    [Plugin] LookAt
    19 Posts 8 Posters 7.4k Views 8 Watching
    • PixeroP Offline
      Pixero
      I have made a plugin that rotates groups and components to look at a point (Attractor).
      First create an Attractor with the script. Place it where you want the other components to look. Select the Attractor and the other groups and/or components and then run Look At to rotate the them towards the attractor.
      LookAt rotates around the World Z axis so it's only looking in the X and Y direction.
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      • srxS Offline
        srx
        LookAtMe πŸ˜„ Thank you for sharing.
        www.saurus.rs
          Thanks... πŸ˜„
          • HornOxxH Offline
            HornOxx
            πŸ‘ πŸ˜„ prima Pixero & thank You !
            never trust a skinny cook
            • tuna1957T Offline
              tuna1957
              Way cool Thank you πŸ‘
              • bazB Offline
                baz
                This looks like it could be very useful for setting up lights in Twilight Render. It can be a pain re-pointing lights when looking for a better lighting angle. Thanks.
                • PixeroP Offline
                  Pixero
                  Remember that it only works in x and y as it rotates around z axis.
                  • cmeedC Offline
                    cmeed
                    Hi All,
                    I thought this would be very useful for making crowds look where I wanted them too. Unfortunately, I can't make this plugin work.
                    my process - I create and move an Attractor - place it were I want it , Select my Attractor and My audience, click extensions - Look At and a window pops up asking AXIS Y, clicking ok - nothing happens. Tried all the other settings X -X -Y
                    is there any reason or process I'm missing? looks so straightforward..
                    Cheers In advance
                    • Didier BurD Offline
                      Didier Bur
                      @cmeed: is your crowd made of billboards (FaceMe components) ?
                      DB
                      • cmeedC Offline
                        cmeed
                        Hi Didier,
                        They are 3d people.
                        C
                        • cmeedC Offline
                          cmeed
                          Hi BAZ,
                          Have you seen this - https://sketchucation.com/plugin/787-freerotate
                          I use it alot to point lights
                          • PixeroP Offline
                            Pixero
                            @cmeed
                            Could you upload the scene so I can see why it isn’t working for you.
                            • cmeedC Offline
                              cmeed
                              Will do.
                              • cmeedC Offline
                                cmeed
                                @pixero said:
                                @cmeed
                                here you go ..... The file had to be watered down as it was a bit too large for sketchucation, LOOK At it still doesn't work for me
                                Thanks for taking a look!
                                c
                                190809_pixero_01.skp
                                • PixeroP Offline
                                  Pixero
                                  Now the script is updated to v1.1.
                                  I hope it works for you now.
                                  • PixeroP Offline
                                    Pixero
                                    I fixed the bug but haven't uploaded it yet as I also found another bug that I need some advice on how to solve. If you desperately need the quick fix let me know and i could PM it to you.
                                    • cmeedC Offline
                                      cmeed
                                      I'm at my computer tomorrow and will check it out.
                                      From your last post it looks you you had a very productive half an hour
                                      • PixeroP Offline
                                        Pixero
                                        Yeah, sometimes bugs are easily squashed.
                                        • cmeedC Offline
                                          cmeed
                                          HI Pixero!
                                          I can confirm its all working as it should!!
                                          Fantastic
                                          Would you permit a little feedback? maybe there could be a further addition to the process - the pull down menu is fine - could there be an extra function after it (or replace it with) - an arrow button that rotates the grp/comp? this degates repeating the process if one gets the axis wrong (or bad modeling in my case)
                                          anyway Thanks again for a very useful plugin!!
                                          Cheers
