    [Plugin][$] FredoPortrait - v2.9a - 01 Apr 24
    82 Posts 23 Posters 134.0k Views 23 Watching
    • BoxB Offline
      @rv1974 said:
      IDK I constantly flatten things. Unfortunately there's limmitation XY plane only with current plugins.
      Fredo's own Fredoscale, scale to 0.
        Tout pour la Photo! 😎
        • fredo6F Offline
          https://www.facebook.com/curic4sketchup/videos/401289690486464/
          ^ This one is on the way but the littleproblem with the tools from this author they are buggy as hell.
          I am not talking about 2D-projections, but just FaceMe component.
          Projection is another algorithm, which I think is already largely covered by several plugins.
          • fredo6F Offline
            @rv1974 said:
            @fredo6 said:
            ..already largely covered by several plugins.
            for example?
            Didier Bur's Projection...
              rv1974
              for example? TT's flatten selection works only in Z axiz, vertex tools scaling can't produce truely 0.00 scaling
                dtrarch
                Thanks again for another Fredo imagined plugin. πŸ‘ πŸ‘ πŸ‘
                Very special
                dtrarch
                  rv1974
                  Fredo, the plugin is monumental! 😲
                  For 2D components, I'd just suggest:
                  some kind of automaticnaming
                  and option for vector version
                  • fredo6F Offline
                    NEW RELEASE: FredoPortrait v1.2a - 20 Jul 19
                    Requirement: LibFredo6 9.1
                    FredoPortrait 1.2a introduces the generation of 2D Components from 3D objects.
                    Note: this functionality is available for**SU2018 and above**.
                    Note also that, as of v1.2, the resolution of images is specified by its Width in pixel, and no longer by a factor of the viewport width.
                    Home Page of FredoPortrait for information and Download.
                    Main post of this FredoPortrait thread.
                    • fredo6F Offline
                      Difficult, because you can select several objects, including faces, edges, etc... And even if a single object is selected, you may want to choose a specific name.
                      I could of course create component names like '2D Component #1", or even let Sketchup assign a name, etc..., but that's an encouragement to users to have a model full of generaic names, difficult to browse afterward.
                      Not sure what you mean by 'Vector version'.
                        Dhannah
                        ]I am experiencing a strange issue in the Portrait Studio where I cannot Export an image file. I am able to adjust settings all the way up to clicking "Generate Image", and the below image shows.
                        At first, I thought it might just take a little longer. However, I have left and come back 30 minutes later to the same "generating image..." screen.
                        [attachment=0:izitojhj]<!-- ia0 -->fp gen.png[/attachment
                        [attachment=0]open gl.png<!-- ia0 -->[/attachment:izitojhj]
                        Perpetual Loading Screen
                        Open GL Stats
                        • fredo6F Offline
                          Hi Dhannah,
                          This is a bug, which only happens when the File mode is "ask". Thanks for signaling it.
                          I am making a fix, which I published as v1.2b.
                          • fredo6F Offline
                            NEW RELEASE: FredoPortrait v1.2b - 24 Jul 19
                            FredoPortrait 1.2b Fixes a bug preventing to generate image when the File mode is "Ask Filename".
                            • fredo6F Offline
                              NEW RELEASE: FredoPortrait v1.2c - 25 Jul 19
                              FredoPortrait 1.2c includes small GUI adjustments
                                bsfranza
                                hi there,
                                amazing idea and plugin - however i have some "errors" .. when using it, it happens that geometry gets "ubuild" in exactly the manner i have build it.. but reverse.. it kinda reverse engineers my model πŸ˜„
                                funny effect but renders the plugin useless πŸ˜•
                                anyone else with this problem? if the author is interested i can share my screen and show the problem πŸ˜„
                                best, franz
                                • fredo6F Offline
                                  Not sure I understand what is the problem. So it would be helpful to post pictures and possibly attach or PM me the model, also indicating which function of FredoPortrait you use (e.g. Image, Export, 2D component?)
                                    bsfranza
                                    hi there again,
                                    fredo i have sent you a private message with a link to a video i have recoreded, it shows the error..
                                    best, franz
                                    • deaneauD Offline
                                      deaneau
                                      Fredo I was always looking for a plugin like this. Many thanks for this plugin
                                      Fredo J'Γ©tais toujours Γ  la recherche d'un plugin comme celui-ci. Merci beaucoup pour ce plugin
                                      • fredo6F Offline
                                        NEW RELEASE: FredoPortrait v1.3a - 19 Aug 19
                                        FredoPortrait 1.3a includes bug fixing and extend the validity
                                        • ntxdaveN Offline
                                          ntxdave
                                          Fredo, This is a very interesting plugin that I think it very valuable. However, I have a couple questions/comments:
                                          • Am I missing something on the toolbar? Here is a screen shot of the toolbar the way it looks in my 2019.2 Pro version. FredoPortraitMenuBar.png
                                          • Is there any way that this tool could be used in conjunction with Twilight Render? I use Twilight Render to make the materials look more realistic but I would like to use your transparent background feature with the render tool.
                                          Press F1...thank me later
                                          • fredo6F Offline
                                            You can configure the visible icon in the Default Parameters dialog box. By default, you get these 2 icons version 1.3. The other one is just a quick launcher, that would be more useful when I add new features.
                                            Not sure I understand the question. You can set your style with NO or transparent background in Sketchup (all scenes or one particular). Could you elaborate?
                                            • 1 / 5
