    Visualizer for SketchUp
    extensions
    157 Posts 37 Posters 126.4k Views 37 Watching
      Seems Visualizer don't works on 2017 with the previous tricks of installation 2015 - 2016 ! 😮
      • jujuJ Offline
        juju
        somehow I am not surprised
        I'm wondering how many other extensions / plugins will be problematic
        • V Offline
          vico44
          It was working with The 2016 on OS X
          Pour cela il fallait juste copier l'ancienne installation sur /Bibliothèque/Application Support/Sketchup 2016/
          (Pas dans User/Biblithéque/Application Support/Sketchup 2016/ mais à la racine du disque)
          Cela ne marche pas pour Sketchup 2017
            driven
            the 2016 tricks will not work for this or any plugin that cannot be updated to run on Ruby 2.2...
            there is no legal way around this for encrypted extensions...
            • masterpaulM Offline
              masterpaul
              Yep its busted.
              I wish they released the program as opensource.
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/Extensions/IRExtension2015x64.so>
              C;/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb;54;in `require'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs;67;in `<module;ImgTecVis>'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs;10;in `<main>'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;5;in `eval'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;5;in `require'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;5;in `<top (required)>'
              C;/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb;197;in `require'
              C;/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb;197;in `load'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb;25;in `register_extension'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb;25;in `<module;ImgTecVis>'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb;14;in `<top (required)>'
              Error; #<NoMethodError; undefined method `get_imgtec_rnd_api' for nil;NilClass>
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs;23;in `irapi'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs;26;in `<module;ImgTecVis>'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs;10;in `<main>'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;9;in `eval'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;9;in `require'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;9;in `<main>'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;6;in `eval'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;6;in `require'
              C;/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb;6;in `<top (required)>'
              Error; #<NoMethodError; undefined method `enable_statistics' for nil;NilClass>
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;93;in `<module;ImgTecVis>'
              c;/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs;12;in `<main>'
                spadestick
                The Visualizer website is down! Does anyone have a list of enhanced material names for the different reflection levels?
                I only remember gloss and matte
                I recall paint plastic / metal somewhere...
                thanks-heaps!
                • V Offline
                  vidy
                  thanks-heaps!
                  Hi Spade,
                  it's still there, check out this link: http://getvisualizer.com/blog/enhanced-materials.html
                  Regards,
                  VD
                  still so much to learn..
                    And for French speaking! 😉
                    • N Offline
                      Nathans
                      Any luck with visualiser on sketch pro 2018 and windows 10?!
                        Works on Windows 10 only till SU 2016 ! 🤓
                        • N Offline
                          Nick1
                          Has anyone been able to render a sand blasted/ frosted glass in Visualizer. I have tested lots of different ways and no proper results. I know the software is somehow limited in some ways, but I thought maybe someone has been successful with a setting for frosted glass or sand blasted glass that would actually render properly in Visualizer.
                            Not used for a long time but you can maybe use 2 transparent (or more) glassed surfaces each with different regulates? (not tested)
                              I have Visualizer but would like to install it on sketchup 2016, how can I do this? Please.
                                Thank you, Sir.
                                  Sorry it's in French but with Deepl no problem for translate it! 😄
                                  Else why not use the free Real Time Render SimLab Composer Lite ? (Maxi 1920 *1080)
                                  It's many more powerful and so easy! 😉
                                  https://i.postimg.cc/0NHmZxRp/ploof.jpg
                                  https://i.postimg.cc/ydgXyddR/crepe02.jpg
                                    And you have the Free Integration / SketchUp / SimLab! 😉
                                    • pbacotP Offline
                                      That's actually a good question. I have had visualizer for multiple versions of SU. I could generally activate it and disable with SketchUcation tools. That would indicate that an .rb is involved. I thought I just transferred the .rb for new versions. So I just looked. I cannot find an associated .rb in any of my versions, and it is not shown any longer in 2019 SketchUcation managers. So my guess is you must download the installer and install it to your system again.
                                        Re downloading and installing, it's no good, I still have the last release and it does not install in Sketchup versions after 2015 out of the box. The method above works well though.
                                        C/users/programdata/sketchup/sketchup version/plugins. The folder and rb are there.
                                        • 8 / 8
