    [Plugin][$] FredoPortrait - v2.9a - 01 Apr 24
    86 Posts 24 Posters 137.4k Views 24 Watching
    • fredo6F
      @rv1974 said:
      @fredo6 said:
      ..already largely covered by several plugins.
      for example?
      Didier Bur's Projection...
        rv1974
        for example? TT's flatten selection works only in Z axiz, vertex tools scaling can't produce truely 0.00 scaling
          dtrarch
          Thanks again for another Fredo imagined plugin. πŸ‘ πŸ‘ πŸ‘
          Very special
          dtrarch
            rv1974
            Fredo, the plugin is monumental! 😲
            For 2D components, I'd just suggest:
            some kind of automaticnaming
            and option for vector version
            • fredo6F
              NEW RELEASE: FredoPortrait v1.2a - 20 Jul 19
              Requirement: LibFredo6 9.1
              FredoPortrait 1.2a introduces the generation of 2D Components from 3D objects.
              Note: this functionality is available for**SU2018 and above**.
              Note also that, as of v1.2, the resolution of images is specified by its Width in pixel, and no longer by a factor of the viewport width.
              Home Page of FredoPortrait for information and Download.
              Main post of this FredoPortrait thread.
              • fredo6F
                Difficult, because you can select several objects, including faces, edges, etc... And even if a single object is selected, you may want to choose a specific name.
                I could of course create component names like '2D Component #1", or even let Sketchup assign a name, etc..., but that's an encouragement to users to have a model full of generaic names, difficult to browse afterward.
                Not sure what you mean by 'Vector version'.
                  Dhannah
                  ]I am experiencing a strange issue in the Portrait Studio where I cannot Export an image file. I am able to adjust settings all the way up to clicking "Generate Image", and the below image shows.
                  At first, I thought it might just take a little longer. However, I have left and come back 30 minutes later to the same "generating image..." screen.
                  [attachment=0:izitojhj]<!-- ia0 -->fp gen.png[/attachment
                  [attachment=0]open gl.png<!-- ia0 -->[/attachment:izitojhj]
                  Perpetual Loading Screen
                  Open GL Stats
                  • fredo6F
                    Hi Dhannah,
                    This is a bug, which only happens when the File mode is "ask". Thanks for signaling it.
                    I am making a fix, which I published as v1.2b.
                    • fredo6F
                      NEW RELEASE: FredoPortrait v1.2b - 24 Jul 19
                      FredoPortrait 1.2b Fixes a bug preventing to generate image when the File mode is "Ask Filename".
                      • fredo6F
                        NEW RELEASE: FredoPortrait v1.2c - 25 Jul 19
                        FredoPortrait 1.2c includes small GUI adjustments
                        • B
                          bsfranza
                          hi there,
                          amazing idea and plugin - however i have some "errors" .. when using it, it happens that geometry gets "ubuild" in exactly the manner i have build it.. but reverse.. it kinda reverse engineers my model πŸ˜„
                          funny effect but renders the plugin useless πŸ˜•
                          anyone else with this problem? if the author is interested i can share my screen and show the problem πŸ˜„
                          best, franz
                          • fredo6F
                            Not sure I understand what is the problem. So it would be helpful to post pictures and possibly attach or PM me the model, also indicating which function of FredoPortrait you use (e.g. Image, Export, 2D component?)
                            • B
                              bsfranza
                              hi there again,
                              fredo i have sent you a private message with a link to a video i have recoreded, it shows the error..
                              best, franz
                              • deaneauD
                                deaneau
                                Fredo I was always looking for a plugin like this. Many thanks for this plugin
                                Fredo J'Γ©tais toujours Γ  la recherche d'un plugin comme celui-ci. Merci beaucoup pour ce plugin
                                • fredo6F
                                  NEW RELEASE: FredoPortrait v1.3a - 19 Aug 19
                                  FredoPortrait 1.3a includes bug fixing and extend the validity
                                  • ntxdaveN
                                    ntxdave
                                    Fredo, This is a very interesting plugin that I think it very valuable. However, I have a couple questions/comments:
                                    • Am I missing something on the toolbar? Here is a screen shot of the toolbar the way it looks in my 2019.2 Pro version. FredoPortraitMenuBar.png
                                    • Is there any way that this tool could be used in conjunction with Twilight Render? I use Twilight Render to make the materials look more realistic but I would like to use your transparent background feature with the render tool.
                                    Press F1...thank me later
                                    • fredo6F
                                      You can configure the visible icon in the Default Parameters dialog box. By default, you get these 2 icons version 1.3. The other one is just a quick launcher, that would be more useful when I add new features.
                                      Not sure I understand the question. You can set your style with NO or transparent background in Sketchup (all scenes or one particular). Could you elaborate?
                                      • ntxdaveN
                                        ntxdave
                                        I want to be able to export/create a rendered image with a transparent background using Twilight Render. I clicked on the export icon but I do not see how to render with TR. My interest here is because TR does not provide the ability to render with a transparent background but it does give me some excellent tools for setting the materials of the objects.
                                        Hopes this makes it a little clearer. I guess the bottom line question is how do I use TR with the export function? I do not see where to specify TR as the render engine (but I admit I have not done a bunch of exploration yet).
                                        • fredo6F
                                          FredoPortrait can generate an image with a transparent background because it produces the image file (the option is available in the Ruby API).
                                          In the case of Twilight Render, it is TR producing the image. So FredoPortrait cannot be of any help for that.
                                          • ntxdaveN
                                            ntxdave
                                            Thanks for the feedback Fredo. I wish the was a way to get some better looking materials in SU. I really like this plugin though.
                                            BTW: I reached out to Twilight yesterday about this plugin. Hope they contact you about it. 😐
                                            • 1 / 5
