    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 457.1k Views 109 Watching
    • Rich O BrienR Online
      Here's a simple cube saved in Blender 3.5 that fails to import...
      cube.zip
        rv1974
        U r Da Beast πŸ˜„
          @rv1974 said:
          U r Da Beast πŸ˜„
          Beware.....because I do bite
          • samuel_tS Offline
            samuel_t
            [attachment=0:hhrjer15]<!-- ia0 -->cube.zip<!-- ia0 -->[/attachment:hhrjer15]
            Indeed Rich, Universal Importer passes Blender 3.4.1 cube test but not Blender 3.5.0 one.
            Thanks for your report πŸ˜‰
            • samuel_tS Offline
              samuel_t
              1.2.2 version deletes temporary hard links and temporary files possibly left after an import fail or a polygon reduction fail.
              Download latest Universal Importer plugin from SketchUcation PluginStore.
                ankitdarda
                Could you also include Revit .RVT import with textures as well????? Thanks in advance
                thank you !!!
                feel free to click on my site http://www.ankitfolio.co.cc includes my blog page link within it
                :sunglasses:
                ankitdarda
                • samuel_tS Offline
                  samuel_t
                  There is little chance that the RVT (Revit) format will ever be supported by the Universal Importer plugin.
                  However, there is a paid add-in for Revit that allows you to export a Revit model and its textures to SketchUp.
                    M_Schulze Newcomers
                    Universal Importer V1.2.2 does not import any stl file. Universal Import Error: No such file or directory @ rb_sysopen - C:/3D/bottle-opener/uir-inter.mtl
                    C:Users/ABC/. . ./SketchUp/Plugins/universal_importer/import.rb:170:in'read'
                    Please help (Sketchup Make 2017, Windows 10)
                    M_S
                    • samuel_tS Offline
                      samuel_t
                      M_S
                      Could you please send me this STL file via Dropbox, for example?
                        Poltava Newcomers
                        Can't download plugin on Sketchucation page...
                          Poltava Newcomers
                            Yes, we are working on restoring the amazon server bucket that hold the downloads.
                            Shouldn't take long.
                              Poltava Newcomers
                              Does not want to export FBX and other files. Reinstalling doesn't help
                              Screenshot
                              • samuel_tS Offline
                                samuel_t
                                Try importing a 3D model stored in a folder to which you have write access.
                                  rizkymfadh19 Newcomers
                                  this amazed me, really thank you for the plugin πŸ‘ πŸ‘
                                  • samuel_tS Offline
                                    samuel_t
                                    I'm glad to hear that! πŸ˜„
                                      Sondre_S
                                      Hi, I've used Universal Importer for about a month now and I'm suddenly getting an error saying it doesn't have write access to my documents folder (or any other folder for that matter). The only place it would import from was the root of my C drive! I checked and all folders are marked as "Read Only", but all other programs work correctly.
                                      I opened import.rb and commented out this:
                                      # Source dir must be writable to host hard links we'll create later.
                                            #raise "Source dir of model to import is not writable; #{@source_dir}"\
                                             # unless File.writable?(@source_dir)
                                      and I can now import from my documents folder again.
                                      I found this in an article from Microsoft:
                                      "The Read-only and System attributes is only used by Windows Explorer to determine whether the folder is a special folder, such as a system folder that has its view customized by Windows (for example, My Documents, Favorites, Fonts, Downloaded Program Files), or a folder that you customized by using the Customize tab of the folder's Properties dialog box. As a result, Windows Explorer does not allow you to view or change the Read-only or System attributes of folders."
                                      What does it mean if Windows isn't supported? - Microsoft Support
                                      Learn what it means if you have an older version of Windows that's no longer supported.
                                      (support.microsoft.com)
                                      • samuel_tS Offline
                                        samuel_t
                                        @Sondre_S
                                        Thanks for the technical details. I will solve this problem as soon as possible.
                                        • samuel_tS Offline
                                          samuel_t
                                          1.2.3 version doesn't display anymore the "Source dir of model to import is not writable" error message.
                                            romanencom Newcomers
                                            Dear samuel_t, I just installed your plugin, but I can't import the step file, I get this message. At the same time, a duplicate of it with a different name is created in the folder with this file. You can help me?
                                            U 1 Reply Last reply Reply Quote 0
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
