    3D Truss Models
    1.5k Posts 31 Posters 977.0k Views 30 Watching
    • medeekM Offline
      medeek
      When I originally enable hurricane (uplift) ties for the trusses I failed to check to see how things looked with a raised heel when the H2.5A (simpson) tie was used.
      In this particular case the tie needs to be flipped around so that it is facing towards the interior rather than the exterior. I've made the correction and added the logic into the code. I will release the fix with the next version:
      http://design.medeek.com/resources/images/truss_su379_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.3.4 - 04.24.2019
        • Enabled the "Edit Roof Assembly" function for gable and hip rafter roofs (imperial and metric units).
        • Corrected an issue with H2.5A hurricane ties when utilized with raised heel trusses.
        http://design.medeek.com/resources/images/truss_su380_800.jpg
        This is a fairly substantial upgrade for the plugin and now gives the user the ability to edit stick framed roofs. Previously only certain truss roofs could be edited.
        I still need to enable editing for the other rafter roof types (shed roofs, I-Joist, rafter roofs with glulam beams etc...), but at least I've now got the two most common roof types with full parametrics enabled.
        design.medeek.com
        • medeekM Offline
          medeek
          This brings me back to some topics I was exploring last year at about this time regarding asymmetric rafter roofs. I will set aside the hip roof for a minute and look at the simple gable roof in continuation of this discussion.
          Each side of the roof may have a different pitch. Additionally the top plate height may differ as well as the birdcut. Things tend to get a little complicated when the symmetry is broken.
          Basically one can boil it down to a symmetric or asymmetric gable roof. The asymmetric variant will have the following additional parameters:
          Roof Type: Symmetric Gable, Asymmetric Gable
          Pitch2 - Roof pitch of right side roof
          Birdcut2 - Birdcut length of right side of roof
          Delta Height - Difference in height between left and right bearing walls (left side is reference)
          One could even go so far as to define a different rafter depth for the opposite side, as its length may be more or less than its opposite side:
          Rafter Depth 2 - Rafter depth on right side of roof.
          design.medeek.com
          • medeekM Offline
            medeek
            With the asymmetric variant the secondary pitch and bearing height cause the location of roof peak to be off center. In order to draw the roof one must first solve for the location of the roof peak (x direction). The solution is given by:
            http://design.medeek.com/resources/trussplugin/asymmetric_gable_pg1_800.jpg
            http://design.medeek.com/resources/trussplugin/asymmetric_gable_pg2_800.jpg
            I won't really know if the math is correct until I drop it into the ruby code and test it.
            I will also need to check for null solutions, where certain combinations of pitches and delta h create impossible geometry.
            I kind of miss the rigor of the math often required with the development of the truss plugin. Asymmetric hip roofs are going to be even more math intensive.
            I'm not exactly sure on what to do with the ridge board. I can either bevel it or drop it to the same height as the lower side rafters.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.3.5 - 04.28.2019
              • Fixed the show_modal bug for macOS in the Materials tab of the global settings.
              design.medeek.com
              • medeekM Offline
                medeek
                First look at an asymmetric roof:
                http://design.medeek.com/resources/images/truss_su381_800.jpg
                Note the addition of "Asymmetric Options" in the edit menu (4 parameters).
                Also note that the rafter depth is different for each side of the roof as well as the birds mouth cut.
                If the delta height is non-zero (can be either negative or positive) then I have the ceiling joists disabled for now. I will need some more direction with regard to that possible configuration.
                I now just need to focus on the advanced options and bring them up to speed for an asymmetric gable roof (ie. gutters, hip and ridge, rake boards, sheathing, cladding etc...)
                I've also spent some considerable time cleaning up the rafter roof module and re-organizing the file structure where it seemed prudent. The thing about these plugins is there is always more to do.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.3.6 - 05.01.2019
                  • Enabled asymmetric gable rafter roofs (imperial and metric units).
                  Tutorial 14: Asymmetric Gable Roofs
                  Sometimes you just never know until you dig into it. This latest update required a virtual rewrite of the entire rafter roof module. Asymmetric roofs literally change everything up. I'm glad to get this one wrapped up and behind me.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    The asymmetric roof addition beat me up pretty hard for about three days, but in the end I won out. Now I need to look at the hip roof and how best to deal with multi pitches...
                    With the hip roof we are now talking about four different possible top plate heights with four different possible pitches, birdsmouth cuts, and rafter depths.
                    If one is to assume that the fascia boards all line up (gutters), then the top plates heights are actually driven by the roof overhang and the pitch of each roof plane. Only one roof plane (Plane A) will actually have its plate height set (the zero or base height of the roof), the other roof planes' top plate heights will be automatically calculated.
                    I suppose there is always the possibility where the fascia don't line up but I think this is more the exception than the rule, correct me if I am wrong.
                    As I've given this some more thought it occurred to me that typically the designer will set the roof pitches from the outset. Then, in order to get the fascia to line up, he/she can either adjust the overhang or the top plate height (assume that the birdsmouth cut is set to some value). So depending on the situation the user may want the plugin to calculate either the overhang (same top plate height) or the top plate height (same overhang). I will need to give this some more thought.
                    If the user keys in a numeric value for the overhang (roof planes B, C or D) then the edit menu can automatically set the delta height (top plate heights) for each respective roof plane to "AUTO". Likewise if a value is keyed in for the delta height the HTML form can set the respective overhang(s) to "AUTO".
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I don't normally post on the boards regarding price changes in the plugins however I thought it might be worth noting that I have decreased the renewal price on the Truss plugin to $10.00. The idea being that once you have paid your initial license fee ongoing renewals are mostly a token payment.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Continuing on with regards to multi pitch hip roofs we need to be very clear about what point on the roof lines up when we talk about lining up the fascia. Do we mean the sub-fascia, rafter tail or the fascia?
                        Since I currently don’t have the fascia and soffit added yet I can probably ignore these for now and state that the top of the fascia board must line up with other fascia boards on other roof planes.
                        design.medeek.com
                        • pbacotP Offline
                          That make sense but in cutting rafters or fabricating trusses, isn't the only thing they can really do is line up the top of the rafter tails? Actually if there are tails, the truss manufacturer will leave it to the carpenter.
                          • medeekM Offline
                            medeek
                            In the field I think its typical to provide rafter tails that are too long so that they can be trimmed all at once (chalk line) to ensure that they all line up.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I've got the asymmetric options added to the edit menu and the common rafters and fascia are calculating correctly:
                              http://design.medeek.com/resources/images/truss_su382_800.jpg
                              Note that all four pitches are different values, however the fascia lines up all the way around the roof as it should (in this case I have the overhangs auto calculating).
                              Next I will work on the hip rafters and jack rafters. As we can see in this example, all symmetry is broken, each hip rafter will be unique (x4) as well as each set of jack rafters (x8). Luckily we can program this sort of thing, drawing this type of roof manually would be a real headache.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                First look at the sheathing and labels for an asymmetric hip roof:
                                http://design.medeek.com/resources/images/truss_su383_800.jpg
                                http://design.medeek.com/resources/images/truss_su384_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Pitch and SQFT callouts/labels are now working:
                                  http://design.medeek.com/resources/images/truss_su385_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Hip and Ridge Cap is now working:
                                    http://design.medeek.com/resources/images/truss_su386_800.jpg
                                    This chunk of code is just for the ridge cap geometry:
                                    @Phi1_3 = atan(sin(@Phiplane13) * tan(@Phi) * cos(@Phihip13))
                                    @Phi3_1 = atan(cos(@Phiplane13) * tan(@Phi3) * cos(@Phihip13))
                                    @Phialpha1_3 = acos(cos(@Phihip13) * sin(@Phiplane13))
                                    @Phialpha3_1 = acos(cos(@Phihip13) * cos(@Phiplane13))
                                    @Psi1_3 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi)*cos(@Phi3)))
                                    @Phi2_3 = atan(sin(@Phiplane23) * tan(@Phi2) * cos(@Phihip23))
                                    @Phi3_2 = atan(cos(@Phiplane23) * tan(@Phi3) * cos(@Phihip23))
                                    @Phialpha2_3 = acos(cos(@Phihip23) * sin(@Phiplane23))
                                    @Phialpha3_2 = acos(cos(@Phihip23) * cos(@Phiplane23))
                                    @Psi2_3 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi2)*cos(@Phi3)))
                                    @Phi1_4 = atan(sin(@Phiplane14) * tan(@Phi) * cos(@Phihip14))
                                    @Phi4_1 = atan(cos(@Phiplane14) * tan(@Phi4) * cos(@Phihip14))
                                    @Phialpha1_4 = acos(cos(@Phihip14) * sin(@Phiplane14))
                                    @Phialpha4_1 = acos(cos(@Phihip14) * cos(@Phiplane14))
                                    @Psi1_4 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi)*cos(@Phi4)))
                                    @Phi2_4 = atan(sin(@Phiplane24) * tan(@Phi2) * cos(@Phihip24))
                                    @Phi4_2 = atan(cos(@Phiplane24) * tan(@Phi4) * cos(@Phihip24))
                                    @Phialpha2_4 = acos(cos(@Phihip24) * sin(@Phiplane24))
                                    @Phialpha4_2 = acos(cos(@Phihip24) * cos(@Phiplane24))
                                    @Psi2_4 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi2)*cos(@Phi4)))
                                    @Ridgex = (cos(@Phi)*@HRthk*tan((@Phi + @Phi2)*0.5)) - sin(@Phi) * @HRthk
                                    @Ridgey = (sin(@Phi)*@HRthk*tan((@Phi + @Phi2)*0.5)) + cos(@Phi) * @HRthk
                                    if @Sheathing_option == "YES"
                                    if @Roofbatten == "YES"
                                    if @Cboption == "YES"
                                    thtot = @Cbheight + @Battenheight + @Sheathing_thickness + @Roofcladding_thickness
                                    else
                                    thtot = @Battenheight + @Sheathing_thickness + @Roofcladding_thickness
                                    else
                                    thtot = @Sheathing_thickness + @Roofcladding_thickness
                                    else
                                    thtot = @Cbheight + @Battenheight + @Roofcladding_thickness
                                    else
                                    thtot = @Battenheight + @Roofcladding_thickness
                                    else
                                    thtot =  @Roofcladding_thickness
                                    # Extension at Peak
                                    @Wa3 = PI - (@Phialpha3_1 + @Phialpha3_2)
                                    @Beta23 = atan(sin(@Wa3)/(tan(@Psi1_3)/(tan(@Psi2_3)) + cos(@Wa3)))
                                    @Beta13 = @Wa3 - @Beta23
                                    ext13 = (thtot * tan(@Psi1_3))/(tan(@Beta13))
                                    ext23 = (thtot * tan(@Psi2_3))/(tan(@Beta23))
                                    @Wa4 = PI - (@Phialpha4_1 + @Phialpha4_2)
                                    @Beta24 = atan(sin(@Wa4)/(tan(@Psi1_4)/(tan(@Psi2_4)) + cos(@Wa4)))
                                    @Beta14 = @Wa4 - @Beta24
                                    ext14 = (thtot * tan(@Psi1_4))/(tan(@Beta14))
                                    ext24 = (thtot * tan(@Psi2_4))/(tan(@Beta24))
                                    # Ridge Length and Extensions
                                    ridgedx = (cos(@Phi)*thtot*tan((@Phi + @Phi2)*0.5))
                                    ridgedy = (sin(@Phi)*thtot*tan((@Phi + @Phi2)*0.5))
                                    length_sq = thtot**2 + ridgedx**2 + ridgedy**2
                                    rext3 = sqrt(ext13**2 + (thtot/(cos(@Psi1_3)))**2 - length_sq)
                                    rext4 = sqrt(ext14**2 + (thtot/(cos(@Psi1_4)))**2 - length_sq)
                                    phicheck3 = atan(ext13*cos(@Psi1_3)/thtot) + PI - @Phihip13
                                    phicheck4 = atan(ext14*cos(@Psi1_4)/thtot) + PI - @Phihip14
                                    if phicheck3 > PI
                                    	rext3 = -1.0 * rext3
                                    if phicheck4 > PI
                                    	rext4 = -1.0 * rext4
                                    @Ridgecaplength = @Arraylength - @Hipf - @Hipb + rext3 + rext4
                                    design.medeek.com
                                    • pbacotP Offline
                                      WOW.
                                      I hope you never see a roof like this, but kudos for handling the situations where we may have a couple different pitches anyway.
                                      • medeekM Offline
                                        medeek
                                        Gutters and Downspouts are now functional for the Asymmetric Hip Rafter Roof:
                                        http://design.medeek.com/resources/images/truss_su387_800.jpg
                                        Even with the different overhangs and top plate heights the gutter height (fascia) is the same height all the way around. However the downspouts on opposite sides of the roof are customized per the overhang on each respective side.
                                        Tomorrow I will jump back into the hip and jack rafters and see if we can wrap this one up.
                                        The good news is that the required code for the asymmetric hip and jacks already exists. I will be borrowing from the roof return module where I handled dissimilar pitches. The bad news is that after a cursory review of this block of code I have absolutely no idea how it actually works anymore (I haven't looked at it in about 2 years). It's just a matter of reverse engineering my own code for about an hour and it will all come back to me.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I'm actually still working on the hip rafters. The complexity of a multi-pitch roof took another unexpected turn with the realization that when roof planes A and B are different pitches it causes an offset in the rafters at the peak which requires some additional logic to account for this fact with the placement of the hip rafters and their geometry.
                                          I'm also still a bit conflicted on how to best handle the birdsmouth cut of the hip rafters when they walls have different top plate heights. In some cases the hip rafter misses the corner entirely and is askew on one of the walls, this is the simple case. In other cases the hip rafter technically rests at the "corner" but since there are two different wall heights possible it is not clear how the birdsmouth cut should be constructed exactly. I'm assuming that the higher plate height will govern.
                                          Does anyone have any photos or details of actual construction where a hip rafter bisects a corner where the top plate heights vary?
                                          design.medeek.com
                                          • pbacotP Offline
                                            Got me looking for examples. I've created (or passed on) far more problems like this for others, than I ever had to deal with in the field. You might look at this guys webpage. https://deskgram.net/explore/tags/bastardhip
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 75
                                            • 76
                                            • 55 / 76
