to Windows Sketchup boggles my mind.
Hello @kostiaarh. This sounds like a bug. Could you please upload your model to a file hoster? This way I could debug it.
Yes. I uploaded the file. Thanks you.
https://mega.nz/#!WKZDkYSA!3HFXWqZTRpVGt_tUftP-i639I5TpToyvc4lG9apMFTA -
Hi, iI installed the latest version of the plugin and it does not work on mac os ((
There's no plan to support PDF in future.
