    [Plugin] Roof.rb
    extensions
    174 Posts 75 Posters 174.0k Views 75 Watching
      @ahmed0007 said:
      Please Update Follow me & Rotate
      This is not the correct thread to post this request.
      This FaR tool has its own thread[s].
      Although I have helped resolve some issues with FaR ver the years, it is NOT my code and is copyrighted and encrypted by its author.
      So nag him - not me !
      • mariochaM Offline
        mariocha
        A localizable version named Roof-LH.rbz is now available. (LanguageHandler)
        French strings included.
        Please note that this is not a full version since 'Layers & materials' options have been removed from it.
        Available on http://www.formation-sketchup.quebec
        if requested I can also load it in the PluginStore.
        Happy new year all.
        %(#008000)[Mario C.
          archarles
          Hi dear author, I tried the 'pick-three-point' to create a gable roof, but after the last click there is no menu come out. Do you have any suggestion. BTW, only 'select from face' options are still workable.
          Cheers.
          Charles.
            The 3 points must all be in a horizontal plane [say the top of walls?]
            1 & 2 defining the width of the gable triangle and then 3 sets the length of the eaves...
            If you run it with the Ruby Console do you see any error messages ?
              bisnisbali
              please update for sketcup 2018, thanks
                It works fine in v2018 and in v2019.
                It's already fully signed and compatible with all current SketchUp versions.
                A few posts back [at the end of 2017] I posted to say v5.0 was now compatible with v2018 !
                I just hadn't updated details on its main page...
                Now done.
                  kubra26
                  hello 2018 sketchup plug-in downloaded but says invalid signature can you help me
                    If you get the latest version of 'Roof' from the PluginStore, then it should be fully signed and compatible for all current SketchUp versions...
                    Where did your problem version come from ?
                    Notwithstanding that - in reality the 'validity' of the extension's signature [or it even being 'unsigned'] doesn't matter very much.
                    If you have download an extension's RBZ from a trusted source [like EWH, SketchUcation, or a well known developer's web-site], then that RBZ might be somewhat old and therefore it's not been re-signed for some newer versions of SketchUp, BUT it is very probable that it will still work in those newer versions.
                    It's a PITA to get everything recompiled into an RBZ, and submit it to SketchUp's portal to get the latest signature added, then republish it: older extensions that haven't needed updating to suit changes in the newer SketchUp's Ruby API, will often have out of date signatures, or might even be 'unsigned'.
                    With 'free' extensions it's unreasonable to expect authors to re-sign everything, at every update...
                    The global fix is easy - to allow you to load and use these older plugins and extensions... simply set your SketchUp > Window > Extension Manager > Loading Policy to be 'Unrestricted'.
                    After you restart SketchUp and previously 'blocked' extensions will be loaded and be available for use...
                      JakubPelka
                      It's great plugin. Thanks!
                      But... is there a chance for a Gambrel option?
                      Will be glad for any info!
                        It's an old Plugin, unlikely to have any major changes...
                        There's already a 'Mansard' option - this allows you two roof pitches per slope - to make a Mansard or Sprocketed roof form.
                        If you want your own kind of 'Gambrel' roof [which I think is called a 'Mansard' roof in many other locales], then you can edit a simpler roof form - and manually add/erase the necessary changes ?
                          Ray Brown
                          TIG:
                          What am I missing?? I've installed V5.0 and still can't get hipped roof to work in either 2018 or 2019 on my MacBook Pro. I've followed your Help instructions, but nothing seems to work. I can generate gable end and pyramids, but no hips or mansards. HELP!!
                          Ray Brown
                          Ray Brown Urban Design
                            Have you run it with the Ruby Console open to see if there are any error messages ?
                            The face you use to make the outline of the hipped roof cannot be at z=0...
                            Draw a shape on the ground [z=0], then extrude it upwards using PushPull.
                            Now select just the top face of the geometry and run the Hipped Roof tool...
                            Any luck ?
                              Ray Brown
                              When I ran it with the Ruby Console open, there were no error messages and the Plugin worked just fine in both 2018 and 2019. Some kind of long-distance sorcery from you, no doubt. Thanks.
                              Ray Brown
                                Juanjoxxx
                                For me, it doesnt work.
                                When I run the program, it exits or closes.
                                  Please explain more details.
                                  Is this problem in v2017 ?
                                  If you run it with the Ruby Console open are there any error messages ?
                                  There are several tools with the 'Roof' set: which one is causing the problem ?
                                  When you say 'it exits' do you mean it just doesn't do any thing, or that SketchUp itself closes ?
                                  No error messages at all ??
                                  Are you using the tool as the usage notes explain ?
                                  e.g. the flat face forming the outline for the hipped roof tool cannot be at z=0, and it is possible to devise a face that cannot accept a hipped roof - but then an error message should tell you that...
                                    kaciecomeaux
                                    I have downloaded this roof tool but I am having a hard time using it. I watched videos. I use sketchup with dynascape. I import 2D drawings into skethchup and replace with components. When I use the select face roof tools, like hipped or gabled roofs, nothing happens. Only the color of the face changes but stays flat. I'm not sure what I am doing wrong. Is there somewhere that I can obtain more info on how to use this tool? I thought maybe these roofs are too complex for the tool, so I created a box and tried to put a roof on it and the same thing happens. Please Help! It looks like it can be an amazing tool if I could just get it to work.
                                      It is an old toolset... but it should work.
                                      Use it with the Ruby Console open...
                                      A few pointers...
                                      The face for a hipped roof must be flat and NOT at z=0.
                                      There should be prompts on the status-bar and dialogs that ask for inputs...
                                      Report any errors from the Ruby Console...
                                        kaciecomeaux
                                        A few pointers...
                                        The face for a hipped roof must be falt and NOT at z=0.
                                        Please forgive me, I am fairly new to sketchup. I know that is a ruby file but what does " use it with ruby console open" mean?
                                          It's a little box screen that display in text mode in real time all that is working on the screen of Sketchup!
                                          If there is an error that is displayed and like this that help a lot for debbugging! πŸ˜„
                                            Menu - Window > Ruby Console...
                                            Opens a window that lists errors/outputs and also lets you type in simple Ruby commands...
                                            • 7 / 9
