    Some tips about why my render looks poor?
    renderpluginsextensions
    15 Posts 4 Posters 5.7k Views 4 Watching
    • bazB
      baz
      Had a very quick play with your model.
      I dont use Vray, but Twilight. But these tips apply anyway.
      Your model is not very realistic, so grain orientation fixed and impossibly sharp edges softened. Also put your model in a curved stage to eliminate hard shadows. And added some shine and bump to the wood.
      Also deleted whole bunch of entities, a sort of studio around the 'badly drawn box'. Vray?
      Suggest you watch some YouTube beginner vids.
      Good Luck.
      poor_scene-baz.skp
      • bazB
        baz
        Now thinking original image a bit 'Stinky'?
        Or, does it matter which way 'textures' point? Even Wood or Feathers?
          sandwich2k
          It's not a real pronect, just to show in the forum because I have same problem with everything.
            sandwich2k
            Whats the reason to see it blue instead of white then?, someone knows?
            • l_breaultL
              l_breault
              I just quickly rebuilt this. Like others were saying, you need to start with a good model, radius or chamfer the edges. I also set back the dividers a smidge. That helps make things look more realistic. Keep your materials going the right way. I brought it closer to the ground and used an infinte plane with shadow catcher. I am using Thea by the way. I used a basic studio hdri and pressed play.
              Thanks,
              Leo Breault
              http://www.breaultdesignstudio.com
              • bazB
                baz
                Mr Ib. Lookin good. Post the skp if you have changed it.
                • l_breaultL
                  l_breault
                  Here's the skp.
                  poor_scenerebuild.skp
                  Thanks,
                  Leo Breault
                  • l_breaultL
                    l_breault
                    It doesn't have the same materials though.
                    Thanks,
                    Leo Breault
                      sandwich2k
                      @baz, @l_breault, thank you both for telling me some tips and share a .skp file with some modifications to make it look better.
                      I was trying to do a better design trying not to look like an idiot (the one in the post was a fast example). I tested several configurations in the render, the only way I can get a floor close to white and not to blue is using the sunlight default option and adding a dome light, I was getting crazy trying to rotate the textured, so ...
                      I'd like to see some vray light setup to get something like the picture from my first post.
                      https://i.imgur.com/ov5gjQb.png
                      I need a little rest after so much sketchup πŸ˜•
                      This is the best I got so far:
                      I think I fixed the grain orientation.
                      I think I fixed the sharped edges.
                      Now the light looks not blue, but it looks still a little pink, if I try to make it more white intense, then the furniture gets overexposed (not sure about the English word).
                      armario.skp
                        rspierenburg
                        Keep in mind most renderers use some (a lot) of post processing in Photoshop or similar after their bake their renders. With post processing you can fix things like white balance much easier than fiddling with settings via the render software.
                          sandwich2k
                          I think you're right, using the .skp file from l_breault and using post processing from v-ray through corrections control, I can get something like this (not as good as him, but better than my first try):
                          • l_breaultL
                            l_breault
                            Much better. I don't know what vray has for white balance, but that could help. I also use an all white color for a background image and that helps.
                            Thanks,
                            Leo Breault
