    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 628.9k Views 113 Watching
    • samuel_tS
      samuel_t
      @ahmed0007 said:
      @samuel_t said:
      @ahmed0007 said:
      @samuel_t said:
      @ahmed0007 said:
      @samuel_t said:
      @ahmed0007 said:
      i import this model with v1.0.1 without any problem but v1.0.6 give me this error why?
      please help.
      In recent versions of plugin there's a mechanism that prevents copy of a too big folder. To fix this issue: Create a sub folder in your Documents then place model and textures inside that sub folder. Re-import.
      Still Same error ?
      What's size of model in MB?
      8 mb
      OK. Could you please post a screen capture of folder containing model (aka a Windows Explorer view)?
      C:\Users\Ahmed\Documents\New folder (2)
      Everything seems OK. I don't understand why you can't import... ๐Ÿ˜• There are no hidden files, isn't?
        Ahmed0007
        Everything seems OK. I don't understand why you can't import... ๐Ÿ˜• There are no hidden files, isn't?[/quote]
        did you try this on your own pc
        No! There are no hidden files
        i think i should stick with older version.
        • samuel_tS
          samuel_t
          Yes. I tried to import a model with this path: "C:\Users\Samuel\Documents\New folder (2)" and it's OK.
          • samuel_tS
            samuel_t
            @Ahmed0007
            Could you please upload your model to a file hoster? This way I can verify if the model is the problem.
            • TutorialsUpT
              TutorialsUp
                Ahmed0007
                @samuel_t said:
                @Ahmed0007
                i uplode the model in my first comment
                • samuel_tS
                  samuel_t
                  @tutorialsup said:
                  Now i'm also unable to import this model again
                  https://www.youtube.com/watch?v=owXwypsZIHY
                  file type .obj
                  size 110 mb
                  located in Documents folder \Documents\obj 2
                  OK. I'm gonna release a hotfixed version.
                    Ahmed0007
                    i tried on another pc and get this error
                    and on one another file get "model is too big error" model size was 11mb
                    • samuel_tS
                      samuel_t
                      1.0.7 version fixes "anti big copy" bug.
                      Download latest Universal Importer plugin from SketchUcation PluginStore.
                      • samuel_tS
                        samuel_t
                        Reinstall Microsoft Visual C++ library on this another computer then upgrade to v1.0.7 of plugin.
                          Ahmed0007
                          WoW ๐Ÿ˜ฎ
                          Everything is working fine again ๐ŸŽ‰
                          Thank you Sooo Much!!!
                          • E
                            Einstein
                            @samuel_t said:
                            @einstein said:
                            Hi!
                            I downloaded the latest update but I'm still getting the same bug with every file format. I cannot import any file to SketchUp ๐Ÿ˜ž
                            Hi!
                            Could you please upload your model (textures included) to a file hoster or here? So I could debug it.
                            I'm attaching one of the models I was trying to import (it's a free model from TurboSquid). But I also tried to import a model that was posted earlier in this thread. None of them worked, even with v1.0.7 - the same bug report.
                            If I don't want textures when it asks me about them, shall I just press "Cancel"?
                            tree1_3ds.rar
                              I believe if your model has yet Textures even you cancel, you will have original textures !
                              If it's just "colored" it will keep its colors...
                              • samuel_tS
                                samuel_t
                                @einstein said:
                                @samuel_t said:
                                @einstein said:
                                Hi!
                                Hi!
                                I can import model you attached in my computer. (There's still issue with leaves. SketchUp import bugs sometimes. If you don't want textures: it's OK.) So, problem comes most problably from your computer.
                                Reinstall Microsoft Visual C++ library then reimport model. Please let me know if problem persists.
                                I you don't want textures: you can remove textures after import by using Materials Tray in SketchUp.
                                  Your file works fine for me too! ๐Ÿ˜„
                                  Import without Texture and reduce to 500 faces! ๐Ÿค“
                                  as I did'nt ask statistics maybe your file had less 500 faces! ๐Ÿ˜„
                                  Edit asked : so...original was 81 000 faces!
                                  hum hum 50 000 faces after the decimate reduction to 500 faces asked ?
                                  there is not something curious ? ๐Ÿ’š
                                  https://i.postimg.cc/02b7Y5Wj/tita.jpg
                                    Ahmed0007
                                    Error ๐Ÿ˜•
                                    .glb 7.9mb
                                    Model is here : https://www.dropbox.com/s/bte329pn42gs5px/80005e0d-0006-f600-b63f-84710c7967bb.zip?dl=0
                                      Ahmed0007
                                      @samuel_t said:
                                      @ahmed0007 said:
                                      Error ๐Ÿ˜•
                                      .glb 7.9mb
                                      This error happens because textures are embedded in model. So I've extracted and relinked them...
                                      You can download fixed model here. Click on "Valider et tรฉlรฉcharger le fichier".
                                      There's no automatic fix for now. ๐Ÿ˜•
                                      Thank you!
                                        Ahmed0007
                                        any other way to donate? paypal is not available in my country.
                                        • samuel_tS
                                          samuel_t
                                          Bank transfer. I can send you my IBAN in PM if you want to make a donation without PayPal.
                                            Ahmed0007
                                            sure!
                                            • 22
                                            • 23
                                            • 4 / 23
