    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
    • T
      tkharis
      Its showing entities of type 'group' can't be deformed !
        Firstly, have you fixed the code as explained in the previous post ?
        PS: Please get the latest v6 which is fixed for you - see next post...
        You are getting an odd message - please post it all.
        However, I suspect it results from the selected group containing no editable vertices - e.g. if the selected group contains some other group[s] or component-instances, but no 'raw geometry', then there will be no vertices in it for FFD to process. Look in the Outliner and explode the nesting, OR edit and perform the FFD operations on a group that does contain raw-geometry which will in turn supply the needed vertices...
        Put simply, you select a group and use the context-menu to apply some guide-points in a 'cage'.
        These are grouped separately, so to select them it's easiest to use the Outliner.
        Edit their container and move the points etc to deform the connected group's geometry...
          Because we've had a lot of confusion with this old Plugin - especially with v2019 - I've updated its RBZ in the PluginStore.
          Now v6 should be compatible and it is also 'signed'...
          https://sketchucation.com/pluginstore?pln=SketchyFFD
          • E
            Einstein
            Support for rotated groups would be a big deal in this plugin.
              Any further development is unlikely - this old plugin has not been updated much in ~6 years.
              To work on a rotated group...
              Rotate it.
              Select it.
              Explode it.
              Immediately make a new group of its still highlighted contents using the context-menu.
              Rest its name, material, layer to match the original one...
              It is probably easier to do it, than it is to write it, and it is certainly easier than [re]coding it...
                AMBLZA16
                HI CAN I ASK WHAT TO DO TO MY SKETCH UP. IT ONLY HAS LOCKED EDGES, UNLOCKED AND MAKE A PATCH. AND THE DOTS DONT APPEAR ON THE OBJECT. CAN I ASK WHAT MAYBE THE POSSIBLE PROBLEM?
                  The 'dots' are guide-points, these are only visible if you have set View > Guides > ON [ticked]
                  Is that your issue ?
                    A cool trick for use FFD is to use the Onliner + Xray for an easy selection of what must be selected! πŸ€“
                    • N
                      nazart
                      HI CAN I ASK WHAT TO DO TO MY SKETCH UP. IT ONLY HAS LOCKED EDGES, UNLOCKED AND MAKE A PATCH. AND THE DOTS DONT APPEAR ON THE OBJECT. When move my points the form doesnt changes
                        Your explanation is unclear.
                        You say the dots don't appear, then you say you move them ??
                        Do you have View > Guides set Visible ?
                        Do you use the Outliner to edit the points' container and move them ?
                        Please supply a SKP showing the issue, with a step-by-step guide to what you are doing...
                          Meda
                          Thank you for the nice plugin.
                          However, I ran into some problems with FFD when I wanted to make shapes with the NxN FFD option. For example, I go for the setting NxN FFD 3-3-3-true to subdivide a cube, then I move some selected control points but either nothing happens, or the whole cube is broken and some faces are missing.
                          Would you be so kind and help me with that?
                          Thank you! Best, Meda
                            Please post a simple SKP model which displays this problem.
                            It is a very old plugin, so it can be flaky... so no promises about a fix...
                            • N
                              nur_aida
                              hye i hav installed FFD extension in sketchup 2019 pro but the icon box doesnt show up, neither in the tool bar lists. its already enabled in extension manager but nothing show up
                                This tool is run from the right-click context-menu items, which are available when there's a suitable selected group.
                                Also use the Outliner to access then edit the associated cpoints group...
                                  Dodanydo
                                  I installed your plugin (SketchyFFD v6) on SketchUp 2018, but after installation the icon and generally the tool did not appear.
                                  maybe I should install the old version of the plugin v2018? Could you drop the file?
                                  sorry for my English. πŸ˜„
                                    Please read the main post which explains the tool's usage.
                                    As I posted recently
                                    Also use the Outliner to access then edit the associated guide points group...
                                      Dodanydo
                                      Hooray! thank you so much! found everything. πŸ‘
                                      why did you remove the plugin icons that were before? It was very comfortable. β˜€
                                        rv1974
                                        What is purpose of 'make patch'?
                                          It sets / changes the number of control guide-points used ?
                                            rv1974
                                            Do you suppose or you know for sure? Could you post some illustrating gif or give a link for existing video?
                                            I set configuration of guide points by entering numbers in NxN FFD window.
                                            No matter what numbers I put in 'make patch' dialog window the only thing this option does is miserable 3X3 patch at 0,0,0.
                                            And I still don't understand the goal of this thing.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 20 / 21
