    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    2D Export / width height ratio
    12 Posts 4 Posters 2.5k Views 4 Watching
    • HornOxxH Offline
      HornOxx
      Hi everyone - is there any way to do a 2D export with a really user defined width to height ratio, completely independent from the currently used SkUp viewport?
      Or is there an alternative option to fix the SU viewport to a desired ratio (e.g. 1920 x1080)?
      never trust a skinny cook
        You could use Eneroth Viewport Resizer to adjust the aspect ratio of the viewport to match the aspect ratio of your desired image export.
          Charlie__V
          Perhaps Fredo Portrait
          Charlie
          • HornOxxH Offline
            HornOxx
            ๐Ÿ‘ ๐Ÿ‘ Thanks to both of you Dave and Charlie__V ๐Ÿ˜„
            Dave, suggesting Enerothยดs Viewport Resizer was so valuable, worked perfectly and is exactly what I was looking for!
            Since my screen can't display the viewport in HD resolution 1920x1080, I took the half of each value - 960x540. For the export from sketchup itself, only the ratio of width to height counts ๐Ÿ˜‰
              That works. For my example, I figured out the viewport width based on the available height.
              Out of curiosity, which version of 2019 are you running? Do you see the difference in the export options between yours and mine? Mine does show the options for PNG export instead of JPG export. With JPG there is the quality slider, still.
              • PixeroP Offline
                Pixero
                There is also this plugin Safe Frame Tools.
                https://s3-us-west-2.amazonaws.com/assets.sketchup.com/web/ewh/s3fs-public/UI_0.png
                • HornOxxH Offline
                  HornOxx
                  ...thanks Pixero for this additional hint. Do you know whether the in this tool entered Width - Hight values will be applied to the SkUp 2D export then? or is it an "exporter" itself?
                  • PixeroP Offline
                    Pixero
                    I haven't used that feature yet so I can't say. I have only used it to set the aspect ratio of the SU Scene to be able to match in Enscape better.
                    • HornOxxH Offline
                      HornOxx
                      @pixero said:
                      ... I have only used it to set the aspect ratio of the SU Scene to be able to match in Enscape better.
                      Thatยดs funny Pixero - exactly this somehow only half-finished Enscape thing was the reason for my question here ๐Ÿ˜‰ ๐Ÿ˜„ ๐Ÿ˜„
                      (Daveยดs Eneroth proposal above worked wonderfully, also for videos)
                      • HornOxxH Offline
                        HornOxx
                        @dave r said:
                        ...Out of curiosity, which version of 2019 are you running? Do you see the difference in the export options between yours and mine? Mine does show the options for PNG export instead of JPG export. With JPG there is the quality slider, still.
                        if you hadn't asked Dave, I wouldn't have noticed the difference ๐Ÿ˜‰. So I assume you're using a newer SU2019 version? (What is a "Line scale multplier"?)
                        These are my png and jpg export options and my SU-version information:
                          It looks like you've missed all three maintenance releases. The current version is 19.3.253. In one of those releases they added the Line Scale Multiplier for line raster exports. This allows you to control how heavy lines appear in the image export. This is especially useful when exporting at larger sizes. Here is an example. The original images were exported as .png at 4000 pixels wide. The compression slider is still there for .jpg exports.
                          On the left, the LSM is set to 1.00:
                          On the right it is set to 3.00:
                          • HornOxxH Offline
                            HornOxx
                            wow - and thanks for this lines representation which is a really nice option (for me updating is like fashion - lots of room for improvements ๐Ÿ˜„ ๐Ÿ˜„ )
