    Visualizer for SketchUp
    extensions
    157 Posts 37 Posters 147.6k Views 37 Watching
      driven
      the 2016 tricks will not work for this or any plugin that cannot be updated to run on Ruby 2.2...
      there is no legal way around this for encrypted extensions...
      • masterpaulM
        masterpaul
        Yep its busted.
        I wish they released the program as opensource.
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/Extensions/IRExtension2015x64.so>
        C;/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;54;in `require'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs;67;in `<module;ImgTecVis>'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs;10;in `<main>'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;5;in `eval'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;5;in `require'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;5;in `<top (required)>'
        C;/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb;197;in `require'
        C;/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb;197;in `load'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb;25;in `register_extension'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb;25;in `<module;ImgTecVis>'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb;14;in `<top (required)>'
        Error; #<NoMethodError; undefined method `get_imgtec_rnd_api' for nil;NilClass>
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs;23;in `irapi'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs;26;in `<module;ImgTecVis>'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs;10;in `<main>'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;9;in `eval'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;9;in `require'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;9;in `<main>'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;6;in `eval'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;6;in `require'
        C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;6;in `<top (required)>'
        Error; #<NoMethodError; undefined method `enable_statistics' for nil;NilClass>
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;93;in `<module;ImgTecVis>'
        c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;12;in `<main>'
          spadestick
          The Visualizer website is down! Does anyone have a list of enhanced material names for the different reflection levels?
          I only remember gloss and matte
          I recall paint plastic / metal somewhere...
          thanks-heaps!
          • V
            vidy
            thanks-heaps!
            Hi Spade,
            it's still there, check out this link: http://getvisualizer.com/blog/enhanced-materials.html
            Regards,
            VD
            still so much to learn..
              And for French speaking! πŸ˜‰
              • N
                Nathans
                Any luck with visualiser on sketch pro 2018 and windows 10?!
                  Works on Windows 10 only till SU 2016 ! πŸ€“
                  • N
                    Nick1
                    Has anyone been able to render a sand blasted/ frosted glass in Visualizer. I have tested lots of different ways and no proper results. I know the software is somehow limited in some ways, but I thought maybe someone has been successful with a setting for frosted glass or sand blasted glass that would actually render properly in Visualizer.
                      Not used for a long time but you can maybe use 2 transparent (or more) glassed surfaces each with different regulates? (not tested)
                        I have Visualizer but would like to install it on sketchup 2016, how can I do this? Please.
                          Thank you, Sir.
                            Sorry it's in French but with Deepl no problem for translate it! πŸ˜„
                            Else why not use the free Real Time Render SimLab Composer Lite ? (Maxi 1920 *1080)
                            It's many more powerful and so easy! πŸ˜‰
                            https://i.postimg.cc/0NHmZxRp/ploof.jpg
                            https://i.postimg.cc/ydgXyddR/crepe02.jpg
                              And you have the Free Integration / SketchUp / SimLab! πŸ˜‰
                              • pbacotP
                                That's actually a good question. I have had visualizer for multiple versions of SU. I could generally activate it and disable with SketchUcation tools. That would indicate that an .rb is involved. I thought I just transferred the .rb for new versions. So I just looked. I cannot find an associated .rb in any of my versions, and it is not shown any longer in 2019 SketchUcation managers. So my guess is you must download the installer and install it to your system again.
                                  Re downloading and installing, it's no good, I still have the last release and it does not install in Sketchup versions after 2015 out of the box. The method above works well though.
                                  C/users/programdata/sketchup/sketchup version/plugins. The folder and rb are there.
                                  • 8 / 8
