    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    441 Posts 106 Posters 432.3k Views 106 Watching
    • samuel_tS Offline
      samuel_t
      @ahmed0007 said:
      i tried on another pc and get this error
      and on one another file get "model is too big error" model size was 11mb
      Reinstall Microsoft Visual C++ library on this another computer then upgrade to v1.0.7 of plugin.
        Ahmed0007
        WoW ๐Ÿ˜ฎ
        Everything is working fine again ๐ŸŽ‰
        Thank you Sooo Much!!!
        • E Offline
          Einstein
          @samuel_t said:
          @einstein said:
          Hi!
          I downloaded the latest update but I'm still getting the same bug with every file format. I cannot import any file to SketchUp ๐Ÿ˜ž
          Hi!
          Could you please upload your model (textures included) to a file hoster or here? So I could debug it.
          I'm attaching one of the models I was trying to import (it's a free model from TurboSquid). But I also tried to import a model that was posted earlier in this thread. None of them worked, even with v1.0.7 - the same bug report.
          If I don't want textures when it asks me about them, shall I just press "Cancel"?
          tree1_3ds.rar
            I believe if your model has yet Textures even you cancel, you will have original textures !
            If it's just "colored" it will keep its colors...
            • samuel_tS Offline
              samuel_t
              @einstein said:
              @samuel_t said:
              @einstein said:
              Hi!
              Hi!
              I can import model you attached in my computer. (There's still issue with leaves. SketchUp import bugs sometimes. If you don't want textures: it's OK.) So, problem comes most problably from your computer.
              Reinstall Microsoft Visual C++ library then reimport model. Please let me know if problem persists.
              I you don't want textures: you can remove textures after import by using Materials Tray in SketchUp.
                Your file works fine for me too! ๐Ÿ˜„
                Import without Texture and reduce to 500 faces! ๐Ÿค“
                as I did'nt ask statistics maybe your file had less 500 faces! ๐Ÿ˜„
                Edit asked : so...original was 81 000 faces!
                hum hum 50 000 faces after the decimate reduction to 500 faces asked ?
                there is not something curious ? ๐Ÿ’š
                https://i.postimg.cc/02b7Y5Wj/tita.jpg
                  Ahmed0007
                  Error ๐Ÿ˜•
                  .glb 7.9mb
                  Model is here : https://www.dropbox.com/s/bte329pn42gs5px/80005e0d-0006-f600-b63f-84710c7967bb.zip?dl=0
                    Ahmed0007
                    @samuel_t said:
                    @ahmed0007 said:
                    Error ๐Ÿ˜•
                    .glb 7.9mb
                    This error happens because textures are embedded in model. So I've extracted and relinked them...
                    You can download fixed model here. Click on "Valider et tรฉlรฉcharger le fichier".
                    There's no automatic fix for now. ๐Ÿ˜•
                    Thank you!
                      Ahmed0007
                      any other way to donate? paypal is not available in my country.
                      • samuel_tS Offline
                        samuel_t
                        Bank transfer. I can send you my IBAN in PM if you want to make a donation without PayPal.
                          Ahmed0007
                          sure!
                          • samuel_tS Offline
                            samuel_t
                            @oxer said:
                            @einstein said:
                            By the way, I think it would be cool to also have polygon reduction as standalone tool for meshes that already exist in SketchUp. Because we haven't had a decent free polyreducer in SketchUp so far. It's just a suggestion.
                            It's a good idea ๐Ÿ‘
                            This idea was implemented in v1.0.8. cf. Toolbar.
                            • samuel_tS Offline
                              samuel_t
                              @ahmed0007 said:
                              Error ๐Ÿ˜•
                              .glb 7.9mb
                              You can download fixed model here. Click on "Valider et tรฉlรฉcharger le fichier" button.
                              There's no automatic fix for now. Since v1.0.8, this issue is automatically fixed.
                              • samuel_tS Offline
                                samuel_t
                                1.0.8 version:
                                • Allows you to apply a polygon reduction on current SketchUp model via toolbar.
                                • Fixes model import with embedded textures. Up to 10 textures are supported.
                                • Names imported model with original filename. This should eases management.
                                Download latest Universal Importer plugin from SketchUcation PluginStore.
                                • jiminy-billy-bobJ Offline
                                  jiminy-billy-bob
                                  @samuel_t said:
                                  Famous plugins like Artisan and Skatter are using C:\ProgramData. This isn't a problem.
                                  For Skatter, we use ProgramData only for the initial install, not for temp files.
                                  • samuel_tS Offline
                                    samuel_t
                                    OK.
                                      Khai
                                      for a future time, any chance of supporting grouping of imported meshes?
                                      • samuel_tS Offline
                                        samuel_t
                                        Chances are low since mesh hierarchy is lost during conversion. ๐Ÿ˜•
                                          Khai
                                          oh. not good.. since if you import a mesh in sections rather than in a hierachy, the way that SU places it in scene - you manually placing it instead of just in position - makes lining it all up again a nightmare if you've got large sets...
                                          hmm no matter.... I can work round it...
                                          • samuel_tS Offline
                                            samuel_t
                                            1.0.9 version:
                                            • Supports up to 1000 embedded textures.
                                            • Shows face count before/after reduction.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
