    [Plugin][Code]SKMtools,Material/ImageTools
    178 Posts 37 Posters 308.9k Views 37 Watching
      Ahmed0007
      i'm very happy to see your quick response
      Thank you soooo much!
      Problem solved.
      paypal is not available in our country is there is any other way to donate developers on sketchucation ?
        I'm afraid that it's pretty much only donations/payment by PayPal.
        No worries just have nice thoughts about us instead - that's more that many people do !
          atek
          Why the png did not convert to geometry. I tried the SKM TOOL image trimmer plugin. I save the file before using it. Then i selected this png image
          It just process and nothing happens. May i know the reason why it does not convert to a geometry so that i can modify. Thanks
            Your PNG file is not suitable for processing.
            The transparent background is 0% Alpha [==good]
            The foreground is 99% Alpha - ==bad, because it must be 100%, as it is the ImageTrimmer tools sees everything with some transparency - so it's assumed to be all background and there's nothing left to process !
            Hence the error message at the end.
            It's easily fixed.
            I opened the PNG in Gimp [other tools like Photoshop will also do the fix].
            Flattened the image to remove all Alpha.
            Added an Alpha Channel Layer.
            Used the magic-wand to select all of the background pixels [now 'white'].
            Delete.
            Saved the changes.
            Imported the PNG as an Image and processed it with ImageTrimmer.
            Took a minute or two, because it has a lot of pixels to go through.
            I skipped the 'Smoothing' step at the end as it's so finely pixilated...
            The updated PNG is attached - but I suggest you try doing the fix yourself.
            [attachment=1:2detnhr6]<!-- ia1 -->place-marker.png<!-- ia1 -->[/attachment:2detnhr6]
            There's also a screenshot of the result...
            [attachment=0:2detnhr6]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:2detnhr6]
            PS: You can attach image files directly onto your posts - no need to link off to external websites...
              RoRay
              Is this pluging compatible with SU2017?
                Yes it is compatible with SketchUp 2017.
                  RoRay
                  thanks! πŸ˜„
                    Updated for compatibility of the ImageTrimmer tool with newer SketchUp versions...
                    https://sketchucation.com/pluginstore?pln=SKMtools
                    • V
                      Vizan
                      Your plugin issues this message SU2017:
                      "Could not find the main class: EdgeDetector. Program will exit."
                        @Vizan
                        Please read this post about JAR files...
                        https://sketchucation.com/forums/viewtopic.php?p=642919#p642919
                        Once you are sure you have your compression tools and Java set up correctly, please retry it...
                        If the issue continues... It might be because files are copied and written to a Temp folder, and it could be that you have not installed SketchUp properly, and thereby the Temp folder / files have incorrect permissions for reading/writing etc...
                        To try an resolve this, you can do the following...
                        Whilst logged into Windows as your usual Windows user, ensure SketchUp is closed.
                        Find the SketchUp installer's exe file - it's usually in your Downloads folder.
                        Select the exe file's icon.
                        Right-click > context-menu > "Run as administrator"
                        When prompted choose "Repair"
                        When it completes retry SketchUp and see if it works...
                        If it still fails, then it might be some latent permissions issues...
                        Try the following...
                        Close SketchUp.
                        Find the folder: C:\Users\YOUR_USER_NAME\AppData\Local\Temp\SKMtools
                        This is where the needed JAR files get created.
                        Delete that folder.
                        Note that folders in the AppData path are hidden by default.
                        If you enter the path to the Temp folder in a Windows Explorer window it should open directly...
                        Alternatively, copy/paste this code into the SketchUp Ruby Console and press <enter>, the Temp folder should open for you.
                        UI.openURL("file:///#{Sketchup.temp_dir}")
                        When SketchUp restarts and the tool is used, then it will remake that folder and also copy in new JAR files, which should now have proper permissions.
                        • deaneauD
                          deaneau
                          Hi TIG, the ImageTrimmer lets Sketchup crash . in both Versions SKPV17 Make and V19pro.
                          what am I doing wrong?
                          Java is installed and not linked with WinRAR etc.
                          Thank you
                            When you say 'crash' what happens - in detail...
                            If you run it with the Ruby Console open - errors ?
                            Are there any other errors ?
                            Have you got a simple PNG to share to test ...
                            • deaneauD
                              deaneau
                              Page Not Found
                              Web word processing, presentations and spreadsheets
                              (drive.google.com)
                              Page Not Found
                              (drive.google.com)
                              here the png
                              https://drive.google.com/file/d/1Jhsdqlomjbc-PIK9RW5IQhjdU_NHQsbk/view?usp=sharing
                                Why not upload the files directly into your post ?
                                I'll look at them anyway...
                                PS: the error msg only shows the end - the start is usually the most informative !
                                • deaneauD
                                  deaneau
                                  some forums dont provide this.
                                  Page Not Found
                                  (drive.google.com)
                                  Error: #<TypeError: reference to deleted ComponentDefinition>
                                  C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Estimator/observers.rb:427:in entities' C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Estimator/observers.rb:427:in onComponentAdded'
                                  C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SKMtools/image_class.rb:314:in explode' C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SKMtools/image_class.rb:314:in use_as_material'
                                  C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SKMtools/image_class.rb:599:in save_imagefile' C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:191:in process_image'
                                  C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:170:in initialize' C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in new'
                                  C:/Users/Dean/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/SKMtools/ImageTrimmer.rb:834:in `block in <top (required)>'
                                    I thought I've got your PNG to trim OK.
                                    But SketchUp crashes silently after processing all of the pixels !
                                    I'll re-look at your PNG...
                                    It works with other PNG !
                                    Just did this one...
                                      If I flatten your PNG it works fine !
                                      See attached...
                                      So it must be some weird interaction of pixels ?
                                        I thought it's because you have several pixels within the main image [eyes/glasses] that are transparent...
                                        I filled them, flattened the PNG, then made the blue background the alpha-channel and it still crashes !
                                        I'm still investigating...
                                        • deaneauD
                                          deaneau
                                          https://s12.directupload.net/images/200612/y73e5rhy.png
                                          without glasses this works hm, very mysterious
                                          • deaneauD
                                            deaneau
                                            TIG if you want you can try this here. I have only safe the svg to the PNG in different resolutions.
                                            The Character Creator
                                            Create realistic characters for fun or for use in creative projects. Choose from a series of options to build your full body avatar in vector graphics.
                                            (charactercreator.org)
                                            • 6 / 9
