    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      With the asymmetric variant the secondary pitch and bearing height cause the location of roof peak to be off center. In order to draw the roof one must first solve for the location of the roof peak (x direction). The solution is given by:
      http://design.medeek.com/resources/trussplugin/asymmetric_gable_pg1_800.jpg
      http://design.medeek.com/resources/trussplugin/asymmetric_gable_pg2_800.jpg
      I won't really know if the math is correct until I drop it into the ruby code and test it.
      I will also need to check for null solutions, where certain combinations of pitches and delta h create impossible geometry.
      I kind of miss the rigor of the math often required with the development of the truss plugin. Asymmetric hip roofs are going to be even more math intensive.
      I'm not exactly sure on what to do with the ridge board. I can either bevel it or drop it to the same height as the lower side rafters.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.3.5 - 04.28.2019
        • Fixed the show_modal bug for macOS in the Materials tab of the global settings.
        design.medeek.com
        • medeekM
          medeek
          First look at an asymmetric roof:
          http://design.medeek.com/resources/images/truss_su381_800.jpg
          Note the addition of "Asymmetric Options" in the edit menu (4 parameters).
          Also note that the rafter depth is different for each side of the roof as well as the birds mouth cut.
          If the delta height is non-zero (can be either negative or positive) then I have the ceiling joists disabled for now. I will need some more direction with regard to that possible configuration.
          I now just need to focus on the advanced options and bring them up to speed for an asymmetric gable roof (ie. gutters, hip and ridge, rake boards, sheathing, cladding etc...)
          I've also spent some considerable time cleaning up the rafter roof module and re-organizing the file structure where it seemed prudent. The thing about these plugins is there is always more to do.
          design.medeek.com
          • medeekM
            medeek
            Version 2.3.6 - 05.01.2019
            • Enabled asymmetric gable rafter roofs (imperial and metric units).
            Tutorial 14: Asymmetric Gable Roofs
            Sometimes you just never know until you dig into it. This latest update required a virtual rewrite of the entire rafter roof module. Asymmetric roofs literally change everything up. I'm glad to get this one wrapped up and behind me.
            design.medeek.com
            • medeekM
              medeek
              The asymmetric roof addition beat me up pretty hard for about three days, but in the end I won out. Now I need to look at the hip roof and how best to deal with multi pitches...
              With the hip roof we are now talking about four different possible top plate heights with four different possible pitches, birdsmouth cuts, and rafter depths.
              If one is to assume that the fascia boards all line up (gutters), then the top plates heights are actually driven by the roof overhang and the pitch of each roof plane. Only one roof plane (Plane A) will actually have its plate height set (the zero or base height of the roof), the other roof planes' top plate heights will be automatically calculated.
              I suppose there is always the possibility where the fascia don't line up but I think this is more the exception than the rule, correct me if I am wrong.
              As I've given this some more thought it occurred to me that typically the designer will set the roof pitches from the outset. Then, in order to get the fascia to line up, he/she can either adjust the overhang or the top plate height (assume that the birdsmouth cut is set to some value). So depending on the situation the user may want the plugin to calculate either the overhang (same top plate height) or the top plate height (same overhang). I will need to give this some more thought.
              If the user keys in a numeric value for the overhang (roof planes B, C or D) then the edit menu can automatically set the delta height (top plate heights) for each respective roof plane to "AUTO". Likewise if a value is keyed in for the delta height the HTML form can set the respective overhang(s) to "AUTO".
              design.medeek.com
              • medeekM
                medeek
                I don't normally post on the boards regarding price changes in the plugins however I thought it might be worth noting that I have decreased the renewal price on the Truss plugin to $10.00. The idea being that once you have paid your initial license fee ongoing renewals are mostly a token payment.
                design.medeek.com
                • medeekM
                  medeek
                  Continuing on with regards to multi pitch hip roofs we need to be very clear about what point on the roof lines up when we talk about lining up the fascia. Do we mean the sub-fascia, rafter tail or the fascia?
                  Since I currently don’t have the fascia and soffit added yet I can probably ignore these for now and state that the top of the fascia board must line up with other fascia boards on other roof planes.
                  design.medeek.com
                  • pbacotP
                    That make sense but in cutting rafters or fabricating trusses, isn't the only thing they can really do is line up the top of the rafter tails? Actually if there are tails, the truss manufacturer will leave it to the carpenter.
                    • medeekM
                      medeek
                      In the field I think its typical to provide rafter tails that are too long so that they can be trimmed all at once (chalk line) to ensure that they all line up.
                      design.medeek.com
                      • medeekM
                        medeek
                        I've got the asymmetric options added to the edit menu and the common rafters and fascia are calculating correctly:
                        http://design.medeek.com/resources/images/truss_su382_800.jpg
                        Note that all four pitches are different values, however the fascia lines up all the way around the roof as it should (in this case I have the overhangs auto calculating).
                        Next I will work on the hip rafters and jack rafters. As we can see in this example, all symmetry is broken, each hip rafter will be unique (x4) as well as each set of jack rafters (x8). Luckily we can program this sort of thing, drawing this type of roof manually would be a real headache.
                        design.medeek.com
                        • medeekM
                          medeek
                          First look at the sheathing and labels for an asymmetric hip roof:
                          http://design.medeek.com/resources/images/truss_su383_800.jpg
                          http://design.medeek.com/resources/images/truss_su384_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Pitch and SQFT callouts/labels are now working:
                            http://design.medeek.com/resources/images/truss_su385_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              Hip and Ridge Cap is now working:
                              http://design.medeek.com/resources/images/truss_su386_800.jpg
                              This chunk of code is just for the ridge cap geometry:
                              @Phi1_3 = atan(sin(@Phiplane13) * tan(@Phi) * cos(@Phihip13))
                              @Phi3_1 = atan(cos(@Phiplane13) * tan(@Phi3) * cos(@Phihip13))
                              @Phialpha1_3 = acos(cos(@Phihip13) * sin(@Phiplane13))
                              @Phialpha3_1 = acos(cos(@Phihip13) * cos(@Phiplane13))
                              @Psi1_3 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi)*cos(@Phi3)))
                              @Phi2_3 = atan(sin(@Phiplane23) * tan(@Phi2) * cos(@Phihip23))
                              @Phi3_2 = atan(cos(@Phiplane23) * tan(@Phi3) * cos(@Phihip23))
                              @Phialpha2_3 = acos(cos(@Phihip23) * sin(@Phiplane23))
                              @Phialpha3_2 = acos(cos(@Phihip23) * cos(@Phiplane23))
                              @Psi2_3 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi2)*cos(@Phi3)))
                              @Phi1_4 = atan(sin(@Phiplane14) * tan(@Phi) * cos(@Phihip14))
                              @Phi4_1 = atan(cos(@Phiplane14) * tan(@Phi4) * cos(@Phihip14))
                              @Phialpha1_4 = acos(cos(@Phihip14) * sin(@Phiplane14))
                              @Phialpha4_1 = acos(cos(@Phihip14) * cos(@Phiplane14))
                              @Psi1_4 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi)*cos(@Phi4)))
                              @Phi2_4 = atan(sin(@Phiplane24) * tan(@Phi2) * cos(@Phihip24))
                              @Phi4_2 = atan(cos(@Phiplane24) * tan(@Phi4) * cos(@Phihip24))
                              @Phialpha2_4 = acos(cos(@Phihip24) * sin(@Phiplane24))
                              @Phialpha4_2 = acos(cos(@Phihip24) * cos(@Phiplane24))
                              @Psi2_4 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi2)*cos(@Phi4)))
                              @Ridgex = (cos(@Phi)*@HRthk*tan((@Phi + @Phi2)*0.5)) - sin(@Phi) * @HRthk
                              @Ridgey = (sin(@Phi)*@HRthk*tan((@Phi + @Phi2)*0.5)) + cos(@Phi) * @HRthk
                              if @Sheathing_option == "YES"
                              if @Roofbatten == "YES"
                              if @Cboption == "YES"
                              thtot = @Cbheight + @Battenheight + @Sheathing_thickness + @Roofcladding_thickness
                              else
                              thtot = @Battenheight + @Sheathing_thickness + @Roofcladding_thickness
                              else
                              thtot = @Sheathing_thickness + @Roofcladding_thickness
                              else
                              thtot = @Cbheight + @Battenheight + @Roofcladding_thickness
                              else
                              thtot = @Battenheight + @Roofcladding_thickness
                              else
                              thtot =  @Roofcladding_thickness
                              # Extension at Peak
                              @Wa3 = PI - (@Phialpha3_1 + @Phialpha3_2)
                              @Beta23 = atan(sin(@Wa3)/(tan(@Psi1_3)/(tan(@Psi2_3)) + cos(@Wa3)))
                              @Beta13 = @Wa3 - @Beta23
                              ext13 = (thtot * tan(@Psi1_3))/(tan(@Beta13))
                              ext23 = (thtot * tan(@Psi2_3))/(tan(@Beta23))
                              @Wa4 = PI - (@Phialpha4_1 + @Phialpha4_2)
                              @Beta24 = atan(sin(@Wa4)/(tan(@Psi1_4)/(tan(@Psi2_4)) + cos(@Wa4)))
                              @Beta14 = @Wa4 - @Beta24
                              ext14 = (thtot * tan(@Psi1_4))/(tan(@Beta14))
                              ext24 = (thtot * tan(@Psi2_4))/(tan(@Beta24))
                              # Ridge Length and Extensions
                              ridgedx = (cos(@Phi)*thtot*tan((@Phi + @Phi2)*0.5))
                              ridgedy = (sin(@Phi)*thtot*tan((@Phi + @Phi2)*0.5))
                              length_sq = thtot**2 + ridgedx**2 + ridgedy**2
                              rext3 = sqrt(ext13**2 + (thtot/(cos(@Psi1_3)))**2 - length_sq)
                              rext4 = sqrt(ext14**2 + (thtot/(cos(@Psi1_4)))**2 - length_sq)
                              phicheck3 = atan(ext13*cos(@Psi1_3)/thtot) + PI - @Phihip13
                              phicheck4 = atan(ext14*cos(@Psi1_4)/thtot) + PI - @Phihip14
                              if phicheck3 > PI
                              	rext3 = -1.0 * rext3
                              if phicheck4 > PI
                              	rext4 = -1.0 * rext4
                              @Ridgecaplength = @Arraylength - @Hipf - @Hipb + rext3 + rext4
                              design.medeek.com
                              • pbacotP
                                WOW.
                                I hope you never see a roof like this, but kudos for handling the situations where we may have a couple different pitches anyway.
                                • medeekM
                                  medeek
                                  Gutters and Downspouts are now functional for the Asymmetric Hip Rafter Roof:
                                  http://design.medeek.com/resources/images/truss_su387_800.jpg
                                  Even with the different overhangs and top plate heights the gutter height (fascia) is the same height all the way around. However the downspouts on opposite sides of the roof are customized per the overhang on each respective side.
                                  Tomorrow I will jump back into the hip and jack rafters and see if we can wrap this one up.
                                  The good news is that the required code for the asymmetric hip and jacks already exists. I will be borrowing from the roof return module where I handled dissimilar pitches. The bad news is that after a cursory review of this block of code I have absolutely no idea how it actually works anymore (I haven't looked at it in about 2 years). It's just a matter of reverse engineering my own code for about an hour and it will all come back to me.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I'm actually still working on the hip rafters. The complexity of a multi-pitch roof took another unexpected turn with the realization that when roof planes A and B are different pitches it causes an offset in the rafters at the peak which requires some additional logic to account for this fact with the placement of the hip rafters and their geometry.
                                    I'm also still a bit conflicted on how to best handle the birdsmouth cut of the hip rafters when they walls have different top plate heights. In some cases the hip rafter misses the corner entirely and is askew on one of the walls, this is the simple case. In other cases the hip rafter technically rests at the "corner" but since there are two different wall heights possible it is not clear how the birdsmouth cut should be constructed exactly. I'm assuming that the higher plate height will govern.
                                    Does anyone have any photos or details of actual construction where a hip rafter bisects a corner where the top plate heights vary?
                                    design.medeek.com
                                    • pbacotP
                                      Got me looking for examples. I've created (or passed on) far more problems like this for others, than I ever had to deal with in the field. You might look at this guys webpage. https://deskgram.net/explore/tags/bastardhip
                                      • medeekM
                                        medeek
                                        Note how this hip rafter sits askew, only on one wall:
                                        https://scontent-atl3-1.cdninstagram.com/vp/0c3557437b831311132380364886be2f/5D60F286/t51.2885-15/e35/35575469_1787088774714743_1874779179191369728_n.jpg?_nc_ht=scontent-atl3-1.cdninstagram.com
                                        design.medeek.com
                                        • pbacotP
                                          Yes. I once did a little roof framing, using old school framing square methods from a book. Sometimes I just had to work it out in the field.
                                          • medeekM
                                            medeek
                                            When the hip roof is asymmetric across the ridge you end up with a situation like what is shown below:
                                            http://design.medeek.com/resources/images/truss_su388_800.jpg
                                            The common rafter in the upper right is a 7:12 pitch and the common rafter in the lower left is a 10:12 pitch. Normally with a symmetric hip or gable roof the common rafters would be flush with the top of the ridge board.
                                            However in the asymmetric case the steeper pitched side is flush and the lesser pitched side overshoots the ridge board just slightly as shown. This additional asymmetry causes further complications in the calculations of the hip rafter that is adjacent to the overshooting common.
                                            Also note that the seams in the sheathing (edges of the roof planes) do not center up on the ridge board or hip rafters. This is not a flaw or an error it is just the way the asymmetric roof goes together.
                                            It appears that I have the hips correctly calculating now (after nearly two days of intense debugging and about 10 sheets of engineering pad) however tomorrow I will continue with further testing, to see if I can break anything, and then begin attacking the jack rafters.
                                            A further look at the bird mouth cut question in shown in the example below:
                                            http://design.medeek.com/resources/images/truss_su389_800.jpg
                                            So in reality I am still missing the birds mouth cut for the hip rafters and the implementation of the soffit cut for trimming the tails of the hip rafters. Always too much to do and never enough time to get it all done.
                                            I'm really hoping that the jack rafter piece is a lot less trouble than the hip rafters, I would really like to get this roof type wrapped up by the end of the weekend.
                                            design.medeek.com
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 76
                                            • 77
                                            • 58 / 77
