    Roof with curved hips
    7 Posts 5 Posters 1.1k Views 5 Watching
      Alfani
      How can I model a roof with curved hips using Sketchup basic tools? I really don't know how to make these curved faces and join them along the curvy hips. This page shows an identical roof that I am trying to create.https://www.contractortalk.com/f14/curved-bay-roof-157282/
        It can be done. What kind of detail are you trying to create?
        What version of SketchUp are you actually using. Your profile has contradictory information as there is no 2018 Make version.
          Alfani
          Just the form of the top surfaces of the roof. I will do it on Sketchup Pro 2017.
            iii.jpgIf you are just trying to model the outside surface there are a couple of ways, by using "follow me" or "From contours" what is shown in the attachement is using the follow me tool. If you are trying to build a model of the timber construction you could build it using the outside form as your template. And again using the "intersect faces" tool, lot of work though.
            • pbacotP Offline
              Using arc tool, push pull, rotate/duplicate. Intersect faces (both to cut hip shape and roof faces at the wall), move/duplicate, flip along red axis, move and delete edges.
              roof.mov
                Alfani
                Thanks! It worked perfect with "Follow me" too. Much easier than I was thinking!
                  Curviloft is very simple too.
